Why3 different alt disconnect relay wiring in Z schematics
PostPosted: Thu Aug 13, 2009 3:32 pm    Post subject: Why3 different alt disconnect relay wiring in Z schematics Reply with quote
At 12:02 PM 8/13/2009, you wrote:
Here are the links to the schematics:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z16M.pdf
The preferred methodology for PM alernator control assuming
you're NOT depending on the AC output waveform to drive
an engine tachometer as shown in . . .
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z20L.pdf
where we see the AC windings permanently connected
to the rectifier/regulator. Here, alternator control reverts
to the older philosophy of opening the DC power output
lead from the R/R. Z20L.pdf had been plotted but not uploaded
to the server. Z20K.dwg was still up and needed deletion.
Must have been one of those late night deals . . .
Note that Z-21 was a special adaptation to accommodate
electronic controlled fuel injection . . .
further, it suggests a means by which alternator control
relay power to energize can come from either the battery
or the alternator.
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z21A.pdf
Any of these drawings will perform as advertised and should
be applied pending a match of your design goals and installed
equipment with the matching Z-figure.
( -Thomas Paine 1776- )
messydeer
PostPosted: Fri Aug 14, 2009 12:58 pm    Post subject: Re: Why3 different alt disconnect relay wiring in Z schema Reply with quote
Thanks, Bob Smile
The preferred methodology for PM alernator control...
I understand that you prefer this method, but I don't know why.
Are you saying it's better to place the alt disconnect AFTER the regulator (as in Z-20 and Z-21) than BETWEEN the alternator and regulator (as in Z-16)? I had heard disconnecting a PM regulator wired with the relay after the the regulator could damage the regulator. You would want a failed regulator disconnected, but what would happen if a good regulator were taken offline?
Also, if the regulator fails and is taken offline by a relay placed after the regulator, could the failed regulator present a fire hazard by continuing to heat up from the uninterrupted supply of power to it from the alternator? If so, could a relay placed between the alternator and regulator, instead of after the regulator, cut the power to the failed regulator and prevent this?
...assuming you're NOT depending on the AC output waveform to drive
I don't know if I need the AC waveform for the tach or not. The Jabiru manual shows a magnetic sensor plugged into a tach sensor tab on the engine. 2 leads go from there to the tach gauge on the panel. I don't know if I have this sensor or sendor.
If I don't have it or can't get it, then I suppose I would need to use one of the alternator AC leads. Is one method preffered over the other?
And Z-20L shows a wire spliced into one of the alternator output leads going to the tach. So if I do need an AC lead, why wouldn't this work in Z-20L?
... Z-21 . . . suggests a means by which alternator control
or the alternator.
I don't understand how this works and why this is an advantage.
Dan
PostPosted: Fri Aug 14, 2009 5:10 pm    Post subject: Why3 different alt disconnect relay wiring in Z schematics Reply with quote
At 03:58 PM 8/14/2009, you wrote:
Thanks, Bob Smile
Because it totally removes the alternator's ability
to deliver power by breaking the AC output power
leads. Breaking the DC power output lead will not
allow you to disconnect the alternator from a shorted
rectifier regulator thus putting the alternator at-risk
for second-failure follwing a regulator failure.
No, directly in the AC output lead . . . but if
your tachometer depends on the AC frequency
signature of the alternator for measuring
engine speed, then you can't put the disconnect
at the preferred point.
Some regulators may indeed be at risk if the system
is operating unloaded . . . but I doubt it. It's
a voltage rating issue for the semiconductors inside
the regulator. It's not a big deal to craft a rectifier
regulator tolerant of unloaded, full speed operations.
The two designs for PM regulators that I participated
in were NOT at risk for no-load, hi-speed ops.
If the regulator is designed to live in the world
to which it's sold, then it shouldn't be a problem.
It's easy to do, it's what we did, but I can't speak
for others. Disconnecting the AC input lead is, therefore,
the preferred, low-risk philosophy for ALL regulators.
No fire risk. You might burn some alternator wires
but this isn't inherently hazardous beyond damage
to the alternator itself. If your tachometer doesn't
require a signal from the alternator, go with Z-16.
messydeer
PostPosted: Fri Aug 14, 2009 6:22 pm    Post subject: Re: Why3 different alt disconnect relay wiring in Z schema Reply with quote
an engine tachometer as shown in http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z20L.pdf where we see the AC windings permanently connected
lead from the R/R.
....Thanks, Bob
I understand that you prefer this method, but I don't know why.......
......Because it totally removes the alternator's ability
to deliver power by breaking the AC output power leads.
Dan
messydeer
PostPosted: Fri Aug 14, 2009 6:35 pm    Post subject: Re: Why3 different alt disconnect relay wiring in Z schema Reply with quote
lead from the R/R.
....Thanks, Bob
Sorry about double posting. Meant to hit the preview button Sad
It seemed to me you were saying the Z-20 method of breaking the DC leads was best, but now I see you mean breaking AC is best, like in Z-16.
So even if I ran the tachometer off the AC leads, I'd only have no tach when the alternator is offline. I haven't seen the tachometer show up on anybody's Ebus list, so going with the preferred AC disconnect might be better even in this situation.
Dan
