Attaching door pins
kearney
PostPosted: Fri Sep 11, 2009 6:13 pm    Post subject: Attaching door pins Reply with quote
HI
I am ready to permanently install my door pins and am wondering about the best way do lock them in place. Is locktite acceptable or should I be using proseal / epoxy or something else? The threads seem somewhat loose so I want to get this right the first time.
Inquiring minds need to know.
Les
#40643 – living in f/g hell
AirMike
PostPosted: Fri Sep 11, 2009 9:42 pm    Post subject: Attaching door pins Reply with quote
I have the rivethead pins and used locktite. Seems to hold ok. Pro-seal might be better, but difficult to remove if the need comes.
See you OSH '18
Q/B - sold.
johngoodman
PostPosted: Sat Sep 12, 2009 6:26 am    Post subject: Re: Attaching door pins Reply with quote
Les,
You said the threads seemed somewhat loose - are you referring to the nut wobbling on the threads, or the grip part of the bolt wobbling in the hinges? I would think that a lock nut on an AN bolt would be pretty firm.
John
