ChangDriver
Posted: Tue Sep 15, 2009 3:49 am Post subject: P-lead as a source for a tachometer |
I am trying to figure out how a p-lead is used as a signal source for a tach. Not how it is wired, but more of the theory behind it. Questions like:
1) what does the signal look like (square wave, sawtooth, sine, etc)
2) What is the typical amplitude
3) why is the p-lead a typical source of noise in the RF range
4) how is the signal produced when the original intent of the p-lead was as a way to ground the magneto and shut down the engine.
5) how do p-lead tachometers typically prevent from a failure that would ground the p-lead.
Craig
jindoguy(at)gmail.com Guest
Posted: Tue Sep 15, 2009 4:42 am Post subject: P-lead as a source for a tachometer |
Just curious, how will you check for rpm drop between mags if the tach goes dead when one p lead is grounded?
Rick Girard
On Tue, Sep 15, 2009 at 6:49 AM, Craig Winkelmann <capav8r(at)gmail.com (capav8r(at)gmail.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Craig Winkelmann" <capav8r(at)gmail.com (capav8r(at)gmail.com)>
Craig
http://forums.matronics.com/viewtopic.php?p=263104#263104
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Posted: Tue Sep 15, 2009 4:54 am Post subject: P-lead as a source for a tachometer |
At 06:49 AM 9/15/2009, you wrote:
<capav8r(at)gmail.com>
it. Questions like:
Very ragged sorta square wave. At least when the
points are closed, the waveform is steady at zero
volts. When the points open, the magnetic field
stored in the inductive iron is allowed to collapse
rapidly. Like the battery powered points/condenser/
coil Kettering system, this mechanically powered
energy storage system delivers a fast rising, high
voltage transient in the fine turns of the secondary
winding (spark energy) while a ratiometric image of
the same waveform appears across the now open windings
of the primary . . . or P-lead.
| Quote: | 2) What is the typical amplitude
The peak voltages can be on the order of 200-300
volts. It's an damped oscillatory waveform who's
period is set by the inductance/capacitance
combination of the system and damped by the loss
of energy that is running out to the spark plug.
| Quote: | 3) why is the p-lead a typical source of noise in the RF range
Any and all perturbations of current/voltage
magnitude can be called "noise". The RATE at which
they vary combined with amplitude of the change
sets the parameters for the frequency spectrum
over which the energy is distributed and propagates.
When I mentioned FAST rise time earlier, this suggests
an unusual opportunity for effects to extend well
up into the RF spectrum. When we combine that with
HIGH voltage, the energy signature becomes potentially
antagonistic.
FAST rise times is the key phrase that suggests why
shielding p-leads is useful. It's waveforms with
high dv/dt (differential) numbers that propagate
electro-statically from one conductor to another.
| Quote: | 4) how is the signal produced when the original intent of the p-lead
The P-lead is connected in parallel with the points
which are themselves connected in parallel with the
primary winding of the magneto's pulse transformer
and the damping condenser. Closing the switch at
the end of a P-lead essentially keeps the "points
closed" all the time thus terminating the train of
sparks.
| Quote: | 5) how do p-lead tachometers typically prevent from a failure that
If poorly designed, yes. I've never seen one that
offer this risk. The design goal for a tachometer that
watches magneto p-leads is to first offer a load
impedance that is sufficiently high as to NOT load
normal operation of the magneto. The next task is
to figure out a way to ignore the trash on the p-lead
waveform that might be mis-interpreted as a signal
proportional to engine RPM. My favorite way to do
this is with an active band-pass filter that only
allows the frequency of interest (30 to 150 Hz)
to pass. My last crack at a smoothing circuit followed
the band-pass filter with a phase-locked loop that
produced a pristine square wave that would not
upset the poorest of tachometers. The input impedance
to the system was over 1000 ohms. Incapable of
causing mischief in the ignition system
Posted: Tue Sep 15, 2009 5:14 am Post subject: P-lead as a source for a tachometer |
[url=http://www.matronics.com/forums/viewtopic.php?p 62838#262838] Posted: Sun Sep 13, 2009 3:46 pm Post subject: Re: Tachometer Generator Wiring [/url]
Bob:
The problem I have is that at RPM below 1000, I get noise in the signal and the tach jumps all over the place. Over 1000 RPM and all is fine. The radial engine idles at 500 rpm so this is a problem.
The tach gen wires go to a circuit that is a basically a voltage divider and a comparator to provide a clean pulse for the engine monitor system.
It has been suggested to 1) shield the tach gen wires to reduce noise, 2) add a 0.1 microfarad ceramic capacitor as a filter, and/or 3) change the voltage at which the comparator triggers (raise the limit for it to trigger).
Craig,
Sorry, I got side tracked by the use of the term
"tach generator" in your original posting. The
2-wire device you're describing is not the traditional
tach generator but SOME form of transducer. If it's
just a 2-wire device, it MIGHT be a permanent magnet
generator of some kind, most hall effect sensors
require a third wire to carry 5-12 volts out to the
tach TRANSDUCER's electronics. But a clever designer
COULD make halls work on the end of a two-wire loop
too. I suspect that the 500 rpm thing is the problem.
Your tach/instrument combination may well have been
crafted for the more common aircraft engines that don't
even IDLE at 500 RPM. If the transducer is a
magnet/coil signal source, the low speed operation may
well be producing a signal below the design goals by
which the system was crafted. The fact that your
difficulty clears up at higher speeds reinforces this
suggestion.
So you may be correct in your supposition that the
circuitry needs to be tweaked to new design goals
(stable ops at low speed). Without a schematic,
parts values and waveform data, it's not possible to
offer more specific assistance. Do you have access
to such information?
In any case, this isn't a noise problem in the classic
sense that the tachometer system is talking to or being
upset by another system.
Bob . . . [quote][b]
ianxbrown
Posted: Tue Sep 15, 2009 5:28 am Post subject: P-lead as a source for a tachometer |
When I installed p-lead signal-sourced RPM monitoring, I learned that the signal is basically a pulse, not a nice sig. gen. produced signal. It's going to be around 100V and in my installation (into a Rocky Mountain engine monitor) there is no noticeable noise that would be attributed to P-lead. In speaking with Unisom I learned that my Slick magnetos do not need shielding on the P-leads, and that seems to be true.
As to how it works, I like to think of it a bit like the ear. There is air on one side, transmitting sound, and air on the other side of the ear drum (capacitor) receiving the vibrations and passing them to the middle ear. Unless the ear drum breaks (capacitor fuses into a dead short) there is no communication between the air on the outside and the air on the inside.
Ian Brown
On Tue, 2009-09-15 at 04:49 -0700, Craig Winkelmann wrote: | Quote: | | Quote: |
Craig
[url=http://forums.matronics.com/viewtopic.php?p 63104#263104]http://forums.matronics.com/viewtopic.php?p 63104#263104[/url]
ChangDriver
Posted: Tue Sep 15, 2009 6:19 pm Post subject: Re: P-lead as a source for a tachometer |
| Quote: | Just curious, how will you check for rpm drop between mags if the tach goes dead when one p lead is grounded?
Rick Girard |
Rick:
Would basically digitize both p-lead signals and logical OR them together. This way when left p-lead is grounded, the right p-lead would pass and vice versa. Both signals should be in phase with one another so when both are on, a signal passes. This also opens up the possibility of adding a panel light to let you know if one mag fails in flight.
Craig
