Top skin rollover
rmacpunk(at)netzero.net
PostPosted: Sat Aug 08, 2009 1:13 pm    Post subject: Top skin rollover Reply with quote
How did you guys handle the top skin rollover on 6B21-1 on the 601XL? TIA Bob
craig(at)craigandjean.com
PostPosted: Sun Aug 09, 2009 1:11 pm    Post subject: Top skin rollover Reply with quote
Page 12 of the “6-B-21B” photo guide shows that the edge of the skin is wrapped around the tube. This works best if you minimize the edge distance. As it says in the guide “Wait to bevel the front edge until after the skin is riveted”
http://www.zenithair.com/zodiac/xl/data/6-b-21b.pdf
I recall one builder relief cut slots (with stop holes at their back) between the rivets to minimize the ripple.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bob McArdle
Sent: Saturday, August 08, 2009 3:00 PM
Subject: Top skin rollover
Gig Giacona
PostPosted: Sun Aug 09, 2009 1:23 pm    Post subject: Re: Top skin rollover Reply with quote
Tapped it with a rubber mallet.
W.R. "Gig" Giacona
601XL Under Construction
grs-pms(at)comcast.net
PostPosted: Sun Aug 09, 2009 1:55 pm    Post subject: Top skin rollover Reply with quote
I assume this is a reference to the forward edge of the top skin, just aft of the cockpit (6F14-2 on my 601HD/HDS drawing). If so, the following may be helpful.
I made relief slots which are actually more like wide notches with the notch the same depth as the rivet edge distance. My rivets are spaced at approximately 50mm. The notches are tapered at about 45 degrees, so that the tab containing each rivet is about 30mm wide at its forward edge. The tabs are rolled smoothly around the tube. As I remember, I formed the tabs before I rivetted the skin in place, so I could "over-bend" them a little bit for a tighter fit.
If I were to do it again, I believe I would not roll the skin, but simply finish the outstanding edge with a molded U-channel, ACS p/n 05-01400 or something similar.
George Swinford
sabrina
PostPosted: Sun Aug 09, 2009 9:55 pm    Post subject: Re: Top skin rollover Reply with quote
dredmoody(at)cox.net
PostPosted: Mon Aug 10, 2009 5:08 am    Post subject: Top skin rollover Reply with quote
George Swinford>>
I did not have the foresight to anticipate how unsatisfied I would be with tapping that free edge down to the tubing contour. Afterward, I knew that I would never be happy looking at that result everytime I entered and exited the airplane. I bought some automotive radiator hose, cut it length-wise and slipped it over the ugly edge. It has to stop a little bitshort of the bottom on both sides to avoid interferring with the canopy but I can live with that. Now I have a decent looking rubber molding to conceal the middle top skin's forward edge... problem solved.
Ed
carlossa52(at)gmail.com
PostPosted: Mon Aug 10, 2009 8:42 am    Post subject: Top skin rollover Reply with quote
Scott Laughlin had a nice solution for this. Unfortunately he shutdown his web site, but maybe he'll comment on this thread...
Carlos
AZFlyer
PostPosted: Mon Aug 10, 2009 9:45 am    Post subject: Re: Top skin rollover Reply with quote
To minimize the dreaded "buckled edge" on the roll over: double the rivets along the edge, ie. every 25 mm, and cut the edge distance to 7mm. Use a rubber or plastic hammer and go slowly. (picture attached)
This same philosophy works at the longeron as well.
 Filesize:  647.91 KB
 Viewed:  9794 Time(s)
Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"!
AZFlyer
PostPosted: Mon Aug 10, 2009 9:46 am    Post subject: Re: Top skin rollover Reply with quote
 Filesize:  647.91 KB
 Viewed:  9793 Time(s)
PostPosted: Mon Aug 10, 2009 11:07 am    Post subject: Top skin rollover Reply with quote
Thanks to all who responded to my question. Bob
