				 Posted: Sat Aug 08, 2009 1:44 am    Post subject: W & B, cruising, stalling and landing |
				I still think it's magic,   or wires.>>
 Hi Robert,
 its magic all right.  With most magic knowing how it works makes it less
 magical. I think flying is one of those things which is still magical even
 when you know (ot think you know) the mechanics.
 At least for me, when the wheels leave the ground it doesn`t matter if you
 know how or why....its away with the other broomsticks.
 Pat
				 Posted: Sat Aug 08, 2009 1:55 am    Post subject: W & B, cruising, stalling and landing |
				/or in the _direction_ of the relative wind will affect this.
 Hi Lucien,
 that is what I said., or thought I did.
 Pat
				 Posted: Sat Aug 08, 2009 4:17 am    Post subject: W & B, cruising, stalling and landing |
				Nah, it's not lift or anything like that at all. It's gobs and gobs of
 cash...>>
 You crazy mixed kid! You have gone all twisted and bitter. Go fly
 Cheers
 Pat
		russ(at)rkiphoto.com Guest
				 Posted: Sat Aug 08, 2009 5:34 am    Post subject: W & B, cruising, stalling and landing |
				Pat, Ladd
 Got to take issue with you in re sailboats going  to windward.
 You say when the apparent (relative) wind moves forward, as when
 boat speed increases, this enables the boat to point higher. It most
 certainly does NOT -- Just the opposite! You must bear off, point
 lower, point further from  the direction the wind comes from, to keep
 sailing, keep the sails full  -- or to keep lift, if in an  aircraft.
 Just substitute angle of relative wind on the boat for AOA on the
 aircraft. You can delay the luff by trimming in the sails, but
 relative wind moving forward does not allow you to point up further.
 As you say, think about it. The sails will luff if you keep your
 course or bear up, you must bear off.
 Sorry to disagree but I've been there too often to count.
 BTW earlier you mentioned a "Boot Sale in  an  adjacent field"? -- is
 this really a sale of footwear or am I missing some English -
 American translation issue? If so, please pardon my Colonial ignorance!
 All best, fair winds,
 Russ
 On Aug 7, 2009, at 6:06 AM, pj.ladd wrote:
  but in actual flight they reach those angles at certain
  corresponding airspeeds.>>
  Hi Rick,
  Not true. Your wing in level flight supports a certain weight .
  Increase that weight and the wing will NOT support it. In other
  words it stalls. How can you do this? Easy! Alter your flight path
  markedly, this will increase the `g` force and the plane will in
  effect weigh more.
  Its all about what a sailor would call `apparent wind` As a yacht
  increases its speed  the direction the wind is coming from moves
  towards the bow. This enables a boat to `point higher`,i.e to
  decrease the angle of attack. It is the same with a planes wing .
  Go fast and the AOA moves forward, go slowly and the AOA moves
  back. If you increase the weight of the a/c (pull `g`) the wing
  will `mush` through the airand the AOA will move backwards
  `WHATEVER THE AIRSPEED`
  I am sure thats clear as mud but think about it.
  Cheers
  Pat
				 Posted: Sat Aug 08, 2009 8:11 am    Post subject: W & B, cruising, stalling and landing |
				Russ, that means selling from the trunk of the car.  AKA "boot"
 BB
 don't ask about bees in the bonnet
 On 8, Aug 2009, at 9:30 AM, russ kinne wrote:
  Pat, Ladd
  most certainly does NOT -- Just the opposite! You must bear off,
  point lower, point further from  the direction the wind comes from,
  to keep sailing, keep the sails full  -- or to keep lift, if in an
  aircraft. Just substitute angle of relative wind on the boat for
  AOA on the aircraft. You can delay the luff by trimming in the
  sails, but relative wind moving forward does not allow you to point
  up further.
  is this really a sale of footwear or am I missing some English -
  ignorance!
  Russ
 > Hi Rick,
 > effect weigh more.
 > Cheers
 > Pat
		Arksey(at)aol.com Guest
				 Posted: Sat Aug 08, 2009 1:19 pm    Post subject: W & B, cruising, stalling and landing |
				interesting statements on full stall landings...I learned to  fly in a J-3 and was taught to have the stick clear back into your belly when  the plane touched the ground and was fully stalled....I still want to try and do  that with my firestar and found it difficult to get a good landing....have often  had the tail wheel hit 1st...have just by experence learned that I seem to get a  lot better landing when I only bring the stick back part way...so you can see  why your discussions on this subject have been interesting to  me.....jswan
  JIM  SWAN
 firestar ll, 503, N663S
 Eaton Rapids, Mi. 48827
 PH 517-663-8488  runway 2300' E & W (42-28.58N 084-44.69 W  )
		lucien
				 Posted: Sat Aug 08, 2009 4:10 pm    Post subject: Re: W & B, cruising, stalling and landing |
				 	  | pj.ladd(at)btinternet.com wrote: | 	 		  Nah, it's not lift or anything like that at all. It's gobs and gobs of
 cash...>>
 Cheers
 Pat |
 I don't think the wind is going to allow it this eve, but I may take another shot at it in the morning. I get a lot grumpier when I don't get to fly and summer is a terrible time for it. Can't wait till fall/winter...
 LS
  _________________ LS
Titan II SS |
		JetPilot
				 Posted: Sat Aug 08, 2009 4:58 pm    Post subject: Re: W & B, cruising, stalling and landing |
				 	  | Arksey(at)aol.com wrote: | 	 		  interesting statements on full stall landings...I learned to  fly in a J-3 and was taught to have the stick clear back into your belly when  the plane touched the ground and was fully stalled....
 This would be different with different aircraft types, depending on landing gear setup and other factors.  Also many times, instructors say things that are not quite true in the interest of simplifying an idea for a student.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
				 Posted: Sun Aug 09, 2009 1:43 pm    Post subject: W & B, cruising, stalling and landing |
 relative wind moving forward does not allow you to point up further.>>
 Hi Russ,
  arguing with you about sailing is like arguing with the Hauck about flying
 and I  have more sense than to do either.
 Starting from the assumption that you were right I reworked the problem....I
 think my memory of what we did was accurate but the reason we did it was
 not.
 As I remebered it, and I haven`t sailed a dinghy for nearly 60 years, it was
 always `harden up in the gusts` but having spent some time today drawing
 diagrams and trying to think myself through the problem I have come to the
 conclusion that hardening up in the gusts was probably to spill some wind to
 avoid a knockdown. I DO remember that when I sailed catamarans we bore away
 from the wind in the gusts because cats accelerated so much faster than
 monohulls they could ride out a strong gust just by going faster.
 Sincere apologies all the way round, my analogy was unsound. I still think I
 am right about the rest of my argument.
 About `boot` sales. Remember that in the UK the trunk of your car (where you
 put the luggage) is our boot.
 Hence a boot sale happens when a farmer makes a field available. He charges
 people who wish to sell goods, from the boot of their car, to park in his
 field and set up shop. Sometimes stuff is laid out on a groundsheet on the
 grass, some bring folding tables. The farmer then charges prospective
 customers to park in the filelds and go shopping.  Most of the stuff is
 rubbish, but one mans rubbish is anothers treasure. Cheap CD`s and DVD`s
 sometimes pirated, some just secondhand copies . Cheap hand tools, garden
 tools, fishing stuff, you name it. It is a very popular way of passing a
 Sunday morning in the UK. Some affairs are gigantic, perhaps on an old
 airfield, sometimes a small affair with the profits going to the local
 church or Boy Scouts. The farmer whose farm I fly from runs a boot sale and
 proceeds go to the local Flying Ambulance Service.
 To get back to flying. Just landed from a nice flight of about an hour.
 Didn`t take off until about 7.45 so the wind had dropped and the air was
 smooth. The Bristol Balloon Festival has been going on all week and there
 were dozens of hot air balloons drifting down towards my field, gettting in
 the last flight of the competition. Spectacular flying alongside the balloon
 stream . crazy designs and brilliant colours. Had to watch it a bit as they
 were coming out of the setting sun and were hard to see from slightly above.
 Getting dusk when I landed and everyone else had packed up. Pleasant way to
 end up a weekend of  glorious weather.
 Cheers
 Pat
		Richard Pike
				 Posted: Wed Aug 12, 2009 6:58 pm    Post subject: Re: W & B, cruising, stalling and landing |
				To John: something you said got my twisted little mind to working: ...
 "3-Required the wings be rigged with more angle of attack so we could take off and land in a nearly level attitude, and to prevent the tail from sagging to the extreme when doing slow flight. It also slows the cruise speed because of additional drag of pulling the tailboom through the air sideways. The Sling Shot will really sag in the tail when slowed down because is has a lot less incidence than the MKIII and FS.
 mkIII"
 Hmmm - so I went out to the hangar and looked at how the bottom of the root rib aligns with the frame that you attach the center section lower fabric to, which is (more or less) aligned with the underside of the wing. Mine has always been misaligned, the rear lines up, the front, not so much. The wing has too great an angle of attack to line up with the front part of the framework, it is about 5/8" too high. And it is built exactly to plans. (At least in this area...)
 So I gets to thinking - "What if I were to drill a new hole in each root rib tang about 5/8" lower and drop the angle of incidence of each wing until it lines up with the lower center section? That would take about 2.5-3 degrees of incidence out of the wings, and maybe pick up a bit of cruise speed? Would need to retrim the elevators, reshim the angle of the motor mounts, etc, but might be worth the hassle. Takeoff runs might be a bit different, landings too, but overall... Hmmm..."
 Now look what you've done...
 Richard Pike
 MKIII N420P (420ldPoops)
				 Posted: Thu Aug 13, 2009 4:18 am    Post subject: W & B, cruising, stalling and landing |
  Richard Pike
 Rev:
 I would have taken some incidence out of my wings a long time ago, but it
 would have required too many other changes.  I wasn't willing to make all
 the other changes required for a couple mph.
 Gary Haley took some incidence out of his MKIII wings when he rebuilt it a
 couple years ago.  Speed increase was not significant.
 Decreasing incidence will also increase dihedral, unless lift struts are
 shortened accordingly.
 Will also require changing the 3 point stance of the MKIII, raising the nose
 to increase angle of attack and allow the aircraft to rotate on take off.
 Raising the nose will also improve 3 point landing capability.
  _________________ John Hauck
Titus, Alabama |
				 Posted: Thu Aug 13, 2009 4:27 am    Post subject: W & B, cruising, stalling and landing |
				Richard, if you still have the aluminum legs you may be in for a
 somewhat longer ground roll during takeoff.
 I got as far as installing the longer legs but got sidetracked by
 fuel flow/pressure problems and life in general.
 A stock MkIII windshield and cabin configuration might not see much
 change.  Mostly because the curvature
 of the window allows most of the air to slip around and provide more
 lift at the wing root bottoms.
 There would be a slight increase in lift under the nose which would
 reduce down force requirement at the tail.
 Your cabin configuration is another matter.  Not much down force on
 your window.
 Mine has a wide flat window that slips a lot of air up and over,
 around the engine to the prop.  Very little
 is diverted to underside wing lift.  The down force on the nose is
 considerable.  I should benefit from
 an incidence more like the Xtra.
 One of these days.
 BB
 On 12, Aug 2009, at 10:58 PM, Richard Pike wrote:
  mkIII"
  this area...)
  Richard Pike
  http://forums.matronics.com/viewtopic.php?p 57418#257418
