rv(at)thelefflers.com Guest
Posted: Mon Aug 10, 2009 1:40 pm Post subject: Transponder antenna location |
I’m in the process of installing doublers for all of my antennas attached to the fuselage bottom.
I understand that the transponder antenna coax run should be 3’to 8.8’. I know that some have mounted the transponder antenna in the center tunnel near the firewall. Others appear to have located it under the rear seat or baggage area. Since this appears to require a coax run of longer than 8.8’, I’m curious to what issues (or lack thereof) folks have experienced when they located their transponder antennas in these areas? Is 8.8’ really a hard limited from Garmin?
#40684
scottmschmidt(at)yahoo.co Guest
Posted: Mon Aug 10, 2009 3:23 pm Post subject: Transponder antenna location |
I never knew of the 8' rule. I did read that 48" (I think, may be more) from any COM antenna was very important which is why I put it aft of the baggage compartment and have not had any issues.
Scott Schmidtscottmschmidt(at)yahoo.com
Sent: Monday, August 10, 2009 3:42:44 PM
Subject: Transponder antenna location
#40684
[quote]http://www.matronics.com/Navigator?RV10-List<//www.matronics.com/contribution">http://www.matronics.com/contribution============
tc1234c(at)roadrunner.com Guest
Posted: Mon Aug 10, 2009 5:11 pm Post subject: Transponder antenna location |
I don't see the minimum coaxial cable length in the installation manual (Garmin 327). The maximum 8.8' is for RG 400. On my 9A I have the TED antenna mounted right besides right gear mount and worked well. I keep it three feet away from my main COM antenna. There is no interference at all. On my 10 I will try to run all my antenna cables as short as possible.
On 8/10/2009 5:42 PM, Bob Leffler wrote: [quote] <![endif]--> <![endif]-->
#40684
| [b]
AirMike
Posted: Mon Aug 10, 2009 9:57 pm Post subject: Transponder antenna location |
In Tunnel - under seat - watch out for glowing genitals
I can't help it. I am a sick man.
Seriously though, the radiation issue was discussed some time ago on this list. Not an issue
_________________ See you OSH '18
Q/B - sold. |
Ron.McGann(at)thalesgroup Guest
Posted: Mon Aug 10, 2009 10:48 pm Post subject: Transponder antenna location |
8.8' of RG400, 12.5' of RG304, 17' of RG393.
Some may know that I've had the 'leans' with my GRT EFIS. Initialises
perfectly on the ground with no anomalous heading, but tilts 3-4deg once
airborne. I have my XPDR antenna in the tunnel beneath the fwd baggage
area, with the magnetometer in the 'stock' location on a shelf above and
aft of the battery. Since the XPDR only transmits once airborne ('SBY'
on the ground and automatically enters 'ALT' mode), and the AHRS only
leans in flight, me thinks that perhaps the XPDR antenna is too close to
the magnetometer and may be interfering when responding to a ping . . .
Posted: Tue Aug 11, 2009 12:54 am Post subject: Transponder antenna location |
Ron,
Contact GRT for your lean problem. I don't think it is due to RF
interference. I had that problem 520 hrs ago (at 120 hr). Called GRT and
sent in a log file. They confirmed it was a bad MEMS gyro. They replaced
both my magnetometer and AHRS (must be in pairs). I have no lean
problem ever since.
Ted
Ted Chang
RV9A flying, RV10 Wing
http://3limafoxtrot.com
my flight track:
http://www.mail2600.com/cgi-bin/track.cgi?call=KD8IIR&last=1
Will turn the XPDR off next flight and see what happens.
Ron
VH-XRM flying in Oz
wayne.e(at)grandecom.net Guest
Posted: Tue Aug 11, 2009 3:57 am Post subject: Transponder antenna location |
Hi Bob,
I installed mine in the tunnel forward to the firewall. It made the run very easy and I've had no difficulties that I'm aware of.
Wayne Edgerton
N602WT
Time: 02:40:21 PM PST US From: "Bob Leffler" <rv(at)thelefflers.com (rv(at)thelefflers.com)> Subject: Transponder antenna location
I'm in the process of installing doublers for all of my antennas attached to
I understand that the transponder antenna coax run should be 3'to 8.8'. I
8.8', I'm curious to what issues (or lack thereof) folks have experienced
when they located their transponder antennas in these areas? Is 8.8' really
#40684
Tim Olson
Posted: Tue Aug 11, 2009 7:14 am Post subject: Transponder antenna location |
I don't know that it would be a XPDR antenna location issue
that would cause your leans, but, the XPDR antenna does
put out something pretty strong...I think I heard 75W
or so? So it's probably a good idea to keep it at least
a couple feet from the AHRS/Magnetometer.
Tim Olson - RV-10 N104CD
Ron
VH-XRM flying in Oz
Phil.Perry(at)netapp.com Guest
Posted: Tue Aug 11, 2009 7:20 am Post subject: Transponder antenna location |
That makes a lot of sense on the limitation. I’ll bet 8.8’ is a multiple of the wavelength where they begin to lose significant amounts of their effective radiated power (erp).
At the 1Ghz frequency range, the amount of signal loss is very high. The wavelengths are tremendously short and it takes a lot to get the signal out the other end of the coax and still have enough energy remaining at the antenna to broadcast a signal.
The rule of thumb for all coax runs is to keep them as short as possible and to use higher-end coax on the higher frequencies.
It’s usually not that big of a deal at the VHF frequencies, but you still want to keep them fairly short because VHF is still pretty lossy – But it’s nothing like the Ghz frequency range. I’ve measured power at the end of a 10’ coax run in the 1.2ghz area and that’s when it really sunk in at how much was lost in the coax.
The shorter the better and the lower loss the coax the better.
Phil
Sent: Monday, August 10, 2009 4:43 PM
#40684 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
bcondrey
Posted: Tue Aug 11, 2009 7:21 am Post subject: Transponder antenna location |
It's actually 250 watts (for a GTX-330). The aluminum airframe is
likely shielding the signal from the AHRS in question and it's unlikely
that it would be causing the issue.
I've got my antenna below the bay where the battery is and haven't had
any issues (transponder or otherwise).
N442PM
Lenny Iszak
Posted: Tue Aug 11, 2009 9:12 am Post subject: Re: Transponder antenna location |
Also the transponder is transmitting in very short bursts, so you'd probably see those bursts showing up on your magnetometer if this was the issue.
But as Bob said, the airframe is shielding that signal from reaching the magnetometer, just as it shields your genitals... Yeah, just come to think of it, I put my transponder antenna under the pilot seat... ooops.
Lenny
Bob Turner
Posted: Tue Aug 11, 2009 9:20 am Post subject: Re: Transponder antenna location |
Nine feet of RG-400 loses about 30% of the power at 1 GHz. leaving you with 70% of what you started with (not counting connector losses). So if you double the length, to 18 feet, you only get 49% of what you started with to the antenna.
This sounds like a lot (and it is!) but in practice if the shorter length works okay when you're 100 nm from the radar antenna, then the 18 feet will work okay when you're within 84 miles (square root of 0.7) of the antenna site. Not really that much difference.
For years I've flown a 182 with the transponder antenna in the back, more than 9 feet of coax. Always works okay,passes biennial tests. So try to keep lengths down, but don't worry too much. Do make sure you use good connectors.
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Tue Aug 11, 2009 9:42 am Post subject: Transponder antenna location |
You will find most factory built aircraft will have the transponder and DME antennas right below the front seat ankle area or just ahead of leading edge of wing on belly. Why give away power and pay more for cable?
On Tue, Aug 11, 2009 at 10:20 AM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote] --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=257160#257160
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Bob Turner
Posted: Tue Aug 11, 2009 1:15 pm Post subject: Re: Transponder antenna location |
Maybe I'm wrong; my observation is most factory planes try to separate the DME and transponder antennas by as much as they can, since they operate on frequencies that are nearly the same. That's how you end up with long cable runs to the transponder. I think most DMEs can even be connected to the transponder, so they know not to 'listen' when the transponder transmits.
But overall I agree, it's best to minimize the coax runs, especially at a GHz.
Has anyone with a forward mounted antenna had any heat issues, similar to the hot tunnel issues?
RV-10 QB |
Kelly McMullen
Posted: Tue Aug 11, 2009 1:37 pm Post subject: Transponder antenna location |
If you look at a few single Cessnas you will find DME and transponder on opposite sides of the fuselage with maybe 36-40" separation. I'm sure that is more than a couple wavelengths, and yes I believe there is an interconnect cable to keep their pulse transmissions separated.
On Tue, Aug 11, 2009 at 2:15 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=257184#257184
le, List Admin.
KCHD |
rv10free2fly(at)yahoo.com Guest
Posted: Tue Aug 11, 2009 5:12 pm Post subject: Transponder antenna location |
Wayne, could you please indicate the distance back from the firewall for the trasnponder antenna please?
Any effect on the antenna as a resut of the exhaust?
Patrick Pulis
#40299
South Oz
Sent: Tuesday, 11 August, 2009 9:25:57 PM
Subject: Re: Transponder antenna location
Hi Bob,
Wayne Edgerton
N602WT
#40684
| Quote: | http://www.matronics.com/Navigator?RV10http://www.matronics.com/contribution" target=_blank rel=nofollow>http:========================
Find local businesses and services in your area with Yahoo!7 Local. [url= http://au.rd.yahoo.com/search/local/mailtagline/*http://local.yahoo.com.au] Get started[/url]. [quote][b]
