		ianxbrown
				 Posted: Wed Jul 15, 2009 5:41 am    Post subject: Dynon D10A/EDC in and  RV-9A - weird behaviour |
				Has anyone else suffered or resolved the following issue with a Dynon
 D10A EFIS with the optional EDC installed in their RV?
 I get "signal too weak to calibrate" messages or something to that
 effect, indicating that the voltage from the EDC is too low.  I'm sure
 I'm going to have to replace the wiring, but wanted to check what others
 had done.  I believe my error was in not using shielded wire, but maybe
 there's a voltage drop on such a long wire run.  For those who have an
 install that works, what wire did you use?  I have the EDC mounted on
 the bulkhead one full space forward of the horizontal stabilizer.  I DO
 see constantly updating numbers, as I'm supposed to, when I go into the
 EDC calibration program.
 The reason I'm asking this on this list, rather than with Dynon, is that
 I'm looking for aircraft specific info, since it's quite a long wire
 run.
 Any other ideas or experience would be appreciated.  Thanks,
 Ian Brown
 Bromont
 Quebec
  On Tue, 2009-07-14 at 23:58 -0700, RV-List Digest Server wrote:
  	  | Quote: | 	 		   *
  Today's complete RV-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the RV-List Digest and can be viewed with a generic text editor
  HTML Version:
      http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 09-07-14&Archive=RV
  Text Version:
      http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 09-07-14&Archive=RV
                             RV-List Digest Archive
                       Total Messages Posted Tue 07/14/09: 1
  Today's Message Index:
       1. 06:45 AM - RV10 tail kit (assembled) for sale  (Rlepre)
  ________________________________  Message 1  _____________________________________
  Time: 06:45:51 AM PST US
  Subject: RV10 tail kit (assembled) for sale
  I have an RV 10 tail kit for sale.  I can deliver.  Contact me at RLaviation(at)aol.com
  http://forums.matronics.com/viewtopic.php?p 52945#252945
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		sbuc(at)hiwaay.net Guest
				 Posted: Wed Jul 15, 2009 10:20 am    Post subject: Dynon D10A/EDC in and  RV-9A - weird behaviour |
				Ian wrote:
  run.
  Ian Brown
  Bromont
  Quebec
 Ian,
 Can't help with your specific problem but I can tell you that I am using
 CAT5 network cable (non-shielded) for the Dynon magnetometer under the
 tail of my RV-6. My installation has worked perfectly for several years.
 Shielded cable is not necessary for proper operation of the mag. You
 might take a good look at the connectors in your harness to make sure
 there isn't a high-resistance fault in a crimp or solder connection.
 Sam Buchanan
		bartrim(at)gmail.com Guest
				Hi Ian;
      I've got the D10A/EDC in an RV9 and had no problems, but I used shielded wire as I have access to plenty of it. I would recommend that you call Dynon's tech support. They are excellent and their service is second to none.
      Your installation is not at all uncommon and they would be able to provide you with any aircraft specific information that you require. If you are determined to try to do this with help from a list then I would recommend the Aero-Electric list as a much more specific list for this sort of problem.
      I once fried my D10 doing something really stupid that I should have known better (always use a grounded tip soldering iron) and when I called Dynon and told them what I did, they said no problem. I had to pay 1-way shipping and they fixed it free and paid the return shipping. It was out of my plane for little more than a week. That's good service.
  Todd
  C-FSTB
  RV9 13BTurbo
  On Wed, 2009-07-15 at 09:33 -0400, Ian wrote:  	  | Quote: | 	 		    	  | Quote: |
 --> RV-List message posted by: Ian <ixb(at)videotron.ca (ixb(at)videotron.ca)>
 run.
 Ian Brown
 Bromont
 Quebec
		mike@hotlinesinc.com
				 Posted: Thu Aug 27, 2009 10:12 am    Post subject: Re: Dynon D10A/EDC in and  RV-9A - weird behaviour |
				Beware of internal pitot leaks with Dynon D10A
 I installed a Dynon 10A a couple years ago as a back up AI in a warbird.
 A recent pitot static check uncovered a pitot leak that was pretty severe.
 The leak was traced and verified as being internal to the Dynon D10A.
 Disassembly of the unit revealed that the pitot connection to the solid state sensor for airspeed was loose. The static port on the sensor also came loose during disassembly.
 This unit has under 10 hours of operation.
 There is no way I would depend on this unit  as a primary flight instrument
