Brad Stump
Goto page Previous  1, 2, 3  Next
PostPosted: Fri Aug 14, 2009 5:33 pm    Post subject: Brad Stump Reply with quote
> John H, have you ever spun the MK III ? How many turns and what is it
like ? I have seen Possums videos of spins in his Firestar, but the MK III
being much heavier may be totally different in a spin.
Mike
Mike B:
I have no problem spinning my mkIII. Spins just like the Firestar and
Ultrastar, but loses a little more altitude. They all like to spin nose
low, almost a spiral.
jlsk1(at)frontiernet.net
PostPosted: Fri Aug 14, 2009 5:34 pm    Post subject: Brad Stump Reply with quote
I`ve been lurking on this topic all week,,,, the common thread seems to be
the witness report, & now, it is part of the official investigation prelim.
Hard to disput the statement. Yes, witness reports can be misleading, but if
I, or any pilot I know of, was having a control problem, managed to get the
airplane going straight up,,,,,-, three times,,,,,,, would not have gotten
to the third time before I shut down the power & pulled the red handle, if I
was that out of control.
I have spent 3 or 4 hours with Brad, & had no clue that as a pilot, might
have been pushing the envelope. But that was also before his 1st flight in
his plane.
Think about this, 2 times, the plane was going straight up. Then a third.
If you were "out of control", those 1st 2 times, with a passenger, would
you have let it gone to that third time,,,, straight up, with a BRS???
Lets let this go,,, Please.
Jim Kmet
Obviously affected
MK-3C 912
Cookeville, TN.
JetPilot
PostPosted: Fri Aug 14, 2009 7:59 pm    Post subject: Re: Brad Stump Reply with quote
Jim,
As a community it is important for us to do our best to understand this and every Kolb accident so that others can avoid the same fate. In any accident involving aviation, an investigation and this kind of discussion takes place and rightfully so, it saves lives. Given that you knew Brad makes it harder, but this is part of the process. My uncle was recently killed in a Sailplane setting an altitude record, and everyone in his sailplane club, including his family did all we could to assist in the accident investigation and to figure out what caused the accident so that others flying sailplanes would not suffer the same fate. My uncle Dave was a very smart and nice guy that cared for his fellow flyers, I know without a doubt that he would have wanted us to figure out what happened and advise the flying community, as I am sure most pilots would.
Mike
Kolb MK-III Xtra, 912-S
pj.ladd(at)btinternet.com
PostPosted: Sat Aug 15, 2009 3:35 am    Post subject: Brad Stump Reply with quote
maneuver sounds to me like a hammerhead stall. >>
Dont you have any restrictions on airobatics in our sort of planes in the
US.
Strictly illegal here. Not to say it is never done of course
Pat
russ(at)rkiphoto.com
PostPosted: Sat Aug 15, 2009 4:23 am    Post subject: Brad Stump Reply with quote
Pat
Some GA aircraft here are placarded "Intentional spins prohibited" --
apparently accidental ones are permitted!
We have more stringent regs in a control zone, near an airport, than
in controlled airspace. Many of the restrictions are laid on by the
manufacturer.
I'm sure a current CFI will let us know the current regs. Hope so.
Russ
in the US.
Pat
aslsa.rng(at)gmail.com
PostPosted: Sat Aug 15, 2009 5:42 am    Post subject: Brad Stump Reply with quote
Pat, Yes, unless the aircraft is spec'd as an aerobatic aircraft, item 17 in the operating limitations forbids aerobatics.
17) This aircraft is prohibited from aerobatic flight, that is, an intentional maneuver involving an abrupt change in the aircraft's attitude,an abnormal attitude, or acceleration not necessary for normal flight.
Hard to imagine how it could be any clearer.
Rick Girard
On Sat, Aug 15, 2009 at 6:19 AM, pj.ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote]--> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
Dont you have any restrictions on airobatics in our sort of planes in the US.
Pat
http://forums.matronics.com
le, List Admin.
dalewhelan
PostPosted: Sat Aug 15, 2009 9:06 am    Post subject: Re: Brad Stump Reply with quote
I am not interested in spinning my Firestar as I have no spin training. I plan to get some.
Is the spin recovery technique the same for a Firestar and a tractor?
Specifically, power off?
Dale Whelan
503 powered Firestar II, Luscombe 8A
Projection, A simple and interesting Psychological concept
zeprep251(at)aol.com
PostPosted: Sat Aug 15, 2009 11:13 am    Post subject: Brad Stump Reply with quote
Dale,
No.The spin recovery technique for my John Deere is very different--------.Sorry,the spin recovery techniques sometimes differ because some aircraft require power addition for recovery,but for most, forward stick and opposite rudder until rotation stops and flying speed is obtained are pretty much standard. Now that I'm out here on this limb someone may want to saw it off.
G.Aman MK-3C
slyck(at)frontiernet.net
you will have to ask John H if he has spun one of his John Deeres.
BB
On 15, Aug 2009, at 1:06 PM, dalewhelan wrote:
<dalewhelan(at)earthlink.net>
Dale Whelan
http://forums.matronics.com/viewtopic.php?p 57810#257810
PostPosted: Sat Aug 15, 2009 11:24 am    Post subject: Brad Stump Reply with quote
Mike,
I still think we have not enough info to make a judgment.My first thought was an uncommanded up elevator condition, just the opposite from yours,so it's still hard to say.The Feds say "loss of control".That still does not answer the big question,WHY.
G.Aman MK-3-C
PostPosted: Sat Aug 15, 2009 11:28 am    Post subject: Brad Stump Reply with quote
Bet he has,at very low altitude and never with power off.
PostPosted: Sat Aug 15, 2009 11:40 am    Post subject: Brad Stump Reply with quote
BB
Bob B:
Yep, they are both pushers.
No problem with low altitude with the 1937 JD B. MKIII is another ball
game.
JetPilot
PostPosted: Sat Aug 15, 2009 11:54 am    Post subject: Re: Brad Stump Reply with quote
zeprep251(at)aol.com wrote:
Mike,
G.Aman MK-3-C
I did seriously consider uncomanded pitch up at first, that is why I was so reluctant to make the assumption that Brad was doing aerobatics after reading the news report, and obvious lack of knowledge by the witness.
What really changes things is when the NTSB reports that the plane had " Leveled Off " three times before the last maneuver. In an uncommanded pitch up, the airplane might pass through level a couple times, but " Level Off " very clearly means what it says, the plane was obviously under control three different times in this episode. I now have to go with the hammerhead stall and spin assumption at this point.
Dana wrote:
At 11:54 AM 8/13/2009,
Not if they're talking to a non pilot reporter... but somewhere I read that
in accident investigation, a pilot may be the worst witness... because
their perception is influenced by that they think is happening. Accident
investigators say that a video camera, naturally, is the best witness. An
intelligent child is second best, because they describe what they see
without trying to interpret it. A non pilot adult is third, and a pilot is
the worst.
I do take strong issue with this statement. If I was letting a person fly my plane and wanted to know how he was flying and if he was abusing the airplane or not, I could send someone out to the airport or the practice area to watch my airplane being flown from the ground and have them and report back to me. If I were to do this, I would most definitely send a qualified pilot do this, not some woman that had never flown an airplane before, or even less likely a kid. Any of you would really rather have a soccer mom tell you how your airplane was going flown than a qualified pilot ? Loss of control or intentional aerobatics, a experienced pilot would definitely be MUCH better able to tell the difference between the two rather than some woman or kid that knew nothing about flying.
The statement above may sound appealing on some level, but when one really thinks about it , its total garbage. If John Hauck, myself, or any of a number of qualified pilots here had witnessed this accident, we would be a LOT more likely to give an accurate account of what happened rather than this witness saw the crash but knows nothing.
Mike
PostPosted: Sat Aug 15, 2009 2:55 pm    Post subject: Brad Stump Reply with quote
There is an alternative possibility: Brad may have simply been
demonstrating departure stalls. The non-aviation oriented
witness could easily get the impression that he was attempting to go
"straight up"
After two, in which obviously it would appear that he was leveling
off, he went for number three. (that's the part I can't figure)
A very tall departure stall with the rudder kicked can do
unpredictable things unless you have done the same thing MANY times
in exactly the same way.
It can fall off one one wing with the result dependent upon elevator
position.
Up elevator, exaggerated inverted spin entry. Usually won't
initially go on its back but flop so quickly that the nose goes
beyond center,
giving you the sensation that you are going to somersault. Loose
stuff flies around cabin.
Elevator neutralized just ahead of stall. (still at full power)
Plane SHOULD mush and nose fall through with normal recovery.
If the angle is too steep a certain amount of vertical fall will have
to happen before the nose falls
Worst case is tail slide. Up elevator should be maintained to go to
go right side up. Cut power. The right point for repowering is a
question
because all my experience in unusual positions is tractor.
We will never know for sure. I recommend that Kolbs be used for what
they were intended, casual rides for the geriatric.
BB
> Mike,
> G.Aman MK-3-C
> read that
> because
> Accident
> witness. An
> pilot is
> the worst.
about flying.
knows nothing.
Mike
&quot;NO FEAR&quot; - If you have no fear you did not go as fast
as you could have !!!
http://forums.matronics.com/viewtopic.php?p 57840#257840
Dana
PostPosted: Tue Aug 18, 2009 3:03 pm    Post subject: Brad Stump Reply with quote
Here you can generally do aerobatics unless prohibited by the aircraft's
operating limitations. Most manufacturers nowadays issue a blanket
statement like "no acrobatic maneuvers permitted except the
following:...). For a homebuilt, the builder can specify (or not specify)
anything he likes and tests for during the flight test phase. Of course
there are other restrictions like minimum altitudes, no acro over congested
areas or on airways, parachutes must be worn unless flying solo, etc.
-Dana
When you were born, you cried and the world rejoiced...
Live your life so that when you die, the world cries and you rejoice.
-- Cherokee saying
Dana
Rick, that applies to aircraft certificated as LSA. For
experimental-amateur built, it's whatever the builder safely demonstrates
-Dana
-- Cherokee saying
PostPosted: Wed Aug 19, 2009 7:15 am    Post subject: Brad Stump Reply with quote
Dana, Per my original response:
From FAA AC 8130.2F change 3 (current version)
153. ISSUANCE OF EXPERIMENTAL AMATEUR-BUILT OPERATING LIMITATIONS.
(15) This aircraft is prohibited from aerobatic flight, that is, an intentional maneuver involving
an abrupt change in the aircraft’s attitude, an abnormal attitude, or abnormal acceleration not necessary
for normal flight.
NOTE: If the builder states that the aircraft is capable of aerobatic flight,
limitation 16 will be used in lieu of limitation 15.
(16) This aircraft may conduct aerobatic flight in accordance with the provisions of § 91.303.
Aerobatics must not be attempted until sufficient flight experience has been gained to establish that the
aircraft is satisfactorily controllable and in compliance with § 91.319(b). The aircraft may only conduct
those aerobatic flight maneuvers that have been satisfactorily accomplished during flight testing
and recorded in the aircraft maintenance records by use of the following, or a similarly worded,
statement: “I certify that the following aerobatic maneuvers have been test flown and that the
aircraft is controllable throughout the maneuvers’ normal range of speeds, and is safe for
operation. The flight-tested aerobatic maneuvers are _________, _________, __________,
and __________.”
I apologize for getting the number of the limitation wrong between E-LSA and E-AB, but the gist of my statement is true, the aircraft must be spec'd for aerobatic flight as per the above.
Rick
On Tue, Aug 18, 2009 at 5:54 PM, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote:
[quote]--> Kolb-List message posted by: Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
Rick, that applies to aircraft certificated as LSA.  For experimental-amateur built, it's whatever the builder safely demonstrates during the flight test phase.
-Dana
-- Cherokee saying
le, List Admin.
Dana
PostPosted: Wed Aug 19, 2009 9:04 am    Post subject: Brad Stump Reply with quote
<regs snipped>
..but the gist of my statement is true, the aircraft must be spec'd for aerobatic flight as per the above.
Understood, and correct. My point was that in the US, if the builder chooses to do (and test for) aerobatics, he can do so, and the operating limitations will then permit them. This is very different from the UK, where (as I understand it) you can only build from an approved design, and no deviation from the original approved design or operating limitations is permissible.
I guess that applies to aerobatics as well as fuel filters. Smile
-Dana
"640K of computer memory ought to be enough for anybody." - Bill Gates, 1981 [quote][b]
PostPosted: Mon Aug 24, 2009 7:15 am    Post subject: Brad Stump Reply with quote
the UK,
permissible.>>
Hi Dana,
The first part is certainly correct. You can only buy a kit or completed a/c if it conforms to `Section S` Approval will only be granted after it has been passed by British Microlight Assoc. or Light Aircraft Assoc who hold delegated powers from the CAA.
This sometimes means that a/c which are used the world over need some changes to fly here. The Kolb 3Xtra for instance would not have been approved with the Jabiru without VG`s fitted.
If you want to change something markedly, new prop/engine combination, altering dihedral, cutting a couple of feet off the wings then you can put your proposal to the LAA or BMA and their engineering division will look at it. They may suggest a better way of achieving what you want, tell you it has been tried and it produced a cranky or non conforming a/c. They will often do engineering analysis of your suggestion but their decision is final.
The authorities are not unreasonable and are generally helpful but if they say don`t do it, listen.
We have recently introduced a very light category and under that regime you can do more or less what you like. Desigh, alter etc.,. Anything as long as its below the specified weight.
Cheers
Pat
Steamin
PostPosted: Sat Oct 17, 2009 5:39 pm    Post subject: Re: Brad Stump Reply with quote
Hi. I was a co worker with Brad. His loss has left a hole in many lives.
Since this forum is dedicated to pilot safety, I feel compelled to add to the above discussion that, the BRS chute entanglement was most certainly, at least to me, caused by the fact the rocket never fired. First responders weren't able to get near the crash until the rocket was fired.
Page 2 of 3
