Possums
Posted: Sat Aug 15, 2009 1:46 pm Post subject: Spinning |
At 01:06 PM 8/15/2009, you wrote:
I am not interested in spinning my Firestar as I have no spin
training. I plan to get some.
Is the spin recovery technique the same for a Firestar and a tractor?
Specifically, power off?
You just kinda take your foot off the left rudder pedal
or quite pulling back on the stick. It doesn't want
to keep spinning unless you make it. At least on mine.
Don't think you'll want much power either, since your nose
will be pointed at the ground anyway.
Here's some pictures from the wing.
http://video.google.com/videoplay?docid=897400447222498104
_________________ Possum |
russ(at)rkiphoto.com Guest
Posted: Sat Aug 15, 2009 2:49 pm Post subject: Spinning |
Possums
Your video is great. Thanx for showing everyone that a Kolb can be
spun if it's in rig and the pilot is experienced/careful. It looks
as tho a Kolb has no bad habits in a spin. I assume spins in both
directions are similar?
But this should NOT encourage Kolb pilots to try this without some
supervision!
Remember how the old airmail pilots used to spin down thru the cloud
layer when they were caught on top? A spin is a stable maneuver, with
fairly low vertical descent speed. Even if the plane impacted the
ground, the pilot would likely walk away. Dizzy perhaps, but alive.
Besides, they're fun!
Russ K
PS I admit I've never worked out a really good spin-recover
technique in a car on ice.
On Aug 15, 2009, at 5:40 PM, possums wrote:
> <dalewhelan(at)earthlink.net>
Posted: Sat Aug 15, 2009 3:16 pm Post subject: Spinning |
Possums C
After watching the video of you and your Firestar spins C I get the impression that you;
A) had to make the Firestar spin
B) were in absolute full control during the spin
C) could have ended the spin at any time you wanted to end it
D) were VERY high above the ground
Your video should seem to remove the fear of some stall jumping out and biting some inattentive pilot. In other words C stalls don't just "happen" C you have to want it to stall.
Just my observation....
Mike Welch
MkIII progress C stalled on purpose
| Quote: | Date: Sat C 15 Aug 2009 17:40:00 -0400
Subject: Spinning
--> Kolb-List message posted by: possums <possums(at)bellsouth.net>
At 01:06 PM 8/15/2009 C you wrote:
>--> Kolb-List message posted by: "dalewhelan" <dalewhelan(at)earthlink.net>
>Specifically C power off?
Don't think you'll want much power either C since your nose
Get free photo software from Windows Live Click here.
Possums
Posted: Sat Aug 15, 2009 4:02 pm Post subject: Spinning |
At 07:06 PM 8/15/2009, you wrote:
| Quote: | Possums,
After watching the video of you and your Firestar spins, I get the impression that you;
Yeah - Beauford told me to cut the power, stomp on the rudder pedal,
yank the stick back as far as it would go and see if I could
count to ten. Done four - don't think I want to do ten.
Air speed never got over 65 mph ........like he said.
Mine doesn't seem to wind up much though. I could see how you could
use it to get through a cloud layer if you knew you had 2,000 feet
or so of clear air above the ground. I've done it the other way, and
I didn't like it much - takes too long and I didn't know which was is
up after a minute or two.
http://video.google.com/videoplay?docid=6787107193246239411
"Neutral does it for the firefly... soon as I turn it loose it stops rotation
and begins to fly...no opposite rudder or forward pop on the stick
needed...highest I have seen on ASI is 65 while it was spinning...
It does spin nose almost straight down...not like a cub or champ....feels
different...also likes to wind up... 3 turns is most I have let it go, but
it was still winding up when I released the back pressure and inside
rudder... I betcha an 8 or 10 turn doober could be eye-watering. I ain't
gonna find out."
Beauford T
Posted: Sat Aug 15, 2009 6:53 pm Post subject: Spinning |
| Quote: | layer when they were caught on top? A spin is a stable maneuver, with
fairly low vertical descent speed. Even if the plane impacted the ground,
Russ K
Russ K:
Think you wrote about this once before.
I don't recommend you try spinning any airplane into the ground. I can
assure you, you will not walk away and you will not be dizzy. You will
probably not be alive.
I don't know what the school definition is of a spin, but to me it is not a
stable maneuver. To me, it is an uncontrolled maneuver until control is
regained when exiting the spin.
In a Kolb, the nose is nearly straight down, and it seems more like a spiral
than a spin. I can assure you altitude is rapidly lost.
I've spun every Kolb I have built and owned, but I don't enjoy going out and
doing spins for fun anymore.
_________________ John Hauck
Titus, Alabama |
Posted: Sat Aug 15, 2009 7:08 pm Post subject: Spinning |
Mike W:
I, personally, don't think there is any control of a Kolb during a spin, not until after recovery has been initiated and accomplished. During the spin there is really nothing to do except bite holes in the seat cushion.
My original Firestar had to have the controls crossed up and locked to spin, and then it would only spin a half turn and fly out of the spin with the controls still locked. That was with the engine at idle. While experimenting with engine off aerobatics, I tried a spin. Dead stick,it spun up and would not recover until control was relaxed on stick and pedals.
The MKIII, being a much heavier aircraft than the Firestar falls out of the sky in a spin. Can't remember how many feet it takes to recovery from time of initiation to recovery in a one revolution spin, but it is enough to warn you not to try one close to the ground.
Inadvertent stalls only occur when the pilot is not paying attention, has diversion of attention, and is usually close to the ground. It is the inattentive pilot that is going to bite the dust. Stalls do happen. The desire to stall does not have to be part of the equation by any means.
Kolbs are not prone to spin. One reason is the outboard end of the wing does not stall, therefore we still have aileron/roll control and some lift to keep a wing from dropping. However, if you stall close to the ground, you probably will not have time to recover before impact.
Unlike some of the pilots on this List, I keep a cross check of my ASI when I am close to the ground, and especially during landing. Only takes me an instant to know where my ASI needle is pointing. I don't have to stare at the ASI to know how fast I am flying. It is the only way to know if I am keeping a safe margin above the stall. Even more important when winds are changing direction on me. I can not use perceived ground speed as an airspeed reference to keep me above the stall.
One can get away with a lot of "stuff" in a Kolb, but it is that one little incident that will get you.
Been there and done that, more than once. Hopefully, I am learning.
[quote] After watching the video of you and your Firestar spins, I get the impression that you;
Your video should seem to remove the fear of some stall jumping out and biting some inattentive pilot. In other words, stalls don't just "happen", you have to want it to stall.
Mike Welch
Titus, Alabama |
ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Sat Aug 15, 2009 7:38 pm Post subject: Re: Spinning |
Stalls in my M3X are so gentle you don't even lose any altitude....they are fun to do...you can really learn how to fly it right on the edge of slow flight with out worrying about whats going to happen.I did some stalls last week in mine and recorded it...take a look....and notice all the stalling I was doing..I lost no altitude..I will have the outside view next time.
http://www.youtube.com/watch?v=mHpS2rqp2bk
chris ambrose
M3X/jab 47.1hrs
N327CS
eagle1live(at)yahoo.com Guest
Posted: Sat Aug 15, 2009 7:48 pm Post subject: Spinning |
When I got my pilot training many years ago in 1947. We did spin training training as part of our lessons. This was in an old (new at the time) 1946 "Air Nocker" Champ. We were required to call out the number of turns we we we were going to make and also the heading, any at North South or East or West or any 90 degree heading. For me, it was a lot of fun. I could come out on my heading every time very easy. The Champ spun rather flat and not very fast so it was no problem. My flight instructor ( An ex Marine Corsier fighter pilot) also told me it was an easy to Way to lose altitude.
BUT, I have bulit and flown a Hi Max, a Firestar and a Firestar II and I never attemped to spin any of those because I didn't know how they would react.
I therefore would not recomend doing it in any of our Kolbs unless talking to someone who had done it a number of times to see how it would react. Also no Kolb is built exactly as yours..
For what its worth.
The Old Az. Bald Eagle
Sent: Saturday, August 15, 2009 8:00:16 PM
Subject: Re: Kolb-List: Spinning
.hmmessage P { PADDING-RIGHT:0px;PADDING-LEFT:0px;PADDING-BOTTOM:0px;MARGIN:0px;PADDING-TOP:0px;} BODY.hmmessage { FONT-SIZE:10pt;FONT-FAMILY:Verdana;} Mike W:
| Quote: | After watching the video of you and your Firestar spins, I get the impression that you;
Mike Welch
[b] |
dalewhelan
Joined: 11 Nov 2008 Posts: 105 Location: USA ARIZONA fountain hills
Posted: Sat Aug 15, 2009 8:53 pm Post subject: Re: Spinning |
Thanks guys
_________________ Dale Whelan
503 powered Firestar II, Luscombe 8A
Projection, A simple and interesting Psychological concept |
Posted: Sun Aug 16, 2009 5:43 am Post subject: Spinning |
John C
My observation of Possums' video gave me the impression he had control of the spin C that is; entering it C how long it lasted C and when he decided to end it. I agree with you that during the actual spin you don't really have any "flight control" C except when you end it.
Personally C I've never spun any aircraft I've flown C nor do I plan to. Not my cup of tea.
I was just making an observation that Kolbs seem to be a reasonably docile airplane C and not
some "scary out of control flight-trap".
I also made the observation Stan was VERY high above the ground. Regardless of whatever aerobatic flight manuever a person might try C they need to do it way up high C to allow plenty of time for recovery C or as a last resort C a ballistic chute attempt.
In my opinion C doing a high risk manuever close to the ground C including an excessive climb out C are asking for trouble.
I am curious how you feel "One reason is the outboard end of the wing does not stall".
I have not heard that before. Since the Kolb aircraft wings do not have any "washout" built into them C why would the outboard wing act any different than any other portion of the wing.
I'm not arguing with you C just curious why you said that.
BTW C I keep the same attention level close to the ground as you do. A good pilot would be aware of his airspeed (on approach) C and the airspeed indicator can NOT be the only way to monitor one's airspeed. They need to have a "feel" for how the airplane is acting C too. When I went through flight training C my instructor used to cover up the flight instruments C just to make sure I wasn't ONLY relying on just the instruments.
Mike Welch
MkIII
Subject: Re: Spinning
Date: Sat C 15 Aug 2009 22:00:16 -0500
Mike W:
I C personally C don't think there is any control of a Kolb during a spin C not until after recovery has been initiated and accomplished. During the spin there is really nothing to do except bite holes in the seat cushion
Posted: Sun Aug 16, 2009 5:44 am Post subject: Spinning |
List
I certainly don't want to start another long thread.
Of course John is right, and I don't recommend spinning into the
ground either.
I only know what I've been told about the airmail pilots; how their
wood-and-fabric aircraft would break up in a crash, and (reportedly)
the pilot usually lived thru it. But maybe I've believed too much. I
have no first-hand or second-hand, or even third-hand experience
here. I should have emphasized that the old biplanes had low
vertical descent speeds in a spin; not like modern aircraft.
I do think a spin is a stable maneuver in that it doesn't change by
itself. The pilot can either let the aircraft keep spinning, or bring
it out of the spin.
They used to require spins in pilot training, then only 'an approach
to a spin'. This at least let the student know what it felt like,
just before the spin developed. I suspect the change occurred because
of too many accidents.
Good idea to stay away from them.
Do we have a CFI on the list who has some input?
Russ K
On Aug 15, 2009, at 10:40 PM, John Hauck wrote:
> with fairly low vertical descent speed. Even if the plane impacted
> the ground, the pilot would likely walk away. Dizzy perhaps, but
> alive.
> Russ K
Russ K:
can assure you, you will not walk away and you will not be dizzy.
You will probably not be alive.
is not a stable maneuver. To me, it is an uncontrolled maneuver
until control is regained when exiting the spin.
a spiral than a spin. I can assure you altitude is rapidly lost.
going out and doing spins for fun anymore.
Posted: Sun Aug 16, 2009 6:33 am Post subject: Spinning |
Hi Mike W:
To answer your question about the outboard end of the wing not stalling:
TNK did tuft tests of the MKIIIc early on in their development of the MKIIIx.
As soon as stall was initiated the tufts on the inboard end of the wing would start pulling off the wing, dancing around, indicating air had seperated from the top of the wing. The tufts on the outboard end of the wing stayed glued to the top of the wing all the way to the end of the bow tip. Inboard stalled, outboard still flying.
Further, I did some experimenting with my MKIII just prior to flying to Pennsylvania for Homer's funeral which backed up the tuft tests. Playing around with stalls, I pulled the flap handle out of the detent and let it float between zero and 20 degrees. As the MKIII approached the stall, the flaps started a gentle shake, but the ailerons remained steady. Further into the stall the flaps and the ailerons were steady.
If you can get enough angle of attack of the wing, and hold it there, you can stall the whole wing. However, it is difficult if not impossible to hold that steep an attitude for more than a moment. In a mush/stall, with the stick all the way back to the stop, the Kolb mushes in a near level attitude. Most of the time it will gain enough airspeed to fly back out of the mush/stall with the stick still being held full aft.
I think what screws folks up is the gentleness of this maneuver at a safe altitude gives them a false impression that they can pop right out of a mush/stall any time they wish. However, close to the ground it is easy to get into a mush/stall and not get out of it before hitting the ground because there just isn't enough altitude to complete the maneuver.
Remember Dale Walen telling us he hit the ground pretty hard when he was maneuvering close to the ground in his FS with his girl friend on board. I imagine he mushed it into the ground when he got too slow in a steep turn, hit the ground, regained enough airspeed to start flying again.
I experienced something similar departing Grants, NM, last May. Flew out of ground effect, max gross weight, 9300 feet DA, cross wind in a valley with invisible dust devils in the area of the airstrip. I was too low and too slow and too heavy to push the nose down to recover. I kept the throttle wide open, kept the nose up with aft stick, kept the wings level. The wind blew me off the runway to the left. I hit in the sand between the sage brush extremely hard, thinking I was going to spread the main gear legs, kept the throttle wide open, bounced back into the air, and was flying again, however poorly. Bruce C and John B took off ahead of me, experienced the same thing, but were able to keep from hitting the ground. Was not a fun experience, but it got our utmost attention after that, and we learned a lot.
Mike Welch
Titus, Alabama |
Posted: Sun Aug 16, 2009 6:39 am Post subject: Spinning |
If your Kolb flies like my Kolb, the inboard end of the wings stalls first
and the aircraft goes into a gentle mush/stall because the outboard end of
the wing is still providing some lift. A lot of Kolb aircraft have mushed
into the ground in a level attitude, spread the gear or worse, and the
pilots walked away, thinking they were still flying and wondering why they
were losing altitude. Some of those pilots did not walk away.
If you get enough angle of attack, the entire wing stalls. The pilot will
recognize this as a normal stall, like in a Cessna. But with enough
altitude, the Kolb will fly out of it.
Not long ago I was trying to get back into the groove after laying off
flying since I returned from out West the end of May, getting ready to fly
to Homer's in mid-July. I was playing around with slow flight, stalls,
steep turns, and placed the the flap handle between zero and 20 degrees,
letting the handle float in that position. As I approached the stall the
flaps would shake. In all the flying I have done in this airplane, this is
the first time I had observed this. As I got further into the stall the
flaps would stop shaking, but the ailerons never shook. That, to me, was an
indication the inboard end of the wing is stalling before the outboard end.
I don't think I ever stalled a Kolb and not lost altitude. Experiementing
with the Kolb I can nibble at the mush/stall and it doesn't seem like I have
lost any altitude because it is so gentle. This can get pilots in trouble
because the airplane remains in a level attitude, but it is in a stall. Our
head tells us we are flying because we are level. Our heads are telling us
if we were stalling, the nose would be down.
In the early years of flying Kolbs, I experimented quite a bit with
different flying techniques, unusual attitudes, aerobatics, trying to learn
all I could about flying these little airplanes. A lot of the experimenting
I did was well outside the design flight envelope, but I would not have
found out how they flew if I had not gone there. Would I do that kind of
flying now that I have learned the hard way several times? Not hardly, but
I wouldn't give a million dollars for the experience.
Titus, Alabama |
Posted: Sun Aug 16, 2009 6:56 am Post subject: Spinning |
Kolbers,
When I began flying lessons, recovery from spins was a requirement. Later
on I flew sailplanes for a a couple of years. Since you are primarily in
continuos slow flight just above stall most of the time, it was important to
experience spins and recovery.
As I under stand it the FAA stopped requiring spin recovery training, due to
the fact that most spins were experienced during transition to and from the
ground. And since most of the resultant effects could not be countered did
not feel that training was essential.
I still believe that spin and spin recovery should be taught, as it can give
you a lot of important information about your aircraft. My original
FireFly, was very twitchy and when I would pull it up into a low powered
stall, I had to kick rudder to pick a wing as it mushed forward. If I
didn't it would roll over into a spin. Later I mounted VG's and it improved
the airflow over the ailerons, so that a wing would not drop, and the
FireFly just went into a forward mush. The twitchyness went away. One
could advance the throttle and hold altitude, and with a little aileron
input, rotate the FireFly without dropping a wing. One had to force it into
a spin. Then I mounted the Victor 1+ and I moved the propeller off to one
side to prevent the addition of a trim tab to the rudder. This improved
overall cruise performance but the asymmetrical thrust over the wings
dramatically changed the stall characteristics. The left wing receives
greater propeller coverage, and so the right wing will always stall first.
With little power, one can hold it up with rudder. Under power the right
wing will warn you with a "wump" and then the flow will re-attach, and it
you persist in adding more back stick, the right wing will drop and over you
go.
This is the price I have to pay for asymmetrical thrust to keep weight down
and to increase cruise performance. But I would not have found how the
FireFly would respond if I had not taken it up to altitude and checked it
out.
FWIW
Jack B. Hart FF004
Winchester, IN
Posted: Sun Aug 16, 2009 7:22 am Post subject: Spinning |
My original
| Quote: | FireFly, was very twitchy and when I would pull it up into a low powered
Jack B. Hart FF004
Winchester, IN
Jack H:
Wouldn't the aileron hold your FF level in a low powered mush?
I never got a chance to "horse around" with the FF more than I could do in
the traffic patterns of OSH and LAL. Been so long since I flew it I can't
remember, but there was something a little unusual about it when slipping, I
think. I never flew the original with the huge ailerons, only the ones with
smaller ailerons.
Titus, Alabama |
JetPilot
Posted: Sun Aug 16, 2009 8:27 am Post subject: Re: Spinning |
Possums,
What a ride !!! With no window or anything forward of you in your firestar, you are hanging by your belts looking down at nothing but air in front of you for 2000 feet I have done hundreds of spins in a Cessna 150 Aerobat, but your position and view in the spin is just insane crazy. Do you do that often ? How many turns have you done ? That is a really cool video, I hope you keep making new ones.
Kolb MK-III Xtra, 912-S |
JetPilot
Posted: Sun Aug 16, 2009 8:33 am Post subject: Re: Spinning |
| russ(at)rkiphoto.com wrote: |
it out of the spin.
A spin is usually fatal, be it in a biplane, cub, or any other airplane. Just like the non aviation witness be the best to determine how an airplane was flying before a crash, don't believe everything you hear and read.
The above is not true, a spin can and usually does change a lot depending on how many turns you go through. This is why many people do not spin past 3 turns or so, spins have a very bad habit if tightening up, getting flatter, and doing all sorts of strange things depending on the airplane and how it is loaded.
Posted: Sun Aug 16, 2009 11:41 am Post subject: Spinning |
| Quote: | Mike
You say "A spin is usually fatal, be it in a biplane, cub, or any
other airplane". Where did THAT come from ?
Sorry, but I don't believe that for a minute. Not even a half-minute.
I've seen LOTS of planes spun, with no fatalities.
Even done a few myself, and I'm still here.
On Aug 16, 2009, at 12:33 PM, JetPilot wrote:
> it out of the spin.
http://forums.matronics.com/viewtopic.php?p 57990#257990
Posted: Sun Aug 16, 2009 12:12 pm Post subject: Spinning |
On Aug 16, 2009, at 3:33 PM, russ kinne wrote:
> Mike
minute. I've seen LOTS of planes spun, with no fatalities.
>> bring
>> it out of the spin.
> Mike
Posted: Sun Aug 16, 2009 12:21 pm Post subject: Spinning |
At 10:22 AM 8/16/09 -0500, you wrote:
smaller ailerons.
John H,
I could not hold the wings level in a low powered mush with the original
ailerons or the shortened ailerons. After I mounted the VG's, I did not
have to worry about picking up a wing with the rudder as the ailerons were
much more effective.
With the VG's, the FireFly side and forward slips very well with or without
flaperons. In a side slip one can hold landing strip alignment into a 20 mph
cross wind. My rudder is a little longer than that used in the original
design. I did not like the bow over the top of the rudder and so I added
that cut off area to the trailing edge. After adding streamlining to the
trailing edge, I believe the trailing edge has been displaced two inches to
the rear.
Some one on the list asked me about how the FireFly reacted to stalling in a
side slip during a landing approach. I added that subject to my short list,
but I have not gotten around to running the test as I was finishing fuel
flow tests with the Victor 1+. When I finish mounting the MZ 34, I will
climb to altitude and perform the test.
As far as mounting the MZ 34, it is on the cage and everything is mounted.
I am building up the start and magneto kill switches and the regulator
mounting plate. When this is mounted, I can complete all engine wiring. To
save weight, I have stripped out all the old Victor 1+ control guides, as I
have only three control functions instead of six. And I have to come up
with some way to control low and high speed air mixture controls inside the
cockpit.
Off Kolb subject, today I purchased a disassembled Thundergull. Some hangar
rash, but nothing serious. Will put it into the barn until I get the
FireFly back into the air. It looks like a nice way to get back into winter
flying.
Jack B. Hart FF004
Winchester, IN
