		donaho1(at)verizon.net Guest
				 Posted: Fri Sep 04, 2009 10:54 am    Post subject: Winching a Kolb |
				Hey Gene, I don`t know if winching is a word, however, I was wondering
 where you hook the winch cable to the airframe. I also trailer my FSII each
 time I fly. I hooked up a winch several years ago. I hooked the cable to
 the tail wheel strut and pulled the FSII up the ramps backwards. It worked,
 but seemed to put A LOT of stress on the tail wheel strut. After that one
 time using the winch I went back to pulling the airplane up using brute
 strength. I`m sure the day will come where I will need to go back to using
 the winch. Lanny N598LF
		Gene Ledbetter
  Joined: 10 Jan 2006 Posts: 20 Location: Cincinnati, OH
				 Posted: Fri Sep 04, 2009 11:25 am    Post subject: Winching a Kolb |
				Lanny,
 I pull my Firefly forward into the trailer.
 I connect the winch cable snap into the middle of a tiedown with hook
 ends looped over the landing gear legs.  Works great!
 Gene
  _________________ Gene D.
2000 Firefly
330 Hours
New 447
Brakes, Ivo |
		George Alexander
				 Posted: Fri Sep 04, 2009 11:49 am    Post subject: Re: Winching a Kolb |
				 	  | donaho1(at)verizon.net wrote: |
 = SNIP =
 I hooked the cable to the tail wheel strut and pulled the FSII up the ramps backwards. It worked, but seemed to put A LOT of stress on the tail wheel strut. After that one time using the winch I went back to pulling the airplane up using brute strength. I`m sure the day will come where I will need to go back to using the winch. Lanny N598LF |
 Lanny:
 Chris Mallory, former FSII driver, used a bracket he had made.  His set up is on my web site (link below) under "Trailering a Kolb".  If you want to go direct to Chris' tail wheel bracket, go to:
 http://home.comcast.net/~kolbplanes/CM_Winch_01.htm
 Thumbnails below the opening picture show the details.
  _________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
				 Posted: Fri Sep 04, 2009 1:12 pm    Post subject: Winching a Kolb |
				Gene and George thanks for the info. I will store that information in the
 hard drive in my brain for future reference. Also, while the tail wheel
 bracket is very nicely done, I still feel it will pull rather hard on the
 strut. It`s not exactly the strut I`m worried about, it`s the tubing the
 strut slides into that seems to take a lot of stress when using the winch.
 Perhaps the structure is strong enough to take the stress of a thousand
 winch assisted loadings. I just always try to treat my FSII as gently as I
 can, on the ground and in the air. Lanny
		WhiskeyVictor36(at)aol.co Guest
				 Posted: Sat Sep 05, 2009 8:12 pm    Post subject: Winching a Kolb |
				In a message dated 9/4/2009 5:12:45 P.M. Eastern Daylight Time,  donaho1(at)verizon.net writes:
    	  | Quote: | 	 		     while the tail wheel bracket is very nicely done, I still feel it    will pull rather hard on the
 strut. It`s not exactly the strut I`m worried    about, it`s the tubing the strut slides into that seems to take a lot of    stress when using the winch.
    Lanny,
    When running the break-in procedure for the Rotax    engine, the FireStar builders manual instructed me to tie the tail to    something solid, like a tree or an automobile, by threading the rope (or strap) around the tail post at    the boom tube.  Maybe that would be a point that you    could attach your winch to.
    Bill    Varnes
 Original Kolb FireStar
 Audubon NJ
 Do Not    Archive
