rlborger(at)mac.com Guest
Posted: Fri Sep 04, 2009 1:35 pm Post subject: Engine quits at full throttle |
Fellow Europaphiles:
I'm at 10.5 hrs on my XS Monowheel. (Just getting the hang of landing
it on pavement) As you can see from the signature block it has a
Rotax 914 and Airmaster C/S prop. On the last flight the engine
developed a surge and a miss at full throttle at about 500' on
takeoff. When I retarded the throttle and surge stopped and miss went
away. After immediate RTB, pulled the upper cowl and began an
inspection. 1st thing noticed was that it was not really obtaining
full throttle. Only about 37.5 in MP. Full throttle is 39 in MP and
37 - 38 in MP is in the unstable range for the turbo controller. That
explained the surging. Located the reason the throttle wasn't going
to max and fixed it. Also checked both fuel filters. Secondary was
fine. Main was had considerable crud so it was replaced. I can now
get full throttle. Re-synched the carbs. Runs nice and smooth.
Now here's what happened today on a full-power, chocks-in, tail tied
down, run-up test.
Engine starts immediately. I kept the idle at 2000 - 2100 RPM to warm
up.
Engine warmed up, all temps and pressures in the green. Prop
controller set Auto and T/O. Main and Boost pumps are both on,
Advance throttle. Everything is OK up to engine RPM 5790 & MP 36 in.
When the throttle is advanced beyond 37.5 in MP the engine quits.
Like fuel starved or ignition cuts out. It just quits.
Retard throttle back below 37.5 in MP and it re-starts and runs
smoothly.
Throttled back to 4000 RPM and did a "mag" check. Left-Off drop is
about 275 RPM, Right-Off drop is 305 - 310 RPM.
Throttle back to idle and shut off ignition, the engine stops and
after about 15 seconds there was a large backfire through the exhaust
(first time for that!).
Engine has only run on 100LL with appropriate amounts of Decalin TCP &
Marvel Mystery Oil to help with the lead situation. Oil is still nice
and clear.
Do any of you Rotax Gurus have a suggestion as to why the engine cuts
out when full throttle is applied? Any suggestion for things to check
and/or fix?
Thanks in advance for your help,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Posted: Sat Sep 05, 2009 5:14 am Post subject: Engine quits at full throttle |
Not that I am a rotax expert, but from my car tuning and racing experience,
I would suggest
that either your pump/s are not able to keep up with demand from the carbs
(unlikely, given
you are running two), you have and open return line??? (you did put the
restrictor in the return line
AFTER the carbs), or your carbs are WAY WAY TOO lean and you simply don't
have enough fuel entering
the engine to keep it running at full throttle. This is the most likely
situation IMHO assuming you have
the restrictor installed. An excessively lean mix could also account for the
lack of MP at full throttle.
No fuel to burn means no expanding gasses so no pressure to drive the
impeller side of the turbo, so less
boost than expected so a lower MP than expected.
You can get some good automotive lean/rich gauges for around $100 these day,
if you lift the needles in your carbs
a bit and it runs better, I would suggest you invest in one to get your mix
right. Failing that, you mentioned contaminated
fuel filter, have you checked to see if the fuel is leaving the tank freely,
by dropping the fuel line off the carb
and see how much fuel comes out when the pumps are on.
hope this helps
craig
kit 577
vh-xsv
_
mau11(at)free.fr Guest
Posted: Sat Sep 05, 2009 6:45 am Post subject: Engine quits at full throttle |
hI all,
is anyone know a solution for resolve the ignition shield to stop engine on the 912?
mau11
2009-09-05
En réponse au message
de : craig bastin
du : 2009-09-05 15:18:05
À : europa-list(at)matronics.com
CC :
Sujet : RE: Europa-List: Engine quits at full throttle
-- > Europa-List message posted by: "craig bastin" <craigb(at)onthenet.com.au >
I would suggest
(unlikely, given
hope this helps
craig
kit 577
vh-xsv
_
_-============================================================
_-= - The Europa-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= -- > http://www.matronics.com/Navigator?Europa-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= -- > http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= -- > http://www.matronics.com/contribution
rampil
Posted: Sat Sep 05, 2009 8:11 am Post subject: Re: Engine quits at full throttle |
Hey Bob,
Similar story on my flight tests. Check for soot on bottom of your
carbs. On mine, one of the exhaust pipes would come lose at full throttle only, and just enough to boil the fuel in one float bowl!
Good Luck,
Ira
Posted: Sat Sep 05, 2009 8:48 am Post subject: Engine quits at full throttle |
Ira,
Thanks. I'm going to run more checks tomorrow. I'll check for the
loose exhaust.
Best regards,
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Sep 5, 2009, at 11:11, rampil wrote:
Hey Bob,
Good Luck,
Ira
Ira N224XS
budyerly(at)msn.com Guest
Posted: Sat Sep 05, 2009 11:35 am Post subject: Engine quits at full throttle |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Bob,
Sorry to hear about your engine woes.
From my experience in the shop here are some things I've run into:
Check that there is not 912S restrictor in your return line for the 914. The restrictor is necessary in the 912S but Rotax forbids it in the 914. Make sure the return is not pinched either. See your install manual on line with Rotax.
Don't make the mistake of swapping the fuel intake line and return lines. (Believe it or not the engine runs, but goofs up the fuel metering as one would expect, and won't accelerate properly or hit top end.)
I hate to admit that I have seen one fuel pump hooked up backwards electrically, and due to plumbing wouldn't feed enough fuel for full power, but it would start...
Check your airbox and static pressure sensors aren't clogged or kinked, or worse yet still plugged.
The new 914s have the removable fuel pans, and easy access to the float bowls. Pull them and check for crap.
If dirty, get a rebuild kit and clean up the carbs.
Since you have 10 hours on your engine, it may be a mute point by now but fuel quality is a combination of the source and materials quality in the plane... Fuel lines are not shipped clean and there is residue in them as well as the tank. Fuel with ethanol will clean better than Av gas.
FBO's do filter their gas to a very high standard, but I find very fine white organic material in it that my filters found, so think about pre filtering your fuel. Since doing so I've had no problems.
My technique for assuring clean fuel tank and lines:
First. Get a pre filter funnel for your fuel. Fill the tank to the neck with 20 gallons of premium unleaded with ethanol. Shake the aircraft and check for leaks.
Next, disconnect the fuel delivery line at the engine fuel regulator and pump the fuel back into the cans, alternating between main and reserve sides. The filters will clean the tank. The pre tank filter funnel will clean the fuel going back in. Fill again, and allow to sit. More will settle, so repeat the fuel straining. Then I do it one more time (total of three times) to insure tank and more importantly the lines are clean. Fuel lines are notorious about being dirty. I don't use the filtering gas for my first engine run, I Premium gas or Av gas.
While doing the above, do a flow and pressure check. I have a valve hooked to the line off the aircraft fuel line with a T and fuel pressure gauge to check for fuel delivery pressure and and volume. It is also a good time to adjust the fuel flow measuring sensors. If you have in and out metering, hook the delivery line to the return line and circulate the fuel. Fuel flow should read zero. (912S owners can do this with one fuel flow device and the restrictor installed and measure the flow rate and pressure delivery with fuel returning to the tank.)
Bud Yerly
Custom Flight Creations
rsementi(at)gmail.com Guest
Posted: Sat Sep 05, 2009 11:27 pm Post subject: Engine quits at full throttle |
Always nice to hear your wisdom Bud!
Thanks,RS
On Sep 5, 2009, at 3:28 PM, "Bud Yerly" <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
[quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Bob,
Bud Yerly
acrojim7534(at)YAHOO.COM Guest
Posted: Sun Sep 06, 2009 3:51 am Post subject: Engine quits at full throttle |
On the full power check, with the plane tied down you stated that at 5790 RPM you had 36 inches MP. Then you stated when you advanced the throttle to past 37.5 inches MP the engine quit... What was the RPM at 37.5 inches MP ? Did the engine RPM exceed 5800 RPM ? to reach the 37.5 Inches MP ?
At 5800 RPM you should be seeing 39 to 40 inches MP.
When you installed the Airmaster prop, did you set the high RPM "stop" in the hub to limit RPM to 5800.??? In order to get full boost of the turbo you must have the throttle wide open, with the RPM's being goverened by the prop hub. This can only be done by setting the prop pitch to limit the max RPM to 5800.
If you did not, the Airmaster installation manual tells you how to do this. It must be done for proper operation of the engine. And also to prevent overspeed of the engine on takeoff....
Jim Brown
--- On Fri, 9/4/09, Robert Borger <rlborger(at)mac.com> wrote:
Subject: Engine quits at full throttle
Date: Friday, September 4, 2009, 9:29 PM
I'm at 10.5 hrs on my XS Monowheel. (Just getting the hang of landing it on pavement) As you can see from the signature block it has a Rotax 914 and Airmaster C/S prop. On the last flight the engine developed a surge and a miss at full throttle at about 500' on takeoff. When I retarded the throttle and surge stopped and miss went away. After immediate RTB, pulled the upper cowl and began an inspection. 1st thing noticed was that it was not really obtaining full throttle. Only about 37.5 in MP. Full throttle is 39 in MP and 37 - 38 in MP is in the unstable range for the turbo controller. That explained the surging. Located the reason the throttle wasn't going to max and fixed it. Also checked both fuel filters. Secondary was fine. Main was had considerable crud so it was replaced. I can now get full throttle. Re-synched the carbs. Runs nice and smooth.
Now here's what happened today on a full-power, chocks-in, tail tied down, run-up test.
Engine starts immediately. I kept the idle at 2000 - 2100 RPM to warm up
h&jeuropa
Posted: Sun Sep 06, 2009 6:29 am Post subject: Re: Engine quits at full throttle |
Did you try hooking up a computer to the TCU and using the TLR program so see what the TCU is seeing? There is the monitor portion of the software and also a history portion that collects some historical data. That might point you to the problem. Helped us a couple of weeks ago.
Jim & Heather
david.stanbridge(at)swift Guest
Posted: Sun Sep 06, 2009 10:52 am Post subject: Engine quits at full throttle |
I had exactly the same problem this weekend with the rpm cycling
between 4500 and 4800 on a 914 fitted with a Airmaster propeller. The
probem was found to be the sealing of the carburettor sumps to the
main body. After diassembling these to see if there was any crud at
the bottom, which there was not, and putting them together the issues
disappeared.
Hope this is of some help.
Dave Stanbridge
Posted: Sun Sep 06, 2009 12:11 pm Post subject: Engine quits at full throttle |
Fellow Europaphiles,
Update as of this morning, 2009 09 06.
Over the last two days, I have checked all the areas recommended by
you folks. Lots of good ideas! Thanks to those who took the time to
call. I appreciate all the help.
Everything checks out so far without tearing down the carbs. I've
reached the point where I need a better check of the airbox/fuel
differential pressure. It could very well be that there was
insufficient fuel pressure at full boost to over come that level of
boost. The UMA gage and sender I have installed seem to be binary,
either 0 or 1. And that's not right. It should read between 2 and 5
PSI. Tomorrow I'll be evaluating why the differential pressure isn't
reading properly.
I have completed six full power run-ups. Three yesterday and three
today. The engine performed perfectly at all times.
Engine started before three blades went by. Maintained idle in the
2000 - 2100 RPM to warm up.
Once the engine warmed up and all temperatures were in the normal
operating range I confirmed that the prop was in Auto and T/O.
Advanced the throttle slowly, watching RPM and MP.
At full throttle the engine was turning 5750 RPM and 39 in MP. Fuel
flow was 8.1 to 8.2 GPH (roughly 32 L/H for you folks in Europe).
Right on the chart numbers.
The engine was very smooth, no surging, no missing, no hesitations, no
sign of stopping.
I held it at full throttle for about 30 seconds and then brought it
back gently to idle. Allowed it to idle for a minute or so before the
next run to full power.
Yesterday and today, the final full power run was held for a full
minute.
After the final run, the throttle was gently returned to idle (1900
RPM) and the engine allowed to idle for at least 1 minute to allow the
turbo to cool down.
And the engine was shut down with the Ignition switches.
Tomorrow I will be looking at the differential pressure gage package
to see what's wrong with it. The 914 really needs an accurate
differential pressure indication.
I'll keep you posted,
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Sep 4, 2009, at 16:29, Robert Borger wrote:
down, run-up test.
warm up.
smoothly.
exhaust (first time for that!).
& Marvel Mystery Oil to help with the lead situation. Oil is still
nice and clear.
cuts out when full throttle is applied? Any suggestion for things
to check and/or fix?
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
