lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Thu Aug 13, 2009 3:19 pm Post subject: Re: 447 problem |
Ralph B wrote: | I've flown with the Mikuni pumps for 22 years and the only problem I've seen was when I replaced the diaphragm with one that was an aftermarket part that wasn't like the original. It ran rough and I replaced the pump. I found it had been creased and was leaking fuel out the weep hole.
If you think the single Mikuni pump is marginal, then use a dual Mikuni and tie the outputs together. This is what I have on my 447.
Never use fuel line for the pulse line. I use single-walled auto fuel line. It's very rigid and won't collapse. Some guys use pneumatic line, which is good too.
Ralph B |
The real issue with the pulse line isn't so much the sturdiness of the walls of the line (tho you generally only want to use purpose-made pulse line anyway), it's the compliance of the air column inside the line.
Air compresses as we all know, so when you have more air in the column, the easier it compresses. Because of that, less energy from the pulse output on the motor gets transmitted to the pump.
After a certain length, even if the line is made of solid steel, too much of the pulse energy gets absorbed by the air column in the line and too little is left over to drive the pump.
It's a very simple thing to overlook but such a horribly dangerous mistake to make. A foot or less always, never longer than a foot.
The single mikuni pump will work fine in virtually all normal situations with a single carb engine. For dual carb you do want the higher volume pump.
Still I always strongly preferred nothing in the vacuum end of the fuel line but a filter and that was it. No squeeze bulbs, extra pumps, etc., that can introduce drag. Once you take them out you may find you never needed them in the first place. I never had any trouble in almost 10 years of use of those pumps.
LS
_________________ LS
Titan II SS |
Posted: Thu Aug 13, 2009 5:25 pm Post subject: 447 problem |
of those pumps.
There is no way to convert years to actual time of operation of an aircraft,
or any other piece of machinery. That's why they install hour meters, or
like we did in Army Aviation, log the flight in the aircraft log book.
If I tell you I have been flying more than 40 years, that doesn't tell you
how much flight experience I have.
If you tell me you never had any trouble in almost 10 years of use of those
pumps, that could mean 10 minutes or 100 hours. Who knows?
mkIII - Flying it 17 years...and 2,980+ flight hours.
_________________ John Hauck
Titus, Alabama |
lucien
Posted: Thu Aug 13, 2009 7:08 pm Post subject: Re: 447 problem |
John Hauck wrote: |
mkIII - Flying it 17 years...and 2,980+ flight hours. |
Ok, that's it. I've told you multiple times now how much time I have with the Rotax 2-strokes and that's already too many times. You're free to believe what you want - that I have 0, 1, 5, 500 or 5000 hours. Go for it.
Regarding the advice and experience I've shared, you can verify what I've told you with any number of other experienced 2-stroke fliers. If you think everything I'm telling you is crap, then I'm done telling it to you. Feel free to get your 2-stroke experience and advice elsewhere. I'll take mine elsewhere also.
I'm done with you, and done with the list.
LS
Titan II SS |
Posted: Thu Aug 13, 2009 7:28 pm Post subject: 447 problem |
those
Quote: | > pumps, that could mean 10 minutes or 100 hours. Who knows?
> john h
them and that's already too many times. You're free to believe what you
LS
No one is questioning your experience, but 10 years is not relative when it
comes to operating an engine. If you want to impress the Kolb List with
your experience, then you need to express it in hours, not years.
I have no desire to verify your experience, but it would help if you express
it so we can understand it.
Titus, Alabama |
Ralph B
Posted: Thu Aug 13, 2009 7:28 pm Post subject: Re: 447 problem |
Lucien, please don't leave as you add quite a bit to this list.
John H may have been referring to me as I say that I have 22 years flying, but have not listed my hours.
Ralph B
22 years flying
960 hours
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
aoldman(at)xtra.co.nz Guest
Posted: Thu Aug 13, 2009 11:34 pm Post subject: 447 problem |
Boys do not throw the toys out of the cot. You are all very interesting folk
and contribute a lot. Your input may just save someones butt" if it has not
already done so" I only have 400hrs with 447 and 503s and have all the
nastys like outboard prime bulbs , by passes and such, and while I respect
the opinion of those that oppose these things ,they have served me well.The
reasons they are not considered good practice do focus me some what when
doing pre flight checks, so while I still use these things ,the reasons not
to, put on this list have at least brought there failings to my attention
and I am now better informed and operate accordingly.Being prepared and for
warned is a good thing.
4 or 40,000 hours we are still all learning . keep the information flowing .
In this way the Kolbs we all on this list love to fly will serve us well for
many years to come.
Downunder
MK111c
300hrs in Kolbs
Some more hrs in other things { stay safe up there }
As my instructor used to say "in god we trust, everything else we check
twice"
pj.ladd(at)btinternet.com Guest
Posted: Fri Aug 14, 2009 1:09 am Post subject: 447 problem |
Hi Tony Oldman,
Is `down under` Oz or NZ? If in NZ, where are you?
I have taken a house on the beach in Russel in the Bay of Islands for all of
Feb next year and if you happen to be in that area I would like to make
contact.
Cheers
Pat in the UK
Posted: Fri Aug 14, 2009 1:55 am Post subject: 447 problem |
NZ ,South Island ,Timaru. You will like Russel. NZs first capital. Treaty of
Waitangi [ our founding document } was signed not far from Russel. We are
still trying to work out what it actualy means. Keeps lawyers and
politicians gainfully employed . If you find you way this far South I will
definatly take the time to meet up . Feb will be a all on month.Boating on
lake Benmore and vintage car stuff to do ,can always fit some Kolb flying in
as well.
Tony
aslsa.rng(at)gmail.com Guest
Posted: Fri Aug 14, 2009 2:39 am Post subject: 447 problem |
As Marx said, " I wouldn't belong to any group that would have me as a member". Groucho, that is, and loosely quoted at that.
Rick Girard
On Thu, Aug 13, 2009 at 10:08 PM, lucien <lstavenhagen(at)hotmail.com (lstavenhagen(at)hotmail.com)> wrote:
[quote] --> Kolb-List message posted by: "lucien" <lstavenhagen(at)hotmail.com (lstavenhagen(at)hotmail.com)>
> john h
Ok, that's it. I've told you multiple times now how much time I have with them and that's already too many times. You're free to believe what you want - that I have 0, 1, 5, 500 or 5000 hours. Go for it.
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=257605#257605
le, List Admin.
Posted: Fri Aug 14, 2009 3:25 am Post subject: 447 problem |
Hi Tony,
We have been to NZ four or five times touring. Flown gliders at Omarama.
Flown out of Queenstown to Milford Sound. Been to Wanaka, unfortunately not
during the Wings over Wanaka but I had a look around the workshops there.
This time, and I think I am getting to old to make another long distance
trip, we decided to stay in one place. If I could put the clock back I
would have emigrated to NZ 40 years ago.
Cheers
Pat
russ(at)rkiphoto.com Guest
Posted: Fri Aug 14, 2009 5:13 am Post subject: 447 problem |
Lucien, I've enjoyed reading your comments, and profited from them
too. I'd be very sorry to see an experienced pilot like yourself go,
as would many others on the List. Your inputs have always been well-
informed, well thought out, good, and valuable (and I can't say that
for some of the others posted). No one's challenging your information.
John only pointed out that "years of operation" really doesn't tell
us much, whereas "hours of operation" would be a good yardstick.
I'm sure no insult was intended. Can't you be a little patient with us?
Russ K
not-yet-Kolber
On Aug 13, 2009, at 11:08 PM, lucien wrote:
Quote: |
> of those
> john h
for it.
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p 57605#257605
by0ung(at)brigham.net Guest
Posted: Fri Aug 14, 2009 7:25 am Post subject: 447 problem |
The other thing I would do is buy a really good fuel filter like this 10 micron stainless steel filter from Aircraft Spruce.
http://www.aircraftspruce.com/catalog/appages/micron10.php
Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>.
To put things in perspective,,,, been told that cigarette smoke is 4 microns.
Boyd Young
Blumax008(at)aol.com Guest
Posted: Fri Aug 14, 2009 9:05 am Post subject: 447 problem |
In a message dated 8/14/2009 11:26:23 A.M. Eastern Daylight Time, by0ung(at)brigham.net writes:
Quote: | The other thing I would do is buy a really good fuel filter like this 10 micron stainless steel filter from Aircraft Spruce.
This award winning high performance billet, stainless steel, washable and reusable Filter is USA made, high performance billet, stainless steel, washable and reusable superb flow filters. For those who want and appreciate quality, these high performance billet, stainless steel, washable and reusable filter will take you to the highest level of filtration performance.
Let me get this straight once & for all...ARE THEY ABSOLUTELY SURE THAT IT'S A...
"high performance billet, stainless steel, washable & reusuable?"
...by the way, what the hell is a billet?...
Posted: Fri Aug 14, 2009 9:33 am Post subject: 447 problem |
A billet is a solid block of metal. You machine away anything that doesn't look like the finished product.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Posted: Fri Aug 14, 2009 9:34 am Post subject: 447 problem |
A billet is a small bill.do not archive
On Aug 14, 2009, at 1:01 PM, Blumax008(at)aol.com (Blumax008(at)aol.com) wrote:
[quote] In a message dated 8/14/2009 11:26:23 A.M. Eastern Daylight Time, by0ung(at)brigham.net (by0ung(at)brigham.net) writes:
Quote: |
| [b]
Posted: Fri Aug 14, 2009 11:43 am Post subject: 447 problem |
Russ!
You beat me to it!!!
Mike Welch
Subject: Re: Re: 447 problem
Date: Fri C 14 Aug 2009 13:31:21 -0400
A billet is a small bill. do not archive
On Aug 14 C 2009 C at 1:01 PM C Blumax008(at)aol.com (Blumax008(at)aol.com) wrote:
Quote: | In a message dated 8/14/2009 11:26:23 A.M. Eastern Daylight Time C by0ung(at)brigham.net (by0ung(at)brigham.net) writes:
This award winning high performance billet C stainless steel C washable and reusable Filter is USA made C high performance billet C stainless steel C washable and reusable superb flow filters. For those who want and appreciate quality C these high performance billet C stainless steel C washable and reusable filter will take you to the highest level of filtration performance.
"high performance billet C stainless steel C washable & reusuable?"
...by the way C what the hell is a billet?...
Quote: |
ttp://www.matronics.com/Navigator?Kolb-List
ronics.com
ww.matronics.com/contribution
| Express your personality in color! Preview and select themes for Hotmail®. Try it now. [quote][b]
Posted: Fri Aug 14, 2009 12:11 pm Post subject: 447 problem |
At 08:56 AM 8/14/09 -0400, you wrote:
>> of those
>> john h
Still waiting for the first mikuni pulse pump failure after flying with one
for 267+ hours. I believe I am correct in that John's engine on his MKIII
does not use a mikuni pulse pump so the year and flight hour totals he lists
do not mean much to this discussion.
Jack B. Hart FF004
Winchester, IN
Posted: Fri Aug 14, 2009 1:13 pm Post subject: 447 problem |
one
Quote: | for 267+ hours. I believe I am correct in that John's engine on his MKIII
lists
Jack B. Hart FF004
Jack H:
The time in my signature block has was not intended to add anything to this
discussion. However, had I only listed the years flown, that information
would tell the reader absolute nothing about how long this airplane had been
flying, other than it first flew 17 years ago.
Was trying to get Lucien S to express experience with Mikuni fuel pumps in
hours, rather than years. Gives me a better understanding of "use" and
expected length of reliability. He may fly 100 hours or 1000 hours in 10
years. Hell, I don't know.
I used single and double Mikunis on ULII02, 447, and 582, on my own Kolb
aircraft, and have flown other factory aircraft a bit. My time in my own
Kolb powered two strokes was a little over 1,300 hours. I only had a Mikuni
fuel pump problem once in all that time, between 1984 and 1993. I bought a
rebuild kit to carry with me on my flight to New England and Oshkosh in
1989. When I got to the Flight Farm at Monterey, NY, I decided to put the
new diaphragm in because I would be flying in some bad country doing the New
England States, and across Niagara Falls for the second year. Next flight I
had an engine failure. Dug the old diaphragm out of the garbage can and
reinstalled it. Made the rest of the flight to Oshkosh and back to Alabama
on the old one. Leaf would not reimburse me for the cost of the kit. It
was an after market no name kit from some unknown country. I assumed it was
a Mikuni part. Live and learn. Last item I bought from LEAF.
I've pulled fuel with Mikunis a pretty good distance. As far away as the
bottom of a Ken Brock seat tank in my Firestar. Was also a good pull from
the Ultrastar tanks under my knees to the pump behind my head on top of the
engine.
As far a Mikuni pulse pump, the UL/Lt Plane market is a very small piece of
their market. I have a 35 year old Kubota diesel tractor that uses a Mikuni
pulse pump that has been pumping for the last 35 years and more than 2500
hours. Never even think about it. Would be afraid to look at it now.
Reliability, to me, of a Mikuni pulse pump is phenomenal. Probably one of
the best systems available.
mkIII - Sitting in the hanger collecting barn dust and bug/bird crap.
Titus, Alabama |
JetPilot
Posted: Fri Aug 14, 2009 1:17 pm Post subject: Re: 447 problem |
Hit Button Twice, read below...
Kolb MK-III Xtra, 912-S
JetPilot
Posted: Fri Aug 14, 2009 1:18 pm Post subject: Re: 447 problem |
russ(at)rkiphoto.com wrote: |
The description is pretty self explanatory
Billet = Billet refers to a cast semi finished product. It is also referred to as ingot, particularly for smaller sizes. A billet is typically cast to a rectangular, hexagonal or round cross section compatible with secondary processing, e.g. forging or milling. It can be produced either as coil or cut lengths. Ingots and billets are collectively known as bar stock.
The filter case starts life as a billet piece of aluminum, and is machined to the proper shape. The aluminum filter Never breaks, cracks, or get soft due to ethanol or water. Stainless Steel mesh element also impervious to ethanol and water, and does a much better job of filtering than Paper for fiber ever will. I have two of these filters in two airplanes, my carb bowls are always so clean I could drink wine out of them if I wanted to
The filter is expensive at 80 dollars, but its not as expensive as having an engine failure and off field landing with aircraft damage due to clogged or faulty cheap filter that can fail in any number of ways...
Kolb MK-III Xtra, 912-S |
