al38kit
Posted: Mon Sep 07, 2009 6:11 pm Post subject: Battery Maintainer and Dual System |
I picked up the Schumacher 1562A Charger-Maintainer...It looks like a neat unit...
Two questions...I would expect it should be a good choice for the odyssey batteries...right?
When I get around to attempting to put a maintainer on a dual system with two batteries, any good ideas on hooking up a maintainer?
Do you think a person should use two maintainers, or attempt to charge both batteries with one? I can see some potential for screw ups using one...
Al Kittleson
Granbury, TX
pwmac(at)sisna.com Guest
Posted: Mon Sep 07, 2009 6:54 pm Post subject: Battery Maintainer and Dual System |
I have 3 batts in my shop hooked up in parallel to one 1562A and sure
enough all three are fully charged when ever I check them. For my
rolling fleet I use a separate 1562 for each one. Its hard to drive
them all so the maintainer keeps them all topped up.
PW
At 08:11 PM 9/7/2009, you wrote:
a neat unit...
ups using one...
Al Kittleson
Granbury, TX
http://forums.matronics.com/viewtopic.php?p 61983#261983
bob.verwey(at)gmail.com Guest
Posted: Mon Sep 07, 2009 9:40 pm Post subject: Battery Maintainer and Dual System |
Paul, I was under the impression that due to differing states each battery will have to be charged separately to keep it "full" ?
Bob Verwey
A35 Bonanza ZU-DLW
On Tue, Sep 8, 2009 at 4:47 AM, paul wilson <pwmac(at)sisna.com (pwmac(at)sisna.com)> wrote:
[quote] --> AeroElectric-List message posted by: paul wilson <pwmac(at)sisna.com (pwmac(at)sisna.com)>
I have 3 batts in my shop hooked up in parallel to one 1562A and sure enough all three are fully charged when ever I check them. For my rolling fleet I use a separate 1562 for each one. Its hard to drive them all so the maintainer keeps them all topped up.
PW
| Quote: | --> AeroElectric-List message posted by: "al38kit" <alfranken(at)msn.com (alfranken(at)msn.com)>
Al Kittleson
Granbury, TX
http://forums.matronics.com/viewtopic.php?p=261983#261983
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Posted: Tue Sep 08, 2009 6:51 am Post subject: Battery Maintainer and Dual System |
After months and months each batt arrive at the same volts within the accuracy of my cheap meter. Seems to work fine. I have a large truck (size 65) flooded, a smaller deep cycle AGM for the VW diesel and a large (65) AGM all in parallel. Quite a diverse combination of batts. Bob will have to explain how my combo works.
PW
At 11:37 PM 9/7/2009, you wrote:
[quote]Paul, I was under the impression that due to differing states each battery will have to be charged separately to keep it "full" ?
Bob Verwey
A35 Bonanza ZU-DLW
PW
Al Kittleson
Granbury, TX
[url=http://forums.matronics.com/viewtopic.php?p 61983#261983] http://forums.matronics.com/viewtopic.php?p 61983#261983[/url]
le, List Admin.
