				 Posted: Wed Sep 09, 2009 8:45 am    Post subject: Was: Door locks Now Flaps |
				Jessie,
 	I try to minimize the number of times I cycle to flaps by
 leaving them down after landing and taxi back to my hangar. They stay
 down till I power up for my next start where I hit the flap up toggle
 while my PFD comes alive & I go through my start procedure. By the time
 my engine is primed the flaps are up and I am ready to crank the engine.
 I then put the 3 degrees in so as to not forget before take off. I
 actually have several reminders on my check list to put the 3 degrees in
 as it is an easy thing to overlook. This procedure minimizes the number
 of times I cycle the flap motor and also keeps the flaps out of the way
 of control surface damaging visitors.
 	I follow this procedure because I have hangars at both ends of
 my regular commute. I would have the flaps in the up position if/when I
 have to leave the plane outdoors overnight. I also retract the flaps
 anytime I an taxiing over surfaces with loose debris.
 Robin
		jeff(at)westcottpress.com Guest
				 Posted: Wed Sep 09, 2009 9:48 am    Post subject: Was: Door locks Now Flaps |
				I assume it's also advisable to retract the flaps when on the ground
 in any kind of high or gusty wind condition.
 Jeff Carpenter
 On Sep 9, 2009, at 9:37 AM, Robin Marks wrote:
  Jessie,
  time
  engine.
  degrees in
  number
  way
  when I
  Robin
