kitfox555(at)sbcglobal.ne Guest
Posted: Sun Aug 30, 2009 3:35 pm Post subject: starter wire breaking |
This is the second time my starter positive wire has broke at the connection on the starter bolt, has anyone had this happen to them? I'm thinking of adding a zip tie around the wire and the starter to stop the vibration that makes the wire connector to break off just before the nut that tightens it on the starter, 582 Grey head, any input would be great thanks, Jerry
Jerry Evans
KitfoxII
Magalia Calif.
N582'er'
kitfox 555
Tom Jones
Posted: Sun Aug 30, 2009 5:19 pm Post subject: Re: starter wire breaking |
Jerry, is the wire the stuff that came with the original Kit? The starter wire that came with my kit was way too stiff. It was about 10 or 12 strands of thick copper. Mine broke at the same spot as yours about a week after the first flight. I replaced it with some marine wire from the boat shop. It is lots and lots of fine copper strands and very flexible. Looks about like welding lead but has a red jacket. 75 hours now and no more problems.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Paul A. Franz, P.E.
Posted: Sun Aug 30, 2009 5:43 pm Post subject: starter wire breaking |
On Sun, August 30, 2009 4:31 pm, jerry evans wrote:
| Quote: | This is the second time my starter positive wire has broke at the connection on the
break off just before the nut that tightens it on the starter.
That will probably do it. If you can restrain the vibrating cable at half the
unrestrained length that will roughly double the natural frequency of vibration as
well as restrict the amplitude. Both effects will likely extend the connector life
considerably if not totally eliminate the problem. On the downside, it might just
break in a different place next time. The restraint needs to be tight and the clamping
stress spread out enough to prevent crushing and insulation damage.
Paul Franz
425.440.9505 (O)
425.241.1618 (C)
"Freedom had been hunted round the globe; reason was considered as
rebellion; and the slavery of fear had made men afraid to think. But
such is the irresistible nature of truth, that all it asks, and all it
wants, is the liberty of appearing."
-- Thomas Paine, Rights of Man, 1791
"The essence of Government is power; and power, lodged as it must be
in human hands, will ever be liable to abuse."
-- James Madison
"[J]udges, therefore, should be always men of learning and experience
in the laws, of exemplary morals, great patience, calmness, coolness,
and attention. Their minds should not be distracted with jarring
interests; they should not be dependent upon any man, or body of
men."
-- John Adams
"When a business or an individual spends more than it makes, it goes
bankrupt. When government does it, it sends you the bill. And when
government does it for 40 years, the bill comes in two ways: higher
taxes and inflation. Make no mistake about it, inflation is a tax and
not by accident."
-- Ronald Reagan
If you don't read the newspaper you are uninformed, if you do read
the newspaper you are misinformed.
-- Mark Twain
"Liberty has never come from the government. Liberty has always come
from the subjects of government. The history of liberty is the
history of resistance. The history of liberty is a history of the
limitation of governmental power, not the increase of it."
-- President Woodrow Wilson (1856-1924)
_________________ Paul A. Franz, P.E.
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
icubob(at)gmail.com Guest
Posted: Mon Aug 31, 2009 4:57 am Post subject: starter wire breaking |
jerry,
fine stranded wire from a welding supply is a must if you dont already have it. also, some place along the wire you can attach it to the starter will help. last, a lot of solder following the strands out of the attach fitting i think makes the wire more likely to fail from movement.
bob noffs
On Sun, Aug 30, 2009 at 8:33 PM, Paul Franz <paul(at)eucleides.com (paul(at)eucleides.com)> wrote:
[quote]--> Kitfox-List message posted by: "Paul Franz" <paul(at)eucleides.com (paul(at)eucleides.com)>
| Quote: | break off just before the nut that tightens it on the starter.
Paul Franz
425.440.9505 (O)
425.241.1618 (C)
-- James Madison
men."
-- John Adams
not by accident."
-- Ronald Reagan
-- Mark Twain
Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
