Voltage Drop / amp ?????
fstringham
PostPosted: Thu Jul 23, 2009 9:38 am    Post subject: Voltage Drop / amp ????? Reply with quote
I have wired my RV7A with the 13/8 revision L. I did modify it to include the LR3C Alternator controller in place of genric Ford Regulator and the AEC9005-101 Low Voltage Module. In looking at the 13/8 revision Q there is an addition of a S704-1 / diode combo added to the Main Battery Bus / Endurance Bus / Endurance Bus Switch. I also have noted that a AEC9001 Schottky Diode can be used in place of a bridge diode.
As I notded in a previous email. 1. When the master switch is closed the voltage showes around 10.8 volts with rock solid amps indication on the Dynon D-120 EMS. When the endurance switch is closed the Voltage moves up to 12.8 or 12.9 and the amps meter begins to fluctuate. Open the Master Switch thus having the load go to only the endurance bus side the voltage maintains at 12.8 to 12.9 volts and the amps still fluctuates. This situation happens with or with out the engine running. The battery maintains charge.
Since I sent the last email I have learned that the bridge diode will cause a drop in voltage. (Even this 62 year old guy can learn stuff....) C but I would have though it would cause the endurance voltage to be less on the endurance bus side not the main bus side with the master switch closed.???????
Now the questions. 1. Why the addition of the S204-1 / diode combo added at the endurance bus switch and will it be of value in my configuration to added it. 2. Would it be of value to added the Schottly in place of the bridge diode. I would think yes if the voltage drop is less and thus give a more accurate voltage reading. 3. Why the higher voltage drop on the Main Bus as compared to the Endurance Bus? 4. Whay the conflicting amp reading between the Main vs Endurance Bus.
Thanks in advance for any help in this matter
Frank (at) 1L8 ...RV7A... Phase 1 underway
Windows Live™ Hotmail®: Celebrate the moment with your favorite sports pics. Check it out. [quote][b]
PostPosted: Fri Jul 24, 2009 7:01 am    Post subject: Voltage Drop / amp ????? Reply with quote
include the LR3C
Bus Switch.
of a bridge diode.
As I noted in a previous email. 1. When the master switch is closed the voltage
shoes around 10.8 volts with rock solid amps indication on the Dynon D-120 EMS.
From this I deduce that your Dynon is measuring the e-bus voltage.
Indeed, with master switch ON and alternator not running, the main
bus would normally be a about 12.5 volts. An expected 0.7 volt drop
in normal feed diode produces an e-bus voltage on the order of
11.8 volts.
to 12.9 volts
Okay, with the alternator OFF the battery-only voltage would
be expected to fall in this range. When you say the amps
"fluctuates" what's the max-min numbers displayed?
This situation happens with or without the engine running. The
With the engine running, do you turn the alternator ON to
see if it elevates the bus to the nominal 14.2 to 14.6 volts?
cause a drop in voltage. (Even this 62 year old guy can learn stuff....),
Then the Dynon is NOT monitoring the e-bus? If you close the
e-bus alternate feed switch and the Dynon display goes UP,
then it appears that the Dynon is on the e-bus.
Now the questions. 1. Why the addition of the S204-1/diode combo added at
it?
Don't know what an S204-1 device is . . . and don't know why
ANY diode would be wired to the e-bus alternate feed switch.
2. Would it be of value to added the Schottly in place of the bridge diode?
Slightly . . . but from the readings you cite it's not clear
that the Dynon is connected to the Main bus . . . hence SOME
degree of bus votlage suppression would be expected.
voltage reading.
The voltmeter is already ACCURATE. It's showing the votlage
at where ever it's attached. I'm guessing the e-bus. So all other
things being normal and functioning to design goals, the readings
are expected and normal.
Endurance Bus?
With engine not running and alternator OFF . . .
Get out a voltmeter and connect the (-) lead to the battery (-)
or to airframe ground. With master switch ON, E-bus alternate
feed switch OFF, measure and record main and e-bus voltages.
Turn E-Bus alternate feed switch ON and repeat the measurements.
Leave B-Bus switch ON turn master switch OFF and repeat the
measurements.
With engine running and alternator ON . . .
With master switch ON, E-bus alternate feed switch OFF,
measure and record main and e-bus voltages. Turn E-Bus alternate
feed switch ON and repeat the measurements. Leave B-Bus switch
ON turn master switch OFF and repeat the measurements.
4. Why the conflicting amp reading between the Main vs Endurance Bus.
I don't know WHAT your amp reading means nor how big the
fluctuations are. These are digital instruments with quantitization
errors that may well display some tiny wobble in readings even when
the actual value is steady. Are the strobes running? This would
cause an explain a jumpy ammeter reading.
We need DATA under various configurations in order to deduce
the whether the system is wired as designed and whether or
not the components are functioning as expected.
fstringham
PostPosted: Fri Jul 24, 2009 8:18 am    Post subject: Voltage Drop / amp ????? Reply with quote
Thanks Bob for the info. My next trip to the airport will begin the process of trouble shooting as you suggest.
In regards to this part of the email I made a typo..
Now the questions. 1. Why the addition of the S204-1/diode combo( should have been S704-1 / diode combo) added at
it?
Date: Thu C 23 Jul 2009 13:39:00 -0500
Subject: RE: Voltage Drop / amp ?????
--> AeroElectric-List message posted by: "Robert L. Nuckolls C III" <nuckolls.bob(at)aeroelectric.com>
include the LR3C
Bus Switch.
of a bridge diode.
Indeed C with master switch ON and alternator not running C the main
11.8 volts.
to 12.9 volts
Okay C with the alternator OFF the battery-only voltage would
With the engine running C do you turn the alternator ON to
cause a drop in voltage. (Even this 62 year old guy can learn stuff...) C
e-bus alternate feed switch and the Dynon display goes UP C
it?
voltage reading.
things being normal and functioning to design goals C the readings
Endurance Bus?
or to airframe ground. With master switch ON C E-bus alternate
feed switch OFF C measure and record main and e-bus voltages.
measurements.
With master switch ON C E-bus alternate feed switch OFF C
&gt
Windows Live™ Hotmail®: Search C add C and share the web’s latest sports videos. Check it out.
PostPosted: Fri Jul 24, 2009 9:31 am    Post subject: Voltage Drop / amp ????? Reply with quote
it?
Okay. The normal e-bus feed path diode shown on Figure
Z-11 . . .
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11M.pdf
shows an isolation diode between the main bus and
the endurance bus. The purpose of this device is
to PREVENT the main bus from being powered up
from the E-bus during battery-only operations.
If you're subscribing to the design goals described
for the endurance bus, then this diode is necessary.
Do I deduce correctly that this diode is not presently
a part of your current configuration?
( -Thomas Paine 1776- )
jimysymonds
PostPosted: Thu Sep 03, 2009 10:06 pm    Post subject: Re: Voltage Drop / amp ????? Reply with quote
You can play around with the others but if you want to work, the shoes has to be your choice.
Did you find this review helpful?
Size 12 shoes
