EFIS
lcfitt(at)sbcglobal.net
PostPosted: Sat Aug 08, 2009 9:26 am    Post subject: EFIS Reply with quote
To those who are installing an EFIS in their panel, what backup instruments
are you installing / considering.
Lowell
darinh
PostPosted: Sat Aug 08, 2009 10:25 am    Post subject: Re: EFIS Reply with quote
Lowell,
I put in a backup ASI and altimeter. I guess you could also argue a turn coordinator would be good but I really only fly day VFR anyway so if I know my altitude and airspeed, I am good to go.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
Fox5flyer
PostPosted: Sat Aug 08, 2009 11:25 am    Post subject: EFIS Reply with quote
I'm using the Grand Rapids EIS, but an early version. It contains all of
the engine instruments including OAT, engine hours, and more, plus parameter
alarm. It puts a lot of instruments in a small spot on the panel so I
could have a large glove box for charts, CDs, etc. Never had a problem with
it.
What I have on the panel is Airspeed, TC, Altimeter, Artificial Horizon,
Vertical Speed. Also have a Fuel Flow meter and G meter, but that could
easily be eliminated as it's never had a useful purpose other than to tell
me how bad my landings are.
Most of the EFIS units I've perused have way too many things crammed into a
small screen for me to interpret under pressure. Just my opinion.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 430+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
CDE2fly(at)aol.com
PostPosted: Sat Aug 08, 2009 6:26 pm    Post subject: EFIS Reply with quote
Lowell - I've got airspeed, altimeter, vertical speed, and an electric turn coordinator for redundancy to a Dynon D-100 in my Model 7(see attached photo) . I've got 11 hours on the airplane and find myself glancing more and more at the Dynon. It's the first airplane I've had with an EFIS and I must say I'm very impressed with it!
Chris
Model 7, 912S
In a message dated 8/8/2009 1:27:01 P.M. Eastern Daylight Time, lcfitt(at)sbcglobal.net writes:
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Lowell ======================== the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
 Filesize:  1.13 MB
 Viewed:  8452 Time(s)
nail13zg(at)centurytel.ne
PostPosted: Sun Aug 09, 2009 2:08 pm    Post subject: EFIS Reply with quote
I am using the Dynon EFIS with the Garmin 296's flight instrument page for
backup.
Trey Moran
Mod 5
PostPosted: Sun Aug 09, 2009 8:49 pm    Post subject: EFIS Reply with quote
Thanks to all who have responded to my question. I have lots of ideas and
time will tell if I go with an EFIS or my panel looks traditional and old
fashioned.
Lowell
JetPilot
PostPosted: Thu Aug 13, 2009 5:02 pm    Post subject: Re: EFIS Reply with quote
I am installing a Grand Rapids EFIS in my Kitfox 7 SS. I will not be putting any backup instruments in it. I do not plan to fly IFR, and even if I lost the entire EFIS, anyone with a little skill and experience should be able to easily land a light plane like a Kitfox VFR with no instruments. A properly installed EFIS system is very reliable, probably more reliable than a panel full of old school vacuum driven Gyros, etc.... I have been flying EFIS airplanes thousands of hours for the last 10 years, EFIS is clearly superior to analog gages..
In a pinch, GPS makes a great backup for airspeed indicator. I know it reads ground speed, but I always have a pretty good idea of where the wind is coming from and how strong when I land, easy enough to get it within a few MPH if one has no skills and is not capable of doing a landing without airspeed Wink
If I just had to have a backup, it would be a single airspeed indicator... Nothing else. For what its worth, I have seen several failures of mechanical airspeed indicators, but never an airspeed failure on an EFIS... In the end, its just a question if a builder is open minded enough to embrace new and better technology, or if he is so stuck in old ways, that he must have inferior analog gages...
Kolb MK-III Xtra, 912-S
