		etzimm(at)gmail.com Guest
				 Posted: Mon Aug 31, 2009 6:24 pm    Post subject: Kolb gph fuel burn survey |
				All Kolbers,
 I'm curious what other kolb pilots are experiencing as their gallon
 per hour fuel burn?
 What is your sustained level flight absolute minimum gal, per hr?  At
 what engine rpm?   And at what cruise speed?
 What is your over all  "average" gal. per hr.   engine rpm, and
 cruise speed?
 Please specify the model of your plane and engine when you share your
 statistics.
 Statistic from  flights of 2 hours or longer will likely be more
 accurate and reliable  than shorter flights, but please share whatever
 you personally experience with your plane.
                             Eugene Zimmerman
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Richard Pike
				 Posted: Mon Aug 31, 2009 7:30 pm    Post subject: Re: Kolb gph fuel burn survey |
				MKIII, 582, 2.58:1 B box, 2 blade 68" Ivo, 4 GPH (at) 5,200 rpm & 65 mph
 FSII, 582, 2.58:1 B box, 2 blade 68" Ivo, 3.5 GPH (at) 4,800 rpm & 62 mph
 Richard Pike
 MKIII N420P (420ldPoops)
		WhiskeyVictor36(at)aol.co Guest
				 Posted: Mon Aug 31, 2009 7:37 pm    Post subject: Kolb gph fuel burn survey |
				In a message dated 8/31/2009 10:24:25 P.M. Eastern Daylight Time,  etzimm(at)gmail.com writes:
    	  | Quote: | 	 		     What is your over all  "average" gal. per hr.      engine rpm, and
 cruise speed?
    Gene Z,
    This is my average for a 1 to 2 hour    flight and includes taxi, warm up, takeoff, landing and taxi again, such as    during my trips to Homers picnics:
    Original style - Kolb FireStar
    Rotax 447
    5000 RPM = 2.0 GPH
    Airspeed about 60 to 65 in smooth air (drops to 55~60    in bumpy air)
     I don't know what the fuel burn is during cruise    only.
    Bill Varnes
 Original Kolb FireStar
 Audubon NJ
 Do Not    Archive
		flykolb(at)pa.net Guest
				 Posted: Mon Aug 31, 2009 7:49 pm    Post subject: Kolb gph fuel burn survey |
				Richard,
 Do you have any gph figures on a slower speed cruise?
 Guesses?
 Dennis
		aslsa.rng(at)gmail.com Guest
				 Posted: Mon Aug 31, 2009 8:14 pm    Post subject: Kolb gph fuel burn survey |
				Eugene, I'll be out of phase one testing and going off to breakfast at Ponca City this Saturday. I'll do a careful test going there and back with my 582 powered Mk IIIC.
 Rick Girard
 On Mon, Aug 31, 2009 at 9:21 PM, Eugene Zimmerman <etzimm(at)gmail.com (etzimm(at)gmail.com)> wrote:
 [quote] --> Kolb-List message posted by: Eugene Zimmerman <etzimm(at)gmail.com (etzimm(at)gmail.com)>
  All Kolbers,
  I'm curious what other kolb pilots are experiencing as their gallon per hour fuel burn?
  What is your sustained level flight absolute minimum gal, per hr?  At what engine rpm?   And at what cruise speed?
  What is your over all  "average" gal. per hr.   engine rpm, and  cruise speed?
  Please specify the model of your plane and engine when you share your statistics.
  Statistic from  flights of 2 hours or longer will likely be more accurate and reliable  than shorter flights, but please share whatever you personally experience with your plane.
                             Eugene Zimmerman
  http://forums.matronics.com
  le, List Admin.
		Thom Riddle
				 Posted: Tue Sep 01, 2009 3:26 am    Post subject: Re: Kolb gph fuel burn survey |
				Eugene,
 Yesterday I did a 1.5 hour flight at a steady 2,640 rpm and true airspeed of 80 mph at a density altitude of about 2,500'. Total fuel burn of 5.5 gallons for burn rate of 3.67 gph or almost 22 mpg. These numbers include taxi, short warm up, one take-off and climb to about 1800 AGL, one descent and landing and taxi back. On my next flight I plan to do a similar flight at a slower speed, probably around 72 mph and will report my numbers.
 Note that the max continuous spped for the Jabiru engine is 3300 rpm but I am currently over propped and it won't reach that rpm in straight and level flight. My prop is a Tennessee Wood 66x34, which I think is too long for a Jabiru engine.
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		Thom Riddle
				 Posted: Tue Sep 01, 2009 3:33 am    Post subject: Re: Kolb gph fuel burn survey |
				Eugene,
 I forgot to mention that I also tested for minimum power flight. Without use of flaperons I got down to sustained S&L flight at only 2,232 RPM and 55 mph airspeed. I think it might go to a little less power cruise but this is only 10 mph over my stall speed so I didn't bother to reduce power any more.
 In case anyone is wondering why I'm quoting such un-rounded tach numbers, for some reason, my EIS tach reading is in increments of 24 rpm. Have not figured out why that is, maybe the sensor is reading flywheel teeth. I have not yet dug into that but will.
Buffalo, NY (9G0)
- Anonymous |
		Jimmy Young
  Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
				 Posted: Tue Sep 01, 2009 4:25 am    Post subject: Re: Kolb gph fuel burn survey |
				Firestar II with the HKS:
 2.8 hr flight on Sunday, good combination of cruise at 5200-5400 rpm, slow flight at 4700 rpm, full power climbs, 3 take offs & landings, burned avg. of 2.5 gal/hr.
  _________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
		Ralph B
				 Posted: Tue Sep 01, 2009 6:41 am    Post subject: Re: Kolb gph fuel burn survey |
				Original Firestar, Rotax 447, 2.58 B box, 2-blade 66" Ivo, 2.7 GPH at 5100 rpm, regular 87 oct ethanol 10% fuel, 60mph
 Kolbra, Rotax 912 80hp, 3-blade Warp Drive, 3.5 GPH at 5000 rpm, regular 87 oct ethanol 10% fuel, 80mph
  _________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
		dalewhelan
  Joined: 11 Nov 2008 Posts: 105 Location: USA ARIZONA fountain hills
				 Posted: Tue Sep 01, 2009 8:57 am    Post subject: Re: Kolb gph fuel burn survey |
				Firestar II 503 DCDI 66" Ivo 2 blade pitched for 6,400 on climb 2.58:1 B box
 32:1 with 87 octane fuel
 Flight started with 320 pound load and 10 gallons of fuel.
 Air temp at surface was about 95 relative humidity 20% Altimeter 29.86" Haze
 Flew between 4,500 and 5,500 msl
 Surface is about 1,300 AGL
 Made landings at three airfields.
 1.8 hours (at) 5,800 RPM
 Average indicated airspeed at cruise 70 MPH
 Fuel burn Five gallons
 2.7 GPH
 Cruise EGT 1,050
 Climb EGT 950, main jets on order
  _________________ Dale Whelan
503 powered Firestar II, Luscombe 8A
Projection, A simple and interesting Psychological concept |
				 Posted: Tue Sep 01, 2009 10:24 am    Post subject: Kolb gph fuel burn survey |
				MKIIIC Redrive 2180cc VW 71" PowerFin F model 3 blade 4GPH (at) 75 MPH 3200 RPM
 on a 2-3.5 hour cross country.
 An interesting change occurred on the flight to the Purdy field fly in. The
 flight was exactly 2 hours round trip winds < 5 MPH both directions. On the
 way there I flew my normal 75 MPH indicated for app. one hour. On the way
 back I flew in a loose formation at 70 MPH. The total fuel burn was exactly
 6.25 gallons I emptied my 6 gallon aux tank just before landing to top off
 the main tanks. This also included a brief period of flight close to 80 MPH
 (at) 3400 RPM to catch up. My MKIIIC really doesn't like to fly faster than 75
 MPH and it appears there is considerable drag reduction, fuel economy by
 slowing to 70 MPH.
 Rick Neilsen
 Redrive VW powered MKIIIC
		Dana
				 Posted: Tue Sep 01, 2009 1:21 pm    Post subject: Kolb gph fuel burn survey |
				UltraStar with Cuyuna ULII-02:
 3.3GPH overall (taxi, climb, cruise, landing) with 5800 rpm cruise (50-55 mph).
 5 gallons won't give me a hour flight!
 Extended slower cruise flights are on my agenda.
 -Dana
 At 10:21 PM 8/31/2009, Eugene Zimmerman wrote:
  	  | Quote: | 	 		  I'm curious what other kolb pilots are experiencing as their gallon
 per hour fuel burn?
 cruise speed?
 statistics.
   "If I knew there were coming to my house a man with the fixed intention
 of doing me good I would run for my life." - Thoreau
		2danglico
				 Posted: Wed Sep 02, 2009 4:01 am    Post subject: Re: Kolb gph fuel burn survey |
				I'd like to weigh in, although my #'s are less than impressive by what I've seen so far.
 Original Firestar
 447 2.58:1
 66" Culver
 5500 rpm
 63 mph
 3.3 GPH
		Thom Riddle
				 Posted: Wed Sep 02, 2009 7:41 am    Post subject: Re: Kolb gph fuel burn survey |
				I did another constant rpm flight today at a slower airspeed.
 2352 RPM
 65 mph TAS
 2200' Density Altitude
 1.6 hours flight time, including taxi etc.
 4.75 gallons consumed
 2.97 gph
 ~22 miles per gallon
 Earlier numbers at higher speed:
 2640 RPM
 80 mph TAS
 2,500' Density Altitude
 1.5 hours flight time, including taxi etc
 5.5 gallons consumed
 3.67 gph
 ~22 mpg
 I am surprised that my MPG is virtually identical to the run at 80 mph. I was expecting at least a little better mpg at the slower speed. Perhaps the sweet spot for my airplane is somewhere in the middle of that range. Next flight I'll split the difference and fly at about 72-73 mph and see if there is any difference. Could be that it is a 22 mpg airplane, no matter what airspeed I fly in this range.
Buffalo, NY (9G0)
- Anonymous |
		dalewhelan
				 Posted: Wed Sep 02, 2009 5:37 pm    Post subject: Re: Kolb gph fuel burn survey |
				Being new to this stuff I was surprised to find GPH was the same in my plane from 50-70. Then I realized the power setting in my plane is the same for all those speeds when I have a passenger (my back seat is seldom empty) My best fuel economy is (at) 70.
		rlaird
				 Posted: Wed Sep 02, 2009 6:25 pm    Post subject: Kolb gph fuel burn survey |
				Kolb MkIIIC w/ 912ULS
 I normally cruise at 75... that's around 4500 rpm, and 3.8 gph
 At 85, about 5000 rpm, and 4.2 gph.
 Don't have info, yet, on slow.
   -- Robert
  All Kolbers,
                             Eugene Zimmerman
  le, List Admin.
  _________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
formerly: MkIIIc w/ 912ULS  &  Gyrobee
current:  Autogyro Cavalon w/ 914ULS
Houston, TX area
http://www.Texas-Flyer.com |
				 Posted: Fri Sep 04, 2009 9:27 am    Post subject: Kolb gph fuel burn survey |
				Thank you all,
 I  wish to express my appreciation for everyone's  response to the
 fuel  burn query.
 We apparently have quite a spread in hourly fuel use between various
 Kolb planes and pilots.
  From Jack Hart's 1.5 gph all the way to John Hauck's 582 with  5.5 gph.
   Some pilots  choose to cruise at 40/ 55 mph, others at 70/85 mph.
 One pilot claims his  best fuel economy is (at) 70.
 My l stats  with my modified Firestar, 618 Rotax 72" inflight IVO prop
 are ,,,,
 42/ 50 mph air speed --  2 gph  as per 2 hour flight time.
 60/65  mph air speed --  3.5 gph as per 2 hour flight time.
 Wide open  6700 rpm climb out  7.5 gph  as per fuel flow gauge
 indication.
 Thanks again to everyone who responded,
 Gene Zimmerman
 On Aug 31, 2009, at 10:21 PM, Eugene Zimmerman wrote:
  All Kolbers,
  per hour fuel burn?
  cruise speed?
  your statistics.
                            Eugene Zimmerman
		gliderx5
				 Posted: Sat Sep 05, 2009 1:29 pm    Post subject: Kolb gph fuel burn survey |
				Malcolm Morrison
 MKII, 503SCSI, 3 blade Ivo
 5500 RPM, 60 MPH, 3.6 GPH
