noconwud(at)earthlink.net Guest
Posted: Mon Aug 17, 2009 7:37 pm Post subject: Has anyone considered making their own propeller? |
After seeing some other folks do it, and having done it with model airplanes, I'm considering attempting it. Has anyone else considered doing it?
My two major concerns would be the harmonics and the potential for asymmetric thrust (one blade pulls more than another), but I've read plenty of accounts of folks making their own with great success.
Thoughts?
Andy
Deems Davis
Posted: Mon Aug 17, 2009 8:52 pm Post subject: Has anyone considered making their own propeller? |
I've not heard of anyone trying it on an RV10. I suspect it's because
most folks opt to install a constant speed prop in order to extract the
most performance. I'm only aware of one -10 that was/is equipped with a
fixed pitch prop, and every time I see/hear of it; its for sale.
Deems Davis N519PJ
http://deemsrv10.com/index.html
Andrew Johnson wrote:
| Quote: | After seeing some other folks do it, and having done it with model
doing it?
Thoughts?
Andy
coop85(at)verizon.net Guest
Posted: Tue Aug 18, 2009 3:35 pm Post subject: Has anyone considered making their own propeller? |
Andy,
Impressive thought to be willing to take on such a task! However, aside from the design and construction issues which would not be small, the RV-10 seems to be the type airplane that really benefits from a constant speed prop. IMO, the short takeoff roll and impressive climb followed by very nice cruise speeds would be compromised with a fixed pitch prop. The constant speed prop also helps get the beast slowed down on approach so a fixed pitch prop would require a little more planning on arrival. The great thing, though, is you can do whatever you want.
Marcus
40286, 430 hrs and counting
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Andrew Johnson
Sent: Monday, August 17, 2009 11:33 PM
Subject: Has anyone considered making their own propeller?
Thoughts?
Andy
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
n8zg(at)mchsi.com Guest
Posted: Tue Aug 18, 2009 3:51 pm Post subject: Has anyone considered making their own propeller? |
Andy –
Dan Horton carved the prop for his bi-plane project. It was a major ordeal. He had an experienced old-timer carve a one-blade blank, built a duplicator, then had trouble getting a blank that was up to his standards. After much time, effort and no small amount of angst, he has a beautiful prop that he carved himself…
neal
Thoughts?
Andy
[quote] [b]
