recommended RV brake fluid
bmeyette
PostPosted: Thu Aug 27, 2009 6:54 pm    Post subject: recommended RV brake fluid Reply with quote
my RV-7A construction manual says I must not use automotive brake, but instead "use only the aircraft brake fluid recommended by the manufacturer". But they don't say what this fluid is. Does anyone know what fluids are recommended for use with the standard Van's Cleveland disk brakes?
thanks,
brian
Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm
t6pilot(at)cfl.rr.com
PostPosted: Thu Aug 27, 2009 7:26 pm    Post subject: recommended RV brake fluid Reply with quote
Mil H 5606 normally is used for brake fluid and you can find it here http://www.aircraftspruce.com/search/search.php. Recommend that you go to the Cleveland website to be sure. Also, it's probably in your Cleveland Brake instructions. Do not use automotive, it'll melt the seals... Good luck and fly safe.
pitts_pilot(at)bellsouth.
The most common is 5606 .... and there is a higher temp fluid out there too.
Linn
thanks,
brian
bmeyette
PostPosted: Thu Aug 27, 2009 7:48 pm    Post subject: recommended RV brake fluid Reply with quote
Would you, or anyone, happen to know the Cleveland web site? I googled "cleveland brakes" before sending the original message, but all I got was sellers, not the mfg site. Or their phone number woudl work, too.
thanks,
brian
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Randy Difani
Sent: Thursday, August 27, 2009 11:08 PM
To: rv-list(at)matronics.com
Subject: Re: recommended RV brake fluid
N432MM
passpat(at)aol.com
use 5606 brake and hdy fluid
Kellym
PostPosted: Thu Aug 27, 2009 7:51 pm    Post subject: recommended RV brake fluid Reply with quote
From the RV-10 list archives:
"A couple of RV-x main landing gear caliper fires that
consumed the glass pant caused a few to change from H-5606 a few years
back. The flame propagation was right below each main AVGAS fuel tank.
Fiberglass fires are a perverted thing to watch. So take a test sample
and learn by experiment not experience how the cured resin and glass
strands come to life until gone. Mine was watching a '69 Vette being
prepped for custom paint.
VANS mantra is stay conservative with the brakes and build your kit bone
stock.
Mil H-83282 provides another level of combustion protection. I have
found that H-5606 tends to coagulate with age. Its low flash point is
routinely accepted by most builders without consideration of
alternatives."
thanks,
brian
Kelly McMullen
KCHD
gyoung
PostPosted: Thu Aug 27, 2009 8:25 pm    Post subject: recommended RV brake fluid Reply with quote
The company is actually Parker-Hannifin. Try
http://www.parker.com/portal/site/PARKER/menuitem.14ecfc66e7a40c1af8500f199420d1ca/?vgnextoid=43cb5242ade5c110VgnVCM10000032a71dacRCRD&vgnextfmt=default&Keyword=AIRCRAFT+WHEELS+%26+BRAKES&Wtky=AIRCRAFT+WHEELS+%26+BRAKES
If that URL is broken go to www.parker.com and browse to Products/Aircraft Wheels and Brakes. All kinds of info including manuals.
Greg Young
[quote] From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Brian Meyette
Sent: Thursday, August 27, 2009 10:42 PM
Subject: RE: recommended RV brake fluid
thanks,
brian
Vanremog(at)aol.com
PostPosted: Thu Aug 27, 2009 9:35 pm    Post subject: recommended RV brake fluid Reply with quote
IMO, don't bother with the crappy old 80 yr old MIL-H-5606 fluid.  Get Viton O-rings installed in your calipers and go with the updated (50 yr old) higher performance fluid MIL-PRF-83282 developed after the military got tired of putting out brake fires. Check the archives and get with the program. A brake fire will ruin your day.
-N1GV
In a message dated 8/27/2009 7:56:01 P.M. Pacific Daylight Time, bmeyette(at)gmail.com writes:
Ed Anderson
PostPosted: Fri Aug 28, 2009 3:30 am    Post subject: recommended RV brake fluid Reply with quote
Having experienced a ruptured brake line and ensuing brake fluid fire while using the 5606 fluid (Flash point around 240F), I strongly agree – use the Mi.-PRF-83232 – it’s flash point is around 440F. The nice part is - it’s fully compatible with the 5606 fluid so you don’t have to flush your lines or replace type of seal. Naturally the more 5606 left in the system the lower the flash point from that of pure 83232. So using this fluid requires no changes to the installation – and since it is compatible with 5606 – you could always add 5606 (available at any FB0) if you find yourself needing brake fluid while away from your gallon of 83232.
I would also suggest considering stainless steel, Teflon lined or other “real” brake lines. My aluminum tubing apparently fatigued and blew a chunk of the tubing wall out after an aborted take off (hot rotors). This could have been a result of me “working” hardening it while curving it around the landing rod, unnoticed damage or just material failure – but whatever the cause, you want to avoid it. But, the spraying of the low flash point 5606 on the hot rotor caused the real excitement. The resulting fire ball rose above the wing (as seen in video made by nephew), the brake peddle went to the floor and an excursion off the runway followed. Upon stopping, I popped the canopy and smelled burning resin - yes, the wheel pant was on fire and burning just below the full wing tank!! Fortunately, the fire was quickly put out and no damage to aircraft thanks to a small shallow ditch which arrested further progress.
I know the aluminum tubing has been around a long time and used successfully, but there have also been several reports of brake failure. At least the SS brake lines are more likely to start seeping fluid than having a catastrophic failure. The SS brake line less likely to fail. I even went to the effort of adding rotors with double the thickness of standard rotors. The idea was that given twice the mass of the thicker rotor the same heat content would raise its temperature less. The side benefit of the thicker rotors are no brake fade, more even wear on the pads and less frequent pad replacement.
Just my $0.02 YMMV
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://www.andersonee.com
http://www.dmack.net/mazda/index.html
http://www.flyrotary.com/
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.rotaryaviation.com/Rotorhead%20Truth.htm[url=http://www.dmack.net/mazda/index.html][/url]
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com
Sent: Friday, August 28, 2009 1:33 AM
-N1GV
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________
The message was checked by ESET NOD32 Antivirus.
Ed Anderson
Matthews, NC
eanderson@carolina.rr.com
khorton01(at)rogers.com
PostPosted: Fri Aug 28, 2009 4:43 am    Post subject: recommended RV brake fluid Reply with quote
The problem with MIL-H-5606 fluid is that it has quite a low flash
point (about 215 deg F). If your brakes are hot, and a line fails,
spraying brake fluid on the brake disk, you will have a fire. The
wheel pant will catch on fire too, and this whole thing is burning
away below the fuel tank. Several RVs have had brake fires.
Fortunately everyone so far has managed to get the fire put out
without losing the aircraft, but it is still something to attempt to
avoid.
MIL-PRF-83282 is a replacement to MIL-H-5606 that was developed by the
military, with a flash point of 470 deg F, or higher. It is fully
compatible with all the seals. It is not that much more expensive,
but it is a little harder to find. If you are on the road, and need
to top up your brake system, you can add some MIL-H-5606 fluid to the
MIL-PRF-83282, but the resulting mixture has a slightly lower flash
point.
I found Royco 782, a MIL-PRF-83282 fluid, at a local supplier (Leavens
Brothers in Toronto) for $12 a quart. It should be cheaper in the
USA. This fluid is specified for some corporate aircraft, so you may
find it at a local FBO.
Kevin Horton
Ottawa, Canada
On Thu, Aug 27, 2009 at 23:42, Brian Meyette<bmeyette(at)gmail.com> wrote:
[quote] Would you, or anyone, happen to know the Cleveland web site?  I googled
thanks,
brian
luck and fly safe.
rv(at)thelefflers.com
PostPosted: Fri Aug 28, 2009 5:41 am    Post subject: recommended RV brake fluid Reply with quote
Skygeek has Royco 782 for $8.14 a quart
http://www.skygeek.com/royco-782-synthetic-fire-resistant-hydraulic-fluid.ht
ml
bob
