Wing U-joint
Goto page Previous  1, 2
aslsa.rng(at)gmail.com
PostPosted: Fri Aug 28, 2009 5:10 am    Post subject: Wing U-joint Reply with quote
All, There's also the option of getting a couple of extra nuts and seeing which one tightens up properly and lets the cotter pin holes align. There will be variation in the nuts as to where the thread starts and you can use that to your advantage.
Rick Girard
On Fri, Aug 28, 2009 at 6:44 AM, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote:
[quote] At 11:32 PM 8/27/2009, WhiskeyVictor36(at)aol.com (WhiskeyVictor36(at)aol.com) wrote:
In a message dated 8/27/2009 12:22:03 P.M. Eastern Daylight Time, jdy100(at)comcast.net (jdy100(at)comcast.net) writes:
  I have used both of these ideas to remove play from the control fittings.  Sometimes I could not get the desired tightness even when changing washers.  That's when I used the grinding of the nut method...
I'd be more inclined to grind the washer rather than the nut, which could leave a sharp edge to rub on the bolt.  Or make a new washer out of shim stock.
-Dana
 We wonder why the dogs always drink out of our toilets, but look at it from their point of view: why do humans keep peeing into their water bowls?
tp://forums.matronics.com
zeprep251(at)aol.com
PostPosted: Fri Aug 28, 2009 5:41 am    Post subject: Wing U-joint Reply with quote
Just what I like,lots of mowed hay fields available for any eventuality.
PostPosted: Fri Aug 28, 2009 9:49 am    Post subject: Wing U-joint Reply with quote
In a message dated 8/28/2009 7:50:36 A.M. Eastern Daylight Time, d-m-hague(at)comcast.net writes:
I'd be more inclined to grind the washer rather than the nut, which could leave a sharp edge to rub on the bolt. Or make a new washer out of shim stock. -Dana
Dana,
That's a good idea. to thin the washer rather than the nut.
Bill Varnes
Original Kolb FireStar
Audubon NJ
JetPilot
PostPosted: Fri Aug 28, 2009 2:11 pm    Post subject: Re: Wing U-joint Reply with quote
I had the same problem, the castle nut was either too loose or too tight from one cotter pin detent to the next. John H advice is the best to use the thinner washers as needed, but I did not have any of John H non standard thickness washers, so I ground down a washer until it was perfect. I figured if I ruined a washer, no harm done, just get another one and try again.
Don't forget to grease that fitting in all exposed metal and everywhere it moves. This way you can have a tighter fitting, less play, without binding. It also protects the threads, and everything in there from corrosion.
Mike
Kolb MK-III Xtra, 912-S
Page 2 of 2
