capt_riney(at)yahoo.com Guest
Posted: Wed Aug 26, 2009 4:20 pm Post subject: Warp props and Rotax 582 |
I just bought a 66" 3 blade warp prop for my Mark III / Rotax 582. For those of you flying 582's, do I need a prop extension or will I have plenty of clearance? Thanks in advance for your thoughts.
Mark Rinehart
aslsa.rng(at)gmail.com Guest
Posted: Wed Aug 26, 2009 5:37 pm Post subject: Warp props and Rotax 582 |
The blades on the Warp Drive is pretty stiff. You should be fine. I've run tapered and straight blades and never had a clearance problem EXCEPT with poorly installed flap bellhorns. When I set them up per plans that problem went away.
Rick Girard
do not archiveaq
On Wed, Aug 26, 2009 at 7:14 PM, mark rinehart <capt_riney(at)yahoo.com (capt_riney(at)yahoo.com)> wrote:
[quote]--> Kolb-List message posted by: mark rinehart <capt_riney(at)yahoo.com (capt_riney(at)yahoo.com)>
Mark Rinehart
http://forums.matronics.com
le, List Admin.
elleryweld(at)aol.com Guest
Posted: Wed Aug 26, 2009 6:10 pm Post subject: Warp props and Rotax 582 |
Mark
I don't have an extension on my prop and I have a MK3 Classic with a warp drive prop
Ellery in Maine
kolber2(at)atcyber.net Guest
Posted: Wed Aug 26, 2009 6:50 pm Post subject: Warp props and Rotax 582 |
Mark,
I also have a Mark IIIc with Warp Drive (3 bladed). It has a 582 with B gearbox and no extension. Clearance has not been a problem.
Gary Siegrist
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ellery Batchelder Jr
Sent: Wednesday, August 26, 2009 9:04 PM
Subject: Re: Warp props and Rotax 582
Mark
Ellery in Maine
Mark,
Gary Siegrist
Mark
Ellery in Maine
lcottrell
Posted: Wed Aug 26, 2009 7:20 pm Post subject: Warp props and Rotax 582 |
I have a 66 inch warp on my Firestar mounted on an HKS motor. I first used it without an extension, I can't remember how many hours, but the drumming from the prop ended up cracking the Poly fiber paint on the right wing. Little spider cracks. Granted the fabric is not quite as tight as it could have been, but I put an extension on it and the reduction in noise was worth it. There was enough clearance and the wrap is stiff enough you aren't going to have any trouble, but If you have one handy, I personally would put it on.
Larry C
by0ung(at)brigham.net Guest
Posted: Sun Aug 30, 2009 1:49 pm Post subject: Warp props and Rotax 582 |
Mark Rinehart
| Quote: | >>>>>>>>>>>>>>>>>>>>>>.
Don't worry only about the clearance
The extension will give you better performance, quieter operation.
Boyd Young
HShack(at)aol.com Guest
Posted: Sun Aug 30, 2009 6:10 pm Post subject: Warp props and Rotax 582 |
If you have a "B" box, I think the prop inertia will be too great. It may work for years & years, but maybe not......
Shack
In a message dated 8/30/2009 5:50:10 P.M. Eastern Daylight Time, by0ung(at)brigham.net writes:
| Quote: | --> Kolb-List message posted by: "b young" <by0ung(at)brigham.net>
Mark Rinehart
Boyd ======================== the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
