		Deems Davis
				 Posted: Fri Aug 07, 2009 3:18 pm    Post subject: Door seal info |
				It was great seeing everyone (at) OSH this year, and a special thanks to
 Gary,Bob and all who set up RV10 HQ and organized the dinners. Judy and
 I returned yesterday after continuing on to Long Island NY from OSH.
 Several people inquired about the door seals on N519PJ. 1st I should
 acknowledge Sheril Hilton and Robin Marks for their innovation on this
 idea, and Ed Hayden for kicking me in the pants to 'quit thinking about
 it and just Do It!' I'm very happy with the results.
 The door seal material is available from McMaster Carr
 McMaster Carr p/n 1120A311
 http://www.mcmaster.com/#1120a311/=3390lx
 I bought a 100ft roll and sold 30 ft to another -10 builder. I've got
 enough left over to do 2 more doors. I cut up an initial 12 ft section
 into pieces of various size/lengths to use  during the trial and error
 process of removing the cabin cover 'curved edge' fiberglass to provide
 the right clearance between the cabin cover and the closed door. Like Ed
 H. I found that it was necessary to glue the seal on, and after
 experimenting with several 'contact like cements' I ended up using Pro
 Seal, which works great. If you scan down this page
 http://deemsrv10.com/Homelogindex.html you will find several entries
 which describe the process I used to close out the door hinges to
 complete the seal. I helped another -10 builder here in AZ to do the same.
 Deems Davis N519PJ
		fdombroski
				 Posted: Thu Aug 13, 2009 7:13 am    Post subject: Re: Door seal info |
				Hi Deems, do you think the smaller diameter material (1/8" tube) would require less install grinding, but still seal the door?
 Frank
  _________________ Frank Dombroski
Multiple Offender RV-8, 7A, 10 x 2
RV-10 2.0 N46VT  2015
KSMQ Somerset Airport NJ |
		Deems Davis
				 Posted: Thu Aug 13, 2009 9:17 am    Post subject: Door seal info |
				I think it would we worth a try. I don't see anything that would prevent
 it. You would have to be more accurate and careful as you removed
 material, but I think it should worl as long as that channel is the same
 size as the intial. You could always order a 13 ft piece and try it.
 Deems Davis
 fdombroski wrote:
  Frank
  Frank Dombroski
  RV-10 N46WD Flying
  RV-8 N84FD final assembly
  N40 Sky Manor Airport
  http://forums.matronics.com/viewtopic.php?p 57480#257480
		aerosport1
				 Posted: Thu Aug 13, 2009 11:24 am    Post subject: Door seal info |
				Frank I do not think 1/8" would be wise if you need to grind down the flange
 more to accommodate for the smaller attach thickness 1/8". That flange
 Gives good strength to the fiber glass top. I actually made my flanges for a
 1/4" instead of the 3/16".
 Just my thoughts.
 Geoff Combs
 President
 Aerosport Modeling & Design
 8090 Howe Industrial Parkway
 Canal Winchester, Ohio 43110
 614-834-5227p
 614-834-5230f
 www.aerosportmodeling.com
  _________________ Geoff Combs
 RV-10 QB N829GW
Flying 500 hrs
40033 |
				 Posted: Thu Aug 13, 2009 11:42 am    Post subject: Door seal info |
				Everyone can make their own choices as to what materials & dimensions
 however I can tell you I am totally satisfied with our door seal set up
 (exactly like Deems) and would not change our configuration.
 Robin
				 Posted: Thu Aug 13, 2009 12:22 pm    Post subject: Door seal info |
				I had a heck of a time getting the doors to be flush with the stock Van's
 seals, how in the world did you get a flush fit with a larger seal? the idea
 is to get a good seal without needing to do major work to have the doors
 flush, the idea of 1/8 seal takes nothing away from the flange or anything
 else, unless it is not large enough, in my case it would have been fine
 since the doors were 3/16 out with the seals, 1/8th would have worked great
 for me in retrospect, but it works just fine now with the stock seals.
 So fit the doors perfectly with the flanges than fit the seals, assure there
 is no gaps whatever size is used and call it success, 3/16 IS too much
 however without needing work.
 Pascal
 From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
 Sent: Thursday, August 13, 2009 12:22 PM
 Subject: RE: Re: Door seal info
  flange
  a
  Just my thoughts.
  Geoff Combs
  President
  614-834-5227p
  614-834-5230f
		drfred(at)suddenlinkmail. Guest
				 Posted: Thu Aug 13, 2009 1:55 pm    Post subject: Door seal info |
				Pascal;
 I had to redo the fiberglass and drop the sill down enough to get the
 seal to fit.  You add more layers to the underside and then grind down
 the top.  I got the pleasure of seeing Deem's work at Osh last week.  I
 really think that the process that he describes on his website and what
 he has done to the hinge area are as good as we can do with this
 design.  I had a fair door fit before I put the seals on, but then could
 not close the door as the seal pushed up and took up too much room.
 Pulling the lip down enough to get it to seal fixed the problem.  I
 don't have the gaps filled around the hinges and do not seem to have any
 significant water or wind thru the gap.  I wish I had started out with
 the seals from Mc Master Carr and had them at the time of initial door
 fitting.  It would have been a whole lot easier to do before I had the
 wings on and had to keep all the dust out of the avionics.
 Dr Fred
  Van's seals, how in the world did you get a flush fit with a larger
  seal? the idea is to get a good seal without needing to do major work
  to have the doors flush, the idea of 1/8 seal takes nothing away from
  the flange or anything else, unless it is not large enough, in my case
  it would have been fine since the doors were 3/16 out with the seals,
  1/8th would have worked great for me in retrospect, but it works just
  there is no gaps whatever size is used and call it success, 3/16 IS
  too much however without needing work.
  Pascal
 > flange
 > flanges for a
 > Just my thoughts.
 > Geoff Combs
 > President
 > 614-834-5227p
 > 614-834-5230f
		kearney
				 Posted: Thu Aug 13, 2009 2:41 pm    Post subject: Door seal info |
				Hi Pascal
 The McMaster Carr seals require that you grind down the canopy door flanges
 until they are parallel to the door. The seal fit on this flange with the
 bulb against the door.
 This gives a great seal. I don't see how you can get a good result by
 fitting the doors first and then fitting the seals. Any kind of seal will
 impact the door geometry.
 As I understand it, the preferred course of action is to fit the doors with
 seals in place and then use epoxy etc to give a flush fit all the way
 around, feathering out to give a smooth transition between the door and the
 canopy. Doing this before the seals are installed just means more rework.
 Today I spent several hours getting my second door to fit (the first worked
 out very nicely right off the bat). Ultimately I had to shim the two delrin
 door blocks so as to provide a bit more space between the door and the
 seals. Now the doors close easily although I will need a pull strap in the
 center of the door to pull the door into the opening. A couple of pounds of
 pull in the center of the door is all that I need.
 I don't like the idea of using the door handle to pull the door closed as it
 doesn't seem like it was designed to take that kind of twisting pull. That's
 just my $0.02 though.
 Cheers
 Les
 #40643 - fitting doors & seals
				 Posted: Thu Aug 13, 2009 2:51 pm    Post subject: Door seal info |
				Les Kearney wrote:
  Hi Pascal
 Which begs the question:  Why not attach the door seal to the door
 instead of the cabin top??
 Linn
  	  | Quote: | 	 		   This gives a great seal. I don't see how you can get a good result by
  Cheers
  Les
		kearney
				 Posted: Thu Aug 13, 2009 4:00 pm    Post subject: Door seal info |
				Linn
 Here is a link to the door seals.
 http://www.mcmaster.com/#door-seals/=36cwot
 It would be tough to make this work on a door given that it is designed to
 be edge mounted. Besides, this trims off the door opening very nicely -
 aesthetics count!
 Cheers
 Les
 #40643 - living in a fibreglass world
		effectus(at)rogers.com Guest
				 Posted: Thu Aug 13, 2009 4:52 pm    Post subject: Door seal info |
				I agree with Les, Robin and Deems. The door seal on the canopy flange is THE way to go!
 It is a bunch more work but I think it gives the aircraft a much more finished look where impressions count the most. I also saw Deem's plane at OSH and the door opening was finished way better than the others I saw.
 Dave
		fdombroski
				 Posted: Sat Aug 15, 2009 5:48 pm    Post subject: Re: Door seal info |
				I am going to order both sizes, and will report back in a couple of weeks if the 1/8" bulb works out.  The flange size is the same.  The stock seals are not doing the job, so back to the dust buster...
 Thanks all.
