		john.marzulli(at)gmail.co Guest
				 Posted: Fri Aug 07, 2009 7:09 pm    Post subject: Aproximate location of the hole for the throttle handle in t |
				It seems like you need to have the friction block and bellcrank in place to find the exact location of the holes in the instrument panel.
  Can someone give me the approximate position? I am laying out my instrument panel and want to know what area I need to reserve.
  John Marzulli
 http://www.GenevieveMarzulli.org/
 http://MarzulliPhoto.net/
 http://701Builder.blogspot.com/
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Fri Aug 07, 2009 9:24 pm    Post subject: Aproximate location of the hole for the throttle handle in t |
				Don’t cut metal based on these but the original holes in my panel for the rigid throttle rods shown in the plans (which I didn’t use) appeared to be symmetrical. Both the copilot and pilot-side holes are 4.5 inches over from the lower corners of the panel and 3.75 inches up from the lower edge of the panel.
 Some people like the throttle design in the plans and some don’t (go figure). I didn’t with a Rotax 912 as the springs on the carbs make it hard to get the friction just right. I went with a vernier throttle on the pilot side and no throttle on the copilot side. Since the cable from the throttle to the firewall is flexible I also gained “flexibility” in the placement of the throttle on my panel. Life is full of compromises.
 If you are installing a Rotax and go with just a single throttle there is a throttle from McFarlane that splits into two cables at the panel. Joe Spencer installed one and his initial reports were positive:
 http://www.mcfarlaneaviation.com/Details.aspx?ID=11744352&Article=199
 This allows you to eliminate the linkage/mixer rod forward of the firewall.
 -- Craig
 From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of John Marzulli
  Sent: Friday, August 07, 2009 9:05 PM
  Subject: Aproximate location of the hole for the throttle handle in the panel?
  John Marzulli
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Zenith701801-List  | 	  0123456789
		Tommy Walker
  Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
				 Posted: Sat Aug 08, 2009 3:41 am    Post subject: Re: Aproximate location of the hole for the throttle handle |
				John, I reserved the left 1/5th of the panel on each side for this.  I put the choke on the left, nearest the door and the throttle above that.  I put the elevator trim just above the throttle so I could operate the trim without removing my hand from the throttle.
 On the other side, I put the cabin heat, Hobbs, and other throttle.
 I can send pics if you want.
 Tommy Walker in Alabama
 Do Not Archive this or anything I ever post on the internet.
 [quote="john.marzulli(at)gmail.co"]
  John Marzulli
  _________________ Tommy Walker
N25A  -  Anniston, AL |
