Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27247 Location: Livermore CA USA
Posted: Wed Aug 19, 2009 7:11 pm Post subject: Oil Cooler Size On RV-10...? |
Hey, what size oil cooler to the RV-10's use? Is it the same on on the -7's and -8's? "Oil Cooler II". Or, do they use a larger one?
I've got a SW10610R for my IO-390 on the RV-8 which is a monster sized cooler. The stock "FF-709" mounting bracket is way too small. Does Van's have a larger one available? What's used on the RV-10?
I guess that I could make one, but I'd rather Van's CNC punch did, if you know what I mean...?
Thanks!
RV-8 #82880 N998RV
http://www.mykitlog.com/dralle
FWF
_________________ Matt Dralle
AirMike
Posted: Thu Aug 20, 2009 9:16 pm Post subject: Oil Cooler Size On RV-10 |
I do not know about Van's, but Alex DeDominicis (Aviation tech products)sells one that has the identical dimensions as Van's unit for the 10 and supposedly has 20% better cooling. Alex is a good guy and with the difference from the cost of the Van's product - it was about $100 more. Seems to work fine.
_________________ See you OSH '18
Q/B - sold. |
partner14
Posted: Thu Aug 20, 2009 9:53 pm Post subject: Oil Cooler Size On RV-10...? |
Ditto on the unit from Alex.... with the exception of the reduction in cooling... certainly NOT 20%.... considering 200 degrees, we'd be talking about a 40 degree reduction. Plan on a reduction of between 5 and 15.
Don McDonald
--- On Thu, 8/20/09, AirMike <Mikeabel(at)Pacbell.net> wrote:
Subject: Re: Oil Cooler Size On RV-10...?
Date: Thursday, August 20, 2009, 10:16 PM
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)>
OSH '09 or Bust (busted) be there someday
Q/B Kit - end game
http://forums.matronics.com/viewtopic.php?p=258936#258936<= - The RV10-List tp://www.matronics.com/Navigator?RV10-List" target=_blank>http://www.matr &nbs;--> h=
40636 |
michaelbaldwin7475(at)sbc Guest
Posted: Fri Aug 21, 2009 1:04 pm Post subject: Oil Cooler Size On RV-10...? |
We put the Airflow 2008X on our RV-10 since our oil temps where higher than we liked
And saw a 10 - 20 degree F drop as a result
We also installed a baffle that splits the air flow in the Van's standard box per recommendation from Airflow (these guys had a lot of good experience with the RV-10 people)
You do have to modify Van's oil cooler box to bolt the 2008X on inplace of the standard cooler, but it can be done. Basically you have to turn the cooler 90 degrees and fold out the vertical sides of the box, drill a few holes and bolt on. Actually pretty simple change. I felt it was worth
High oil temps for us was only during summer hot days coupled with slow flight conditions 120 - 150 mph range. if you keep the speed up to 160 or better its usually ok
Example would be 90 degree day and slow flight around the pattern or sight seeing low and slow the temp would get up to 230 F. Now with larger cooler it only hits 210 F. Our 6 position CHT numbers have always been 350 or lower regarding engine temp, so the cowling / baffling seams tight and working good.
The slow flght condition appears to be more of the issue. I would bet a cowl flap right under the cooler would also work, be interested to hear if any one has done that yet.
Mike Baldwin (see add below )
Engine Parts - Oil Coolers - Airflow Systems X-SERIES OIL COOLERS BY AIRFLOW SYSTEM The first new aircraft oil cooler design in 50 years. Computer modeling and flight testing have been used to develop coolers that deliver significantly lower oil temps with no increase in oil cooler
View more details 08-06154 2006X AIRFLOW OIL COOLER EXPMT $432.00 08-06155 2008X AIRFLOW OIL COOLER EXPMT $493.00
--- On Fri, 8/21/09, Don McDonald <building_partner(at)yahoo.com> wrote:
Subject: Re: Re: Oil Cooler Size On RV-10...?
Date: Friday, August 21, 2009, 1:49 AM
Don McDonald
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
Q/B Kit - end game
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
| [quote][b]
pilotdds(at)aol.com Guest
Posted: Fri Aug 21, 2009 1:11 pm Post subject: Oil Cooler Size On RV-10...? |
Mike do you have any photos of your mods to the oil cooler box?
Tim Olson
Posted: Fri Aug 21, 2009 1:21 pm Post subject: Oil Cooler Size On RV-10...? |
Does anyone have photos of this "splitter" vane thing that people
are putting in the filter box? It sounds great, and I've heard
tons about it, but never seen a photo.
Tim Olson - RV-10 N104CD
Michael Baldwin wrote:
| Quote: | We put the Airflow 2008X on our RV-10 since our oil temps where higher
than we liked
worth
*/ Engine Parts
<http://www.aircraftspruce.com/menus/ep/index.html> - Oil Coolers
<http://www.aircraftspruce.com/menus/ep/oilcoolers.html> - Airflow Systems/*
<http://www.aircraftspruce.com/catalog/eppages/xseriesOilCooler.php>
View more details
08-06154 2006X AIRFLOW OIL COOLER EXPMT *$432.00*
<http://www.aircraftspruce.com/neworderform.php?cmd=add&p=08-06154&q=1>
08-06155 2008X AIRFLOW OIL COOLER EXPMT *$493.00*
<http://www.aircraftspruce.com/neworderform.php?cmd=add&p=08-06155&q=1>
5 and 15.
Don McDonald
<http://us.mc537.mail.yahoo.com/mc/compose?to=Mikeabel(at)Pacbell.net>>
Q/B Kit - end game
http://forums.matronics.com/viewtopic.php?p 58936#258936<=
<http://www.matronics.com/contribution>
Deems Davis
Posted: Fri Aug 21, 2009 4:13 pm Post subject: Oil Cooler Size On RV-10...? |
Tim,
I don't have a picture, but I'll try and describe it.
The 'splitter' itself is a piece of .032. It is the same width as the
inside dimension of the oil cooler mounting box. Its depth (from memory)
is about 3 1/2 " the bottom 3/4" of an inch of the splitter is bent with
an angle of 30-45 degs. The splitter comes with 2 .032 alum angle "L"
tabs. that are about 1/2" wide and 1/2-5/8" long. I installed mine by
pop riveting the angle flanges flush with the top of the splitter, Then
installe the splitter/diverter flange inside of the mounting and place
it midway across the circular opening. Drill (match) a # 30 hole so
that you can pop rivet the flanges to the top of the mounting . 9The
bent part of the splitter is facing forwaed. The theory is that the air
coming from the scat is split and the splitter pushes 1/2 of the air
towards the top of the oil cooler. the reports were that without it the
pressures builds up on the bottom of the wedge and more air passes
through the bottom than the top.
Deems Davis N519PJ
http://deemsrv10.com/index.html
Tim Olson wrote:
> */ Engine Parts <http://www.aircraftspruce.com/menus/ep/index.html>
> - Oil Coolers
> Systems/*
> View more details
> wrote:
> From: Don McDonald <building_partner(at)yahoo.com>
> To: rv10-list(at)matronics.com
> 5 and 15.
> Don McDonald
> From: AirMike <Mikeabel(at)Pacbell.net>
> Q/B Kit - end game
Posted: Mon Aug 24, 2009 7:18 am Post subject: Oil Cooler Size On RV-10...? |
No photo - but I think we had a drawing >From Airflow that I can dig out and scan
It's at the airport so may take a few days to get back to you
Later
Date: Friday, August 21, 2009, 5:10 PM
Tim Olson
Posted: Mon Aug 24, 2009 7:48 am Post subject: Oil Cooler Size On RV-10...? |
Mike, that will be awesome if you can get the drawing.
Maybe they'll send it to me if I ask. I'll see.
[quote] No photo - but I think we had a drawing >From Airflow that I can dig out
and scan
Later
Tim Olson
Posted: Mon Aug 24, 2009 7:49 am Post subject: Oil Cooler Size On RV-10...? |
Nope, they give the drawing with the kit, which is $49.
I may have to get me one.
and scan
Later
Posted: Mon Aug 24, 2009 1:23 pm Post subject: Oil Cooler Size On RV-10...? |
thanks
martin(at)gbonline.com Guest
Posted: Tue Aug 25, 2009 8:52 am Post subject: Oil Cooler Size On RV-10...? |
When I built my RV8, I attempted to use the SW cooler recommended by vans,
however it was inadequate. Upon advice of Monty Barrette, and Dave Anders
(still the fastest RV) I obtained a Niagara/Harrison 10 cooler and mounted
it on the rear baffle behind cyl 4 and tilted it down approximately 35
degrees (tilt as much as possible without contacting engine mount) (it will
be necessary to remove some metal from the flange on the cooler to prevent
contact with engine mount tube). This set up has proven to be excellent
providing good cooling in all temperatures up to 95 degrees outside air
including the Air Venture races when I run at 100 percent of power at low
altitude for over 2 hours (2700 rpm, 27-29 inch manifold pressure) average
indicated airspeeds are 220-235mph depending on OAT.
Posted: Tue Aug 25, 2009 9:04 am Post subject: Oil Cooler Size On RV-10...? |
Thanks for the feedback Richard. Do you have some pictures of your installation you could post to the Lists?
BTW, your computer clock is 5 days behind.
RV-8 #82880 N998RV
<http://www.mykitlog.com/dralle>http://www.mykitlog.com/dralle
FWF
At 08:33 AM 8/20/2009 Thursday, you wrote:
When I built my RV8, I attempted to use the SW cooler recommended by vans, however it was inadequate. Upon advice of Monty Barrette, and Dave Anders (still the fastest RV) I obtained a Niagara/Harrison 10 cooler and mounted it on the rear baffle behind cyl 4 and tilted it down approximately 35 degrees (tilt as much as possible without contacting engine mount) (it will be necessary to remove some metal from the flange on the cooler to prevent contact with engine mount tube). This set up has proven to be excellent providing good cooling in all temperatures up to 95 degrees outside air including the Air Venture races when I run at 100 percent of power at low altitude for over 2 hours (2700 rpm, 27-29 inch manifold pressure) average indicated airspeeds are 220-235mph depending on OAT.
