craigb(at)onthenet.com.au Guest
Posted: Mon Aug 10, 2009 4:56 pm Post subject: Finger brakes / ground handling |
[quote] I was just looking at installing finger brakes, but it occured to me on the Trigear
it could be hard to control on the ground in that configuration, one hand on throttle,
one on brakes to stear, and stick??? Thoughts please
craig
Kit 577
VH-XSV
jeff(at)rmmm.net Guest
Posted: Mon Aug 10, 2009 6:24 pm Post subject: Finger brakes / ground handling |
Craig,
Now that I'm use to flying / Taxing my tri-gear I have trouble even
thinking of foot brakes. You will get use to anything in a while and
this is no exception. I can run my brakes and run the throttle all with
the right hand. I can't imagine doing it any other way and I grew up
like most in a 152 then Cherokee.
Put in the brakes. It's a non issue.
Jeff R.
A258 - N128LJ / Gold Rush 191 hours and climbing slowly.
On Aug 10, 2009, at 7:47 PM, craig bastin wrote:
> on the Trigear
> hand on throttle,
> craig
> Kit 577
> VH-XSV
gholland(at)content-strea Guest
Posted: Mon Aug 10, 2009 9:23 pm Post subject: Finger brakes / ground handling |
Craig Hi!
As per Jeff's comments. It becomes second nature to use finger brakes.
Ensure levers are long enough and keep speed to a good walking pace to taxi. Use Rudder too. They become quite accurate to use and control and I found them easy to use doing a short field landing. Juggling with throttle also seems to work out after a few goes.
Gerry
Visit - www.EuropaOwners.org
kheindl(at)msn.com Guest
Posted: Tue Aug 11, 2009 1:37 am Post subject: Finger brakes / ground handling |
craig C
control the stick with your knees
karl
Subject: Europa-List: Finger brakes / ground handling
Date: Tue C 11 Aug 2009 10:47:21 +1000
.ExternalClass .EC_shape {;} (at)page Section1 {size:612.0pt 792.0pt;} .ExternalClass P.EC_MsoNormal {font-size:12pt;font-family:'Times New Roman';} .ExternalClass LI.EC_MsoNormal {font-size:12pt;font-family:'Times New Roman';} .ExternalClass DIV.EC_MsoNormal {font-size:12pt;font-family:'Times New Roman';} .ExternalClass A:link {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass SPAN.EC_MsoHyperlink {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass A:visited {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass SPAN.EC_MsoHyperlinkFollowed {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass P {font-size:12pt;margin-left:0cm;margin-right:0cm;font-family:'Times New Roman';} .ExternalClass PRE {font-size:10pt;font-family:'Courier New';tab-stops:45.8pt 91.6pt 137.4pt 183.2pt 229.0pt 274.8pt 320.6pt 366.4pt 412.2pt 458.0pt 503.8pt 549.6pt 595.4pt 641.2pt 687.0pt 732.8pt;} .ExternalClass SPAN.EC_EmailStyle19 {color:navy;font-family:Arial;} .ExternalClass SPAN.EC_SpellE {;} .ExternalClass DIV.EC_Section1 {page:Section1;}
[quote] I was just looking at installing finger brakes C but it occured to me on the Trigear
it could be hard to control on the ground in that configuration C one hand on throttle C
one on brakes to stear C and stick??? Thoughts please
craig
Kit 577
VH-XSV
| Quote: | http://www.matronics.com/Navigator?Europa-List
ronics.com
ww.matronics.com/contribution
Posted: Tue Aug 11, 2009 2:10 am Post subject: Finger brakes / ground handling |
I had considered that as an option.
[quote] Subject: RE: Finger brakes / ground handling
craig,
karl
rampil
Posted: Tue Aug 11, 2009 12:44 pm Post subject: Re: Finger brakes / ground handling |
Hi Gerry,
Your advise is straight from the book, so to speak, but it is inconsistent
If you taxi at walking speed, your rudder will have no detectable effect
on directional control. My rudder begins to be useful only over speeds
of 12kts. I can't even run that fast
Be save!
Posted: Tue Aug 11, 2009 8:14 pm Post subject: Finger brakes / ground handling |
Ira Hi!
You are right. On reflection the required taxi speed is a little faster than walking pace. I erred on the side of a slower description speed in case it was envisioned that you were needing to use lots of power and racing around. The action becomes second nature very quickly.
As for YOUR running speed.... I'm glad it's slow. That means you are not chasing your dinner or being chased as an intended dinner! No other reason to run anywhere!!
Gerry
