Don McIntosh
Joined: 02 Jul 2007 Posts: 24 Location: Sandpoint, Idaho
Posted: Mon Aug 24, 2009 6:45 pm Post subject: Audio Alert to PM 100II |
I have a Dynon D180 that has 2 audio alert outputs that I can tie together but there is no Aux input on the PM 1000II intercom or my Garmin SL 40 to hook to. Someone said to hook it to my phone (headphone?) output but when I called PS Engineering, they weren't sure it would work and had no suggestions except that their new PM 3000 has 2 Aux inputs. Any ideas on how to get audio alert from my Dynon? I do hate to undo my existing pins and soldered shields. I have an "expansion unit" input slot that is open on the intercom harness, that is apparently used for attaching their unit to add up to six passengers.
_________________ Don McIntosh
Kitfox Series 7
Jabiru 3300 |
rv-9a-online(at)telus.net Guest
Posted: Mon Aug 24, 2009 9:21 pm Post subject: Audio Alert to PM 100II |
Hi Don. What you need is an audio mixer. The one that we manufacture is
the AMX-2A at www.vx-aviation.com. It takes 10 inputs (4 variable), which
may be overkill, but it will work with any radio and intercom, even ones
that do not have auxiliary inputs.
The variable inputs are ideal for the Dynon D180. Some rewiring is
necessary, but the unit is extremely small and can be buried in the wiring
harness.
Vern Little
Vx Aviation
rv8iator
Posted: Wed Aug 26, 2009 6:42 am Post subject: Audio Alert to PM 100II |
Don...
Just finished a panel for a kitfox with similar panel components. I tied the Dynon's audio out together with a potentiometer per Dynon's schematic and used an audio mixer from Flight Data Systems ($90). This provided multiple audio inputs (Dynon and SL-30 Nav audio) to be combined into one audio out that I connected to the aux input on the PM1000.
http://www.fdatasystems.com/
Chris Stone
RV's
Newberg, OR
_________________ C. Stone (RV8iator) |
Don McIntosh
Posted: Wed Aug 26, 2009 3:39 pm Post subject: Re: Audio Alert to PM 100II |
There is no aux input on the PM 1000. Do you mean the expansion unit input? Apparently the signal coming from the Dynon is not a sound, but just a signal that needs some magic to turn it into sound?
Kitfox Series 7
Jabiru 3300 |
stein(at)steinair.com Guest
Posted: Wed Aug 26, 2009 4:12 pm Post subject: Audio Alert to PM 100II |
Quick suggestion...if you're using the standard dynon alert "beep"...just
forget it. It doesn't play nice with many intercoms! The HS-34 audio on the
other hand is quite good.
Stein
_________________________________________
The information transmitted is intended only for the person or entity to
which it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you receive
this in error, please contact the sender and delete the material from any
computer.
[quote]--
doug.ilg(at)verizon.net Guest
Posted: Wed Aug 26, 2009 6:29 pm Post subject: Audio Alert to PM 100II |
Don,
Note that he's talking about a PM 1000 II. They DO have aux audio in. I had one in my Tiger for about 8 years.
FYI.
Doug Ilg
Grumman Tiger N74818, College Park Airport (KCGS), Maryland
Challenger II LSS (N641LG reserved) - kit underway at Laurel Suburban (W18)
frank.hinde(at)hp.com Guest
Norm Biron
Posted: Thu Aug 27, 2009 8:16 am Post subject: Audio Alert to PM 100II |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> The Dynon EMS Alarm and AOA Alarm also works well with the PS Engineering PMA6000MC when connected to the Audio Alert un-switched un-muted input.
Norm
Don McIntosh
Posted: Thu Aug 27, 2009 4:03 pm Post subject: Re: Audio Alert to PM 100II |
OK. Attached is the wiring diagram for the PM1000II w/o crew PN 11922. Are we talking about the music input? It may mute when I scream when the alarm goes off but that might not be all that bad!
 Download |
| Filename: |
PM1000II Wiring Diagram.pdf |
66.74 KB |
| Downloaded: |
681 Time(s) |
Kitfox Series 7
Jabiru 3300 |
