Calibrating fuel qty gauges
Goto page Previous  1, 2, 3, 4
Eric M. Jones
PostPosted: Sat Aug 15, 2009 6:43 am    Post subject: Re: Calibrating fuel qty gauges Reply with quote
I have seen all sort of fuel gauges, and I don't know what is best....
But I want to add a note to the discussion that might spur some thinking:
Video cameras have become soooooo cheap that using one to directly image the inside of a tank is becoming a practical solution.
When I consider "things I would like to know", I often imagine visualizing them. So I can imagine a conical piece of acrylic in the fuel tank with a couple LEDs and a tiny video camera looking down the axis as a practical solution, or a video camera looking at a calibrated stick inside the tank.
Although you could image these directly on a small display, you could also write some simple imaging software to turn these video images into a displayed number of gallons.
For those interested in the basic subject, search the USPTO patents site (advanced search) and enter search string "ttl/(fuel and level and sensor)"
When the Oakies left Oklahoma and moved to California,
it raised the I.Q. of both states." --Will Rogers
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
BobsV35B(at)aol.com
PostPosted: Sat Aug 15, 2009 7:09 am    Post subject: Calibrating fuel qty gauges Reply with quote
Good Morning Ken,
That sounds great!
Reminds me of a device that was common in the thirties and early forties. There would be a standpipe in the fuel tank that fed fuel above a predetermined amount via the MAIN position of the fuel valve. When switched to the RESERVE position, the fuel was taken from the bottom of the tank.
I had a PT-22 that was so equipped. When the tank ran dry on MAIN, there was precisely five gallons (thirty plus minutes of fuel) left that was available via the RESERVE position. All takeoffs and landings were to be performed with the fuel valve selected to the RESERVE position.
Worked great as long as you remembered to select the RESERVE for T/O & Ldg.
The early Volkswagen had a similar setup that made the last gallon or so of fuel available to the engine. No fuel gauge at all in the VW as I recall..
Happy Skies,
Old Bob
In a message dated 8/15/2009 7:40:03 A.M. Central Daylight Time, klehman(at)albedo.net writes:
--> AeroElectric-List message posted by: Ken <klehman(at)albedo.net>
There are simple ways of achieving some of these goals in some aircraft.
I have a two gallon gravity fed vented header tank which is also a great
gascolator. A low cost float switch (from aircraft spruce) triggers a
large two color flashing LED if it is not full, which means it gets
quiet in 20 min. for me unless I switch tanks or land as appropriate. No
sloshing effects in a full header tank. No concerns about air bubbles,
unuseable fuel, or maneuvering with low fuel in the main tanks. It has a
press to test button for no good reason other than it makes me feel good.
The sight gauges in my wing tanks are damped with a restriction and
calibrated in blue on the forward side for flight and in red on the rear
side for ground (tail dragger). Certainly not foolproof but surprisingly
accurate for confirming fuel remaining agrees with what I estimate
should be there. Certainly accurate to within one gallon in my 24 gallon
wing tanks although I don't remember looking at them when in head
bumping seat belt tugging turbulence. They also verify how much fuel is
added to the tanks quite accurately. Even parked on a slight left to
right slope, the error in one tank tends to be cancelled out by the
error in the other tank. Clear teflon sight gauges are shatter proof and
will last forever regardless of what fuel one uses.
Ken
At 01:14 PM 8/14/2009, you wrote:
> Geek, Nerd, or Ernest,
> I'm surprised you are willing to accept the poor excuse for fuel
> measurement we've had for the past 60 years. With your skills, I
> would have expected you to jump on this challenge and solve it.
> There must be a solution.
Design goals for the system I'm working on now include
in-situ calibration at intervals equal to 5% of full
capacity. So an accuracy on the order of 2% of tank
capacity seems achievable. But even if it becomes
a product on either the TC or OBAM side of the house,
I'd still be reluctant to recommend that anyone plan
a flight that draws a tank down to less than 30 minutes
total fuel aboard.
Bob McC
PostPosted: Sat Aug 15, 2009 7:52 am    Post subject: Calibrating fuel qty gauges Reply with quote
Bob;
This “standpipe” reserve system with a dual position valve is also quite common to many motorcycles. Works very well, BUT----, The biggest drawback I’ve found to this as applied to VW’s or bikes or whatever, is that when you stop to refuel after having selected “reserve” is that you MUST remember to return the valve to the “main” position lest the next time you run “low” you’re actually completely dry as you were already on “reserve”. (Ran out of fuel on my Honda 500 Interceptor more than once for just this reason.)
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Saturday, August 15, 2009 11:06 AM
Subject: Re: AeroElectric-List: Calibrating fuel qty gauges
Good Morning Ken,
That sounds great!
Happy Skies,
Old Bob
Bob McC
Falco #908
(just starting)
BobsV35B(at)aol.com
PostPosted: Sat Aug 15, 2009 8:17 am    Post subject: Calibrating fuel qty gauges Reply with quote
Good Morning Bob McC,
No doubt about it!
Every "improvement" adds another point where failure could occur!
The simplest fuel system possible would have one tank, no valves and no filters.
Lindbergh wanted many small tanks because he had experienced so many fuel tank leaks.
'Tis a quandary Indeed.
Happy Skies,
Old Bob
In a message dated 8/15/2009 10:53:36 A.M. Central Daylight Time, robert.mccallum2(at)sympatico.ca writes:
Bob;
Bob McC
Good Morning Ken,
That sounds great!
Happy Skies,
Old Bob
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
phillip.johnson(at)lmco.c
PostPosted: Mon Aug 17, 2009 6:02 am    Post subject: Calibrating fuel qty gauges Reply with quote
Was Said>
The Princeton Capacitance Sensors I bought and connected to the AF-3400 EM do not work. I've calibrated them 7 times and they still fluctuate between full and 8 gallons when the tanks are full and fluctuate wildly when less than full. Perhaps I've done something wrong in the calibration - I know most errors are installation or operator errors - but, I tried to follow the AF-3400 instructions accurately.<end
When I installed my capacitance senders I seem to remember having to drill a small hole at the highest point so that the fuel could drain back down the tube as necessary. It is possible that you have entrapped fuel in the tube that is being held there and needs to be released by a small vent.
Phillip Johnson
Speedy11(at)aol.com
PostPosted: Tue Aug 18, 2009 5:13 pm    Post subject: Calibrating fuel qty gauges Reply with quote
Phillip,
Thanks for your response.
Your idea may be correct. Not having the vent hole would cause a problem. As I recall, the Princeton senders did have a small (maybe a #40) hole drilled in the side to allow flow. But, I will check photos to see if that is correct.
Thanks for the idea.
Stan Sutterfield
Was Said>
small vent.
Phillip Johnson
PostPosted: Wed Aug 19, 2009 4:14 am    Post subject: Calibrating fuel qty gauges Reply with quote
My sensors are not Princeton but the principle is the same. I seem to remember drilling about a 1/16" or 3/32" hole at the top of the tube.
Phillip Johnson
From: Speedy11(at)aol.com [mailto:Speedy11(at)aol.com]
Sent: Tuesday, August 18, 2009 9:07 PM
Cc: Johnson, Phillip (EXP)
Subject: Re: Calibrating fuel qty gauges
Phillip,
Stan Sutterfield
Was Said>
small vent.
Phillip Johnson
ulflyer(at)verizon.net
PostPosted: Wed Aug 19, 2009 7:17 am    Post subject: Calibrating fuel qty gauges Reply with quote
Are you using 100LL or ethanol blend car gas.
jerb
At 05:12 AM 8/19/2009, you wrote:
[quote] My sensors are not Princeton but the principle is the same. I seem to remember drilling about a 1/16" or 3/32" hole at the top of the tube.
Phillip Johnson
From: Speedy11(at)aol.com [ mailto:Speedy11(at)aol.com (Speedy11(at)aol.com)]
Phillip,
Stan Sutterfield
Was Said>
small vent.
Phillip Johnson
PostPosted: Thu Aug 20, 2009 4:13 am    Post subject: Calibrating fuel qty gauges Reply with quote
Mine is not flying yet. I was just relating to what I had done and what was in the instructions.
I will be using auto fuel though.
Phillip Johnson
Cozy MK IV Powered by Subaru IO-200
www.canardzone.com/members/phillipjohnson
Speedy11(at)aol.com
PostPosted: Thu Aug 20, 2009 6:25 am    Post subject: Calibrating fuel qty gauges Reply with quote
100LL.
I have an IO-390, Princeton fuel probes, Advanced Flight Systems AF-3400EM engine monitor.
Stan Sutterfield
Do no archive
jerb
Phillip Johnson
Phillip,
Stan Sutterfield
Was Said>
small vent.
Phillip Johnson
Page 4 of 4
