		| Author | Message |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Fri Mar 31, 2006 2:13 am    Post subject: Tail plane Pip Pin Cover |   |
				| Richard, Apart from covers it's worth considering getting rid of the ring in
the pip pins so that all of the holes can be much smaller. A small piece of
 steel in the hole the ring goes through allows you to fish the pip pin out
 and replace it with a tool that has a spiral groove that screws on to the
 pip pin and pulls up  the central portion of it, thus disengaging the pips.
 The tool is only about a centimetre in diameter, (lives on the ignition key
 ring), and the access holes in the tail planes and wing roots only need to
 be slightly wider. This makes the system pretty much tamper proof, so that
 no passing youth can readily go off with a pip pin to see how well the plane
 flies without it, and also covering the hole with a small circle of sticky
 white plastic is neat and easy. Regards, David Joyce, G-XSDJ
		| Back to top |  |
		| rogerjohnsheridan(at)yaho Guest
				|  Posted: Sat Apr 01, 2006 2:15 am    Post subject: Tail plane Pip Pin Cover |   |
				| I like that idea David, would you mind emailing me a pic or details
of the tool sometime please (no rush).
 Much appreciated,
 Roger
 On 31 Mar 2006, at 11:07, David Joyce wrote:
  	  | Quote: |  	  | <davidjoyce(at)doctors.org.uk>
 the ring in
 piece of
 pin out
 to the
 the pips.
 ignition key
 need to
 so that
 the plane
 sticky
		| Back to top |  |
		| pete(at)lawless.info Guest
				|  Posted: Sat Apr 01, 2006 3:27 am    Post subject: Tail plane Pip Pin Cover |   |
				| Even simpler, get rid of the ring and just make a hook from some stiff wire.
It's very easy to just hook the pins out.  The same hook works on the wing
 pins.  This leaves you with a hole just big enough to get the pip pin down.
 Pete
		| Back to top |  |
		| nwcmc(at)tiscali.co.uk Guest
				|  Posted: Sat Apr 01, 2006 5:04 am    Post subject: Tail plane Pip Pin Cover |   |
				| It helps to mark the orientation of the hole on the head of the pip pin because
it is not easy to see when the pin is installed. I found that the small long
 nosed pliers I carry in my travelling tool kit extract and insert the pins
 with ease should a hook tool not be readily available.
 Nigel Charles
  	  | Quote: |  	  | -- Original Message -- From: "Pete Lawless" <pete(at)lawless.info>
 Subject: RE: Tail plane Pip Pin Cover
 Date: Sat, 1 Apr 2006 12:23:23 +0100
 Reply-To: europa-list(at)matronics.com
 Pete
 Tiscali Broadband from 14.99 with free setup!
 http://www.tiscali.co.uk/products/broadband/
		| Back to top |  |
		| scrimm
				|  Posted: Sat Apr 01, 2006 6:25 am    Post subject: Tail plane Pip Pin Cover |   |
				| Go to my gallery on the Europa Owners site and you will see a couple of pics
of "Split-Ring" pliers.  They are just the thing with a flat arm on one side
 and the other is bent at 90 degrees it does the perfect job.
 Here is the link
 http://www.europaowners.org/modules.php?set_albumName=album48&op=modload&nam
 e=gallery&file=index&include=view_album.php
 Steve
 N42AH
 A058
 Steve Crimm
 N42AH
		| Back to top |  |
		| paul.mcallister
				|  Posted: Sat Apr 01, 2006 6:42 am    Post subject: Tail plane Pip Pin Cover |   |
				| Hi All,
 Some time ago "somewhere" I saw some photographs where a pair of long nosed
 pliers were modified so the ends of the were bent / ground so that the would
 go into the holes in side of he pip pin where the ring normally goes.  It
 seemed to be a neat idea, does this ring a bell with anyone ?
 Paul
		| Back to top |  |
		| astills(at)cox.net Guest
				|  Posted: Sat Apr 01, 2006 8:02 am    Post subject: Tail plane Pip Pin Cover |   |
				| Paul,
I also saw that photo and made a pair of the long nose pliers for the pip
 pins. Just get a pair of needle
 nose pliers and cut off one end, then bend the other "long" end over so it
 touches. Works great on
 the pip pins. Take out the ring and you have a great remove and installer.
 Al Stills
 N625AZ
		| Back to top |  |
		| scrimm
				|  Posted: Sat Apr 01, 2006 9:04 am    Post subject: Tail plane Pip Pin Cover |   |
				| Paul,
 Those were my pliers that I did.  What happens was that the metal was
 hardened and the bend didn't last.  Then I found the split ring pliers at
 Bass Pro Shot and they are perfect.
 Steve
 Steve Crimm
 N42AH
		| Back to top |  |
		| Bill & Sue
				|  Posted: Sun Apr 02, 2006 4:08 am    Post subject: Re: Tail plane Pip Pin Cover |   |
				| If you push a suitable rod (small screwdriver) up through the drain hole it will retract the locking balls and push the pip-pin up without needing any special tools.
This way you can make the pip pin holes just big enough for the pin itself.
 We only worked this out after spending hours making a screw cap for the pip-pins before deciding that a couple of cm of tape was neater, lighter and simpler.
 Bill and Sue
 465 Trigear. Still finding an infinite number of minor jobs to do on the airframe.
		| Back to top |  |
