		aerosport1
				 Posted: Sat Aug 15, 2009 6:05 am    Post subject: Alternator belt alignment |
				I was putting on my alternator today and find that the belt is misaligned
 by about 1/3 of the belt width to the belt groove on the engine. I have a Aerosport engine and the stock PLane Power alternator has any one else seen this problem? Or is this standard and leave it alone. I would think they need to be perfectly
 aligned.
 Geoff
  _________________ Geoff Combs
 RV-10 QB N829GW
Flying 500 hrs
40033 |
		greghale
  Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
				 Posted: Sat Aug 15, 2009 6:23 am    Post subject: Re: Alternator belt alignment |
				My Plane Power alternator pulley did not align with th ring gear pulley groove.  I swapped ends with the alternator bracket and that corrected the problem.  I did however have to make new spacers on the bracket to hold the alternator in position.  I am using the dual groove ring gear for the air conditioning compressor.
 Greg...
  _________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
		aerosport1
				 Posted: Sat Aug 15, 2009 10:05 am    Post subject: Alternator belt alignment |
				Mystery is solved. I some how had turned the ring gear pulley groove plate
 one stud off and was just hand tighten it. Once I got it holes in the
 correct alignment everything was good. All is good and prop is on.
 Thanks Geoff
 Geoff Combs
 President
 Aerosport Modeling & Design
 8090 Howe Industrial Parkway
 Canal Winchester, Ohio 43110
 614-834-5227p
 614-834-5230f
 www.aerosportmodeling.com
 RV-10 QB N829GW
Flying 500 hrs
40033 |
