Phil.Perry(at)netapp.com Guest
Posted: Tue Aug 11, 2009 9:55 am Post subject: QB Fuse........ State of Shipment |
So I’m FINALLY getting close to putting my fingers on a QB fuselage. I’ve only been waiting for it the be delivered since early December. Hopefully it’ll be here in mid-Sept.
For those of you who received the QB fuse’s, approximately what chapter did they leave off? I’m guessing it’s somewhere between 29 and 32.
Yeah, I know to start at the beginning and check box everything, but I’m also trying to get a handle on where we will realistically be so I can proactively get a handle on the steps ahead.
Phil
Bob Turner
Posted: Tue Aug 11, 2009 1:22 pm Post subject: Re: QB Fuse........ State of Shipment |
IMHO you really do need to go thru everything carefully. There are quite a few "small" things left undone, in between steps in the manual where things were done. There are a number of places where dimpling was not done, and now that the parts are assembled, it's much harder to dimple there. I even removed a few rivets in the tunnel because they weren't dimpled underneath.
Look it over carefully. My QB wings had the fuel tanks installed with too-long bolts, compensated with extra washers. I guess this worked, but I sure didn't like it.
_________________ Bob Turner
RV-10 QB |
Posted: Tue Aug 11, 2009 9:25 pm Post subject: QB Fuse........ State of Shipment |
I’d be stupid not to check and make sure everything is done. That’s to be expected.
But does anyone recall the approximate stage of completion where they could definitely say the work hadn’t been completed?
Phil
Sent: Tuesday, August 11, 2009 12:53 PM
Subject: QB Fuse........ State of Shipment
Phil
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
