clrprop
Posted: Thu Sep 10, 2009 11:47 am Post subject: coolant question |
My 582 grayhead has the green antifreeze in it. Someone told me this is the wrong stuff to be using. I called Lockwood and they recommend rinsing it out and using Penzoil Dex-Cool, the orange stuff. The guy at the auto part store said only the yellow kind would mix ok with a motor that had been run with the green. If the remnants aren't boiled or steamed out, the orange and green would form a mud that could not be cleaned out.
Recommendations?
Keath T
MkIIIc
student, 3hrs and counting
aslsa.rng(at)gmail.com Guest
Posted: Thu Sep 10, 2009 2:54 pm Post subject: coolant question |
Flush the system out with distilled water and then change over. I did that with mine and I'm having zero problems.
Rick Girard
On Thu, Sep 10, 2009 at 2:47 PM, clrprop <ktony(at)windstream.net (ktony(at)windstream.net)> wrote:
[quote]--> Kolb-List message posted by: "clrprop" <ktony(at)windstream.net (ktony(at)windstream.net)>
Recommendations?
Keath T
MkIIIc
http://forums.matronics.com/viewtopic.php?p=262454#262454
le, List Admin.
Richard Pike
Posted: Thu Sep 10, 2009 6:51 pm Post subject: Re: coolant question |
[quote="aslsa.rng(at)gmail.com"]Flush the system out with distilled water and then change over. I did that with mine and I'm having zero problems.
Rick Girard
What Rick said. Several years ago I bought a Camry with the green stuff in it and wanted to go to the silicate free coolant. Drained it, filled it with water, ran it, drained it, and then simply parked it next to the hangar and stuck the hose in it and let the car run while the hose was stick into the radiator so that the excess would overflow.
After a half hour I drained it, mixed it 50/50 and never had a moments problem. Surely the Camry has a lot more places for the old coolant to hide than your Rotax system.
Richard Pike
MKIII N420P (420ldPoops)
clrprop
Posted: Fri Sep 11, 2009 3:22 am Post subject: Re: coolant question |
Sounds reasonable enough to me.
Thanks!
