		kearney
				 Posted: Sat Sep 12, 2009 10:00 am    Post subject: Attaching door pins - Clarification |
 The door pins I am referring to are the RivetHead door pins that contain
 magnets. They screw into the end of the C-1011 and C-1012 latch pins. The
 C-1011 and C-1012 are the forward / aft tubes that extend into the door
 frame when latching.
 I have tapped my tubes but the threads seem "loose" although they do hold
 properly when the door pins are fully screwed on. Perhaps this is because of
 the course nature of the threads.
 Cheers
 Les
 #40643 - living in fibreglass hell
		daveleikam(at)wi.rr.com Guest
				 Posted: Sat Sep 12, 2009 2:08 pm    Post subject: Attaching door pins - Clarification |
				I have the same RivetHead pins and noticed my threads a bit loose as well.
 I used red loctite high strength.  They are now very secure.
 Dave Leikam
 RV-10 #40496
 N89DA
 Muskego, WI
		kearney
				 Posted: Sat Sep 12, 2009 3:20 pm    Post subject: Attaching door pins - Clarification |
				Hi Dave
 Thanks for the info - it is just what I needed. It is good to know that you
 had the same experience with the thread looseness as well.
 Cheers
 Les
		capsteve(at)iflyrv10.com Guest
				 Posted: Sun Sep 13, 2009 7:23 am    Post subject: Attaching door pins - Clarification |
				LES,
     technically, the threads formed inside the door rods (with a tap) are
 not formed with the correct minor diameter because the inside diameter is
 not quite small enough. But,
  there is still plenty of "meat" for the threads to form on the rods. this
 will cause the magnetic tip to seem sloppy when screwing it on. once the
 shoulders mate, and cinched together the slop will disappear.
     If you think you need a little more:
 once the length is established there should be no reason to remove the
 bullet ends, so maybe a jb weld or structural epoxy would be a better
 choice over locktite. (not very good at filling voids)
  Also (another option) I've found that replacing the door rods with hard
 steel brake lines from napa worked well . the walls are thicker so they tap
 out to a tighter fit .
 Steve
 IFLYRV10.COM
 Sent: Saturday, September 12, 2009 1:57 PM
 Subject: RE: Re: Attaching door pins - Clarification
  of
  Cheers
  Les
