Posted: Thu Sep 10, 2009 9:17 am Post subject: 701/rotax battery cables |
I'm planning the electrical system on my 701 with a Rotax 912, no BRS. My
understanding is that the conventional setup for this configuration is to
place the battery behind the seats. I'm wondering about the gauge of the
cables that run up to the engine. My questions are:
- what gauge cable? The diagrams in the AeroElectric book call out 4 gauge.
Anyone using less, say 6 gauge? I could save a little weight here.
- dedicated ground cable or ground through the airframe? Again looking to
save weight.
-- Craig
lgold(at)quantum-associat Guest
Posted: Thu Sep 10, 2009 10:40 am Post subject: 701/rotax battery cables |
Craig,
Use 4 gauge welding cable since its more flexible. Don't skimp on cable size
unless you want problems starting or the potential of a fire! If you want to
get technical you can figure out how much heat and voltage loss you are
willing to accept. This depends upon the full-load current used by the
starter and the size and length of the cable; but I would just stick with
what we know works. There are better ways of saving weigh without risk (like
not using the heavy door handle/locks provided in my kit by Zenith).
Les
Posted: Thu Sep 10, 2009 10:48 am Post subject: 701/rotax battery cables |
Thanks Les. So do you have one or two cables (plus and ground) in your 701?
-- Craig
Posted: Thu Sep 10, 2009 5:17 pm Post subject: 701/rotax battery cables |
I used two cables from the battery Craig. I have found that the causes of
most electrical problems with instruments and starting is a result of a bad
ground... So I added a really good ground buss on the firewall. I attached a
4-gauge cable from the battery to the ground buss and also from this buss to
the engine block. All my grounds terminate at this buss except for the ones
from the fuel tanks, which I grounded locally. This is also a good way to
eliminate radio static. I purchased the ground buss and most of my
electrical parts from B&C (see http://www.bandc.biz/search.aspx?find=ground)
but I'm certain you could buy a ground buss elsewhere.
It's also very important to both crimp and solder the 4-gauge wire
terminals. A bad electrical connection here can heat up enough to melt stuff
and start a fire.
Les
NYTerminat(at)aol.com Guest
Posted: Thu Sep 10, 2009 6:16 pm Post subject: 701/rotax battery cables |
Craig,
I did the exact same as Les, except just crimped my connections. Works great no problems, 180 hrs
Bob Spudis
N701ZX/912S
In a message dated 9/10/2009 9:17:29 P.M. Eastern Daylight Time, lgold(at)quantum-associates.com writes:
| Quote: | used two cables from the battery Craig. I have found that the causes of
and start a fire.
Les
Posted: Thu Sep 10, 2009 6:17 pm Post subject: 701/rotax battery cables |
Thanks, I have and will use the B&C ground block.
-- Craig
