MauleDriver(at)nc.rr.com Guest
Posted: Tue Aug 11, 2009 5:23 pm Post subject: Filtered Air Box (FAB) alignment |
Thanks in advance to Tim and others who have documented their install.
Can anyone tell me what the two pre-punched or pre-drilled holes in the
VA-131-B Air Box Top Plate are for?
I initially thought it was for alignment of the top plate with the
VA131-C mount plate but that doesn't work. Now I'm thinking they are
just some sort of tooling holes used in Van's fabrication process.
The hole in the rear of the plate seems to be depicted on the "plans".
The hole in the front isn't depicted but would probably be cut out as
part of the carb heat door (which I don't need on my fuel injection setup).
Bill "FWF" Watson
Posted: Tue Aug 11, 2009 7:39 pm Post subject: Filtered Air Box (FAB) alignment |
IIRC, those are just tooling holes.
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
352-427-0285
On Aug 11, 2009, at 9:20 PM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com
> wrote:
the VA-131-B Air Box Top Plate are for?
are just some sort of tooling holes used in Van's fabrication process.
"plans". The hole in the front isn't depicted but would probably be
cut out as part of the carb heat door (which I don't need on my fuel
injection setup).
Bill "FWF" Watson
