Posted: Tue Sep 15, 2009 9:23 pm Post subject: d-sub connectors and current carrying capacity |
At 11:26 PM 9/15/2009, you wrote:
| Quote: | Are there quality differences between different brands of d-sub connectors that I should worry about? I purchased a couple of d-sub 9 pin solder cup connectors made by Pan Pacific at a local electronics supplier:
http://www.jasonbeaver.com/rv7/rv7pictures/Scaled/20090915/CIMG0524.JPG
Would these be acceptable or would any of you recommend a certain brand and supplier? |
Solder cup and b-crimp connectors come in a huge
variety of qualities. This is why I like to use
the machined d-sub pins . . . ALWAYS good electrical
connection. They also pretty much fit the whole
range of removable pin d-subs.
| Quote: | | Also, what is the rated current capacity per pin? I'm considering using these to hook up a Dynon RV-7 autopilot servo (to make disconnection easy if I ever need to). Is this acceptable or would any of you recommend another way to hook the servo up? |
The d-sub with machined pins is my preferred connector.
20AWG wire in any one pin is good for 7A or so. I like
to keep it below 5A for a few wires, and 3A average for
a connector full of wires.
It's almost a certainty that the machined pin d-sub will
work just fine for the application you proposed.
( -Thomas Paine 1776- )
Posted: Wed Sep 16, 2009 5:09 am Post subject: d-sub connectors and current carrying capacity |
At 06:54 AM 9/16/2009, you wrote:
| Quote: | I have had rotten luck with the Radio Shack metalized D-sub
shells. They fall apart quite easily.
But, why should that be surprising?
Sam
The ones with removable crimp pins?
Posted: Wed Sep 16, 2009 6:11 am Post subject: d-sub connectors and current carrying capacity |
At 08:31 AM 9/16/2009, you wrote:
| Quote: | Yes, but it doesn't involve the connector or pins. Almost every RS
plastic metalized hood has fallen apart. It cracks at the screw bosses.
Sam
Aha! I guess I've never used those. Good data point.
We get nearly all of our plastic hoods from Marlin
P Jones . . .
http://www.mpja.com/prodinfo.asp?number 859+PL
The metalization of plastic hoods serves no useful
purpose. If there is compelling need to encase the
connector-to-connector wire bundles in a metallic
enclosure, then processes MUCH more complex than
adding a metallic coating to the connector shells
is indicated!
jason(at)jasonbeaver.com Guest
Posted: Wed Sep 16, 2009 8:11 am Post subject: d-sub connectors and current carrying capacity |
I've only seen the machined d-sub pins with crimp connectors (like on the B&C website). I'm fine using those, but several articles on your site show d-sub connectors with solder cups. I assume those can be found with machined pins, but B&C doesn't carry them. Do you know where I can get these?
| Quote: | | Quote: | | Also, what is the rated current capacity per pin? I'm considering using these to hook up a Dynon RV-7 autopilot servo (to make disconnection easy if I ever need to). Is this acceptable or would any of you recommend another way to hook the servo up? |
Thanks for your help!
jason
