		mustangsally(at)semo.net Guest
				 Posted: Sat Apr 01, 2006 5:19 am    Post subject: New member/ owner |
				Let me  introduce myself. I just picked up a mid 90's unfinished firestar.
 I may be asking questions in the future.
 I currently fly a CWII Challenger and have for about 6 years. I am in SE
 Missouri and fly from my own strip.
 How hard or challenging is to go from a nose wheel plane to the Kolb? I
 haven't ever flown a tail wheel.
 Jerry Deckard
				 Posted: Sat Apr 01, 2006 5:43 am    Post subject: New member/ owner |
				Jerry, spend a couple sessions driving it up and down your strip.
 That should do it.   Pay attention to how well your tail wheel responds
 and adjust it if necessary.  The flying/landing part is no big deal.
 Fly it to within a foot or so of the ground.  Forklifts are tougher to
 handle.
 -BB  do not archive
 On 1, Apr 2006, at 8:16 AM, Jerry Deckard wrote:
  <mustangsally(at)semo.net>
  firestar.
  SE
  Jerry Deckard
		dhkey(at)msn.com Guest
				 Posted: Sat Apr 01, 2006 6:05 am    Post subject: New member/ owner |
				Make sure you are landing into the wind for a while. Look at the far end of
 the runway when you get close to landing and when you are high speed
 taxiing. Over correcting was my biggest problem at first, if it's going
 crooked then make tiny rudder adjustments, not one big one. If you have your
 own field then cut the runway a little wider. Make sure you're not drifting
 across the runway center line on final or before touch down. After a month
 none of this advise will be important to you any more, it's easy.
  	  | Quote: | 	 		  From: "Jerry Deckard" <mustangsally(at)semo.net>
 Reply-To: kolb-list(at)matronics.com
 To: <kolb-list(at)matronics.com>
 Subject: New member/ owner
 Date: Sat, 1 Apr 2006 07:16:59 -0600
 Jerry Deckard
		John Jung
  Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
				 Posted: Sat Apr 01, 2006 7:46 am    Post subject: Re: New member/ owner |
				 	  | mustangsally(at)semo.net wrote: | 	 		  How hard or challenging is to go from a nose wheel plane to the Kolb? I
 Jerry Deckard |
 Jerry,
 Most people say it is a non-issue. It is at most, a very small issue. I got a few landing in a Mark II before flying a Firestar (my first tail draggger), and it was mostly for peace of mind or confidence. It would not have been necessary. It just helped to relax me.
  _________________ John Jung
Firestar II N6163J
Surprise, AZ |
		planecrazzzy Guest
				 Posted: Sat Apr 01, 2006 8:24 am    Post subject: Re: New member/ owner |
				I don't know how much "time" you had before you were having problems
 like the ones you stated..... ( Your SCARING the guy )
  But it sounds personal....Most of us Never came close to having that
 kind of difficultly....
   To the "main Question"  - It would help a little to get some tailwheel training......?  You should give a little "forward stick"....Fly the tail ,
  and "rotate" when ready.... ( It seems to work for me )
   Or you could haul it to the Great Salt Lakes and have Plenty of room....
  He he he.... ( but watch out for those Mountains on the edges )
                Gotta Fly...
                               Mike in MN / N381PM
  	  | dhkey(at)msn.com wrote: | 	 		  Make sure you are landing into the wind for a while. Look at the far end of
  | 	  [/quote]
		Thom Riddle
				 Posted: Sat Apr 01, 2006 8:33 am    Post subject: Re: New member/ owner |
				Jerry,
 One thing that has not been mentioned is this. Try not to use the brakes too hard for stopping. The CG on most Kolbs is very close to the main gear so hard braking can put your nose on the ground. Ususally not much damage but it is embarassing. On a grass strip, unless it is really short, you should not need brakes for stopping, unless you are headed downwind. I would say that most of us have done at least one noseover in a Kolb.
 Thom in Buffalo
				 Posted: Sat Apr 01, 2006 10:13 am    Post subject: New member/ owner |
				Wow Mike(planecrazy) you're a real jackass huh?
 Yes, I'm pointing out some issues I had when I started flying my Kolb, sure
 you can say they are my personal problems. Yes it was tricky for me to make
 the adjustment to steering with the tail wheel, reminded me of steering the
 red flyer wagons as a kid. When I made small corrections it really helped.
 Maybe it was my plane, maybe it was me. I guess you have to get used to
 people not being as smart and skilled as you.
 Someday you might even aspire to go further in your training than your
 Private License.
  	  | Quote: | 	 		  From: "planecrazzzy" <planecrazzzy(at)yahoo.com>
 Subject: Re: New member/ owner
 Date: Sat,  1 Apr 2006 08:24:57 -0800
                 Gotta Fly...
                                Mike in MN / N381PM
 of
 your
 drifting
 month
 The more people I know....
 The more I like MY DOG
 .Do not archive
 http://forums.matronics.com/viewtopic.php?p=25765#25765
		Richard Pike
				 Posted: Sat Apr 01, 2006 10:16 am    Post subject: New member/ owner |
				Along with this, do not start your takeoff by firewalling the throttle
 when sitting still. When you begin your takeoff, give it about half
 throttle for a second or two until it gets up to about 15 mph before
 going to full throttle. Otherwise that high thrust line might overcome
 inertia by having your Kolb looking like a hog rooting for acorns...
 Richard Pike
 MKIII N420P (420ldPoops)
 Thom Riddle wrote:
  Jerry,
  Thom in Buffalo
  http://forums.matronics.com/viewtopic.php?p=25769#25769
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
		planecrazzzy Guest
				 Posted: Sat Apr 01, 2006 10:51 am    Post subject: Re: New member/ owner |
				Woof...
  	  | dhkey(at)msn.com wrote: | 	 		  Wow Mike(planecrazy) you're a real jackass huh?
  | 	  [/quote]
		Russ Kinne
				 Posted: Sat Apr 01, 2006 11:53 am    Post subject: New member/ owner |
				Woof not HeeHaw??
 On Apr 1, 2006, at 1:51 PM, planecrazzzy wrote:
  Woof...
  .Do not archive
  http://forums.matronics.com/viewtopic.php?p=25795#25795
				 Posted: Sat Apr 01, 2006 5:31 pm    Post subject: New member/ owner |
				I have seen a couple of nose overs on take off. Doesn't look bad just
 embarrassing.
 Jerry
		Don G
  Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
				 Posted: Sat Apr 01, 2006 7:28 pm    Post subject: Re: New member/ owner |
				Welcome Jerry Deckard...hmm  that name sounds familiar...and a challenger huh?....have you ever brought that bird up to central Illinois to any Fly-ins?
  _________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
		neilsenrmf(at)comcast.net Guest
				 Posted: Sat Apr 01, 2006 8:40 pm    Post subject: New member/ owner |
				Welcome Jerry
 You will not have any problems with the Kolb. Those of us that came from the
 GA world have had problems with landing our Kolbs because of the lack of
 inertia and lots of drag but you are used to it so it shouldn't be a
 problem. Keep your speed and power up till you are a few inches from the
 ground. As you get comfortable slowly progress to less power on approach.
 As for tail wheels it's a non issue. I had a problem once landing down wind
 on a paved strip but it was a stupid thing to do. I didn't ground loop but
 it did get exciting. Stay on grass till you're comfortable and it will not
 be a problem.
 As for going up on your nose. It can happen but common sense goes a long way
 here. One of our members, that hadn't flown yet, felt the need to build a
 monster hoop for his plane but it isn't necessary. We really tried to advise
 him that it wasn't needed but..... If you ease in the power till your
 elevators start working you will not have a problem. Again just use a bit of
 common sense.
 Rick Neilsen
 Redrive VW powered MKIIIc
				 Posted: Sun Apr 02, 2006 6:17 am    Post subject: New member/ owner |
				At 07:29 PM 4/1/06 -0600, you wrote:
 embarrassing.
 Jerry
 Jerry,
 When you see guys at EAA Chapter 453, please tell them hello.
 Jerry a member of EAA Chapter 453 in Painton, MO at the time I was in MO.
 He may have seen me put my FireFly on its nose.  It was my first take off
 from a grass strip.  I thought I pushed the throttle in the same as I had at
 Perryville, but it was too much for grass.  The wheel drag and the high
 thrust line got me.  I remember sitting there wondering what is going on.
 This thing is a shaken and quaken, the tail was up and it was not coming
 loose from the ground.  Then I felt  my self sinking and the tail starting
 to come up further on its own. I moved the stick back against the stop and
 nothing happened.  I did not get the throttle backed off in time and over I
 went on the nose.  It was a repeat of my sailplane days.  I just kept it
 straight until it came to a stop.  I had 54 miles to get home as the sun was
 going down.  So, I put my right leg out and gave a little push.  As the tail
 started to come down, I gave a little push on the throttle to keep it from
 banging.  And then I advanced the throttle slowly, made a nice lift off and
 headed on home.
 This lead to VG's, never taking off with the tail up, and always holding the
 stick back against the stop, and teasing the throttle.  I have not had a
 nose over on takeoff since the first one.  But I have nosed it over twice
 while taxiing in tall grass and adverse wind conditions.  Experience is a
 great teacher.
 Jack B. Hart FF004
 Winchester, IN
		Dave Bigelow
  Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
				 Posted: Sun Apr 02, 2006 9:18 pm    Post subject: Re: New member/ owner |
				Jerry,
 The transition to the Firestar will not be a big deal.  Taxi it around to get a feel for the steering.  On takeoff, slowly move the throttle forward to full power, and hold the stick slightly aft of neutral.  You do not need to lift the tail - just let it lift off from the three point attitude.  If your bird is 503 equipped, the take off is more like a launch than a roll.  If you are on grass, be careful advancing the throttle until your ground speed is 10-15 mph.  I haven't noticed that there is much of a nose over tendency with the Firestar unless you are holding the brakes as you run up, or are in pretty high grass.
 Landing is pretty much the same as you are used to with the Challenger.  Keep your speed up and some power on until you are within a foot or so from the ground and in the flare.  Keep flying the plane until you are stopped or at a slow taxi speed.
 You'll like your Firestar!
  _________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
