		hotwheels
				 Posted: Mon Aug 24, 2009 12:38 pm    Post subject: Question on Control Cables & FAB |
				FF3-2 (rev0): What torque to set for AN316-7R nuts? These are used to hold the various control cables to their respective mounting brackets.
 FF-FAB Figure 2: "Securing the Control Cable" shows the alt air cable as "route to panel". Where have others routed it through the firewall? Any photos?
 Thanks in advance to anyone who responds...
 Jay
		johngoodman
				 Posted: Tue Aug 25, 2009 5:31 pm    Post subject: Re: Question on Control Cables & FAB |
				It's a 7/16th inch thread, so look up the torque numbers in the tables.
		hotwheels
				 Posted: Wed Aug 26, 2009 10:20 am    Post subject: Re: Question on Control Cables & FAB |
				Thanks for the reply.
 Here's why I asked the question:
 The table in Vans RV-10 General Info Section 5 calls out AN7... 450-500 in-lbs. The Lycoming Service Table of Limits SSP1776 doc Table I, "Bolts, Screws and Nuts", page 1-37 calls out 7/16...600 in-lbs. 150 in-lbs difference is quite a spread.
 I may just split the difference and call it good.
 Jay
  	  | johngoodman wrote: | 	 		  It's a 7/16th inch thread, so look up the torque numbers in the tables.
 John |
		johngoodman
				 Posted: Wed Aug 26, 2009 11:35 am    Post subject: Re: Question on Control Cables & FAB |
				Jay,
 Just to muddy the water a little (g), The Standard Aircraft Handbook table on page 160 Shows 450-500 inch-pounds for a 7/16-20 with an AN315 nut, while an AN316 Shear Nut is only 270-300 inch-pounds. I believe you are tightening an AN316, right?
 Also, Coarse thread 7/16-14 are even less, but I'm pretty sure yours is -20.
		hotwheels
				 Posted: Thu Aug 27, 2009 6:31 am    Post subject: Re: Question on Control Cables & FAB |
				Thanks John. Differences between the tables make perfect sense once thread count is taken into consideration.
 The control cables all use the same AN316 nuts. Don't know if they are shear nuts however.
 Just fyi that if you ordered Vans throttle quadrant, you'll need extra -43 lock washers as they only include enough for the FWF ends.
 Jay
  	  | johngoodman wrote: | 	 		  Jay,
 John |
