Charles Heathco
Posted: Mon Aug 31, 2009 4:19 am Post subject: Loop problem |
Late yesterday I finally got up courage to try a loop in my 6a, stalledout just as was starting back down. Recovered strait down, no problem. I wasn expecting that as I had succesfully looped cherokee 140's several time back in 68. I entered from a shallow dive at about 170 mph. Only thing I can think of was I didnt make it tight enuff. I remmbered B F Billy demoing one with me in a 6a, and was very quick and high G. Is that the key? Charlie H
panamared505(at)brier.net Guest
Posted: Mon Aug 31, 2009 5:56 am Post subject: Loop problem |
Loop entry is not so much about speed as it is about Gs, I pull 3.5 to 4Gs at entry, going over the top I transition to 0Gs, float over the top to get a round loop and then at the 270 degree of loop back to 3.5-4Gs for pull out. 140 KTS is a good entry speed for my RV6, but I have done them as slow as 125 KTS.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Doing acro in an RV, a necessary instrument is the G meter. It is real easy to exceed the 6 G limit on the downside of many maneuvers, control the speed with the G, control the G with speed. Avoid VNE at 6+Gs, no good way out.
Bob
Posted: Mon Aug 31, 2009 6:42 am Post subject: Loop problem |
I have no experience in looping a 6A, so I may be blowing smoke here.
There's a band of airspeed/G's that will get you a good loop. The entry
speed needs to be high enough to have the kinetic energy to get you over
the top with a little extra airspeed than you just had, but pulling more
Gs also scrubs off that kinetic energy. There's a fine balance there
that you may get from another aerobatically inclined pilot, or just keep
at it on your own. My only suggestion when you're breaking new ground
in the flight envelope is to do it high .... very high ...... and, of
course, wear a 'chute. Better to carry one and not need it than need it
and not have it.
Linn
charlie heathco wrote:
| Quote: | Late yesterday I finally got up courage to try a loop in my 6a,
wdleonard(at)gmail.com Guest
Posted: Mon Aug 31, 2009 7:56 am Post subject: Loop problem |
I agree with Bob except that it it pretty easy to keep it to 3 to 3.5 G's. Going to zero G's over the top is a nice touch, but not really necessary as no one is usually watching anyway. But you do need to ease the pull over the top as your airspeed will be very low. Either way, remember to NOT be at low G's as you come down the back side or speed and G's will build up quickly as you go through the bottom. (i.e. keep the pull going as you come down the back side).
I use an entry of anything more than 140 KTS with full power, straight into a 3 G pull easing to less than 1 G over the top, then throttle to idle and build back to 3 G's out the bottom. Dont forget to add rudder on the way up.
If you are going to do them with a passenger get good at the low G technique first, because you will most likely be over the aerobatic weight limit.
There is no substitute for instruction, but it is really fun to perfect these on you own.
Dave Leonard
On Mon, Aug 31, 2009 at 7:03 AM, Panama Red <panamared505(at)brier.net (panamared505(at)brier.net)> wrote:
Bob
t="_blank">http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com
David Leonard
Turbo Rotary RV-6 N4VY
http://N4VY.RotaryRoster.net
http://RotaryRoster.net
johnd(at)wlcwyo.com Guest
Posted: Mon Aug 31, 2009 8:30 am Post subject: Loop problem |
Get a G meter before trying any Acro.
3.5 to 4 G’s on entry is good with an entry speed of 160 or 170mph.
I float over the top with 0G’s and pull 3 to 3.5 G’s coming out on the bottom end.
Usually the problem is that your worried about pulling to many G’s on entry. This is why you need a G meter. And your again worried about the g’s on the pull out.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of charlie heathco
Sent: Monday, August 31, 2009 6:19 AM
To: rv-list
Subject: Loop problem
| Quote: | | http://www.matronics.com/Navigator?RV-List | 0123456789
sbuc(at)hiwaay.net Guest
rv8a2001(at)yahoo.com Guest
Posted: Mon Aug 31, 2009 11:19 am Post subject: Loop problem |
From what I have read tells me you are not familiar with performing aerobatics and I dont mean that as a put down. Get some basic training it will be the best money spent.
Scott
RV-8a
--- On Mon, 8/31/09, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Subject: Re: Loop problem
To: rv-list(at)matronics.com
Date: Monday, August 31, 2009, 7:37 AM
--> RV-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
I have no experience in looping a 6A, so I may be blowing smoke here. There's a band of airspeed/G's that will get you a good loop. The entry speed needs to be high enough to have the kinetic energy to get you over the top with a little extra airspeed than you just had, but pulling more Gs also scrubs off that kinetic energy. There's a fine balance there that you may get from another aerobatically inclined pilot, or just keep at it on your own. My only suggestion when you're breaking new ground in the flight envelope is to do it high .... very high ...... and, of course, wear a 'chute. Better to carry one and not need it than need it and not have it.
Linn
| Quote: | Late yesterday I finally got up courage to try a loop in my 6a, stalledout just as was starting back down. Recovered strait down, no problem. I wasn expecting that as I had succesfully looped cherokee 140's several time back in 68. I entered from a shallow dive at about 170 mph. Only thing I can think of was I didnt make it tight enuff. I remmbered B F Billy demoing one with me in a 6a, and was very quick and high G. Is that the kbsp; --> http://foru - List Contribution We &nbs;-->
Posted: Mon Aug 31, 2009 12:55 pm Post subject: Loop problem |
<am sending this post to the list since Linn's private address bounced>
Linn Walters wrote:
> Sam Buchanan wrote:
>> Linn Walters wrote:
>> <snip>
it and not have it.
>>> Linn
>> Very unlikely you would ever be able to get out of the RV-6A........
> Why is that? Inquiring minds want to know!
> Linn
Linn,
There are two canopy designs on the side-by-side RVs:
tip up; Originally designed with a quick release mechanism that *may*
have worked properly when the canopies were built without hydraulic
assist (guess in an emergency you wouldn't worry about whether or not it
would take off your head or the vertical stab as it departed the
plane....). But since mid-90's, the hydraulic struts have been shipped
with finish kits and would almost certainly prevent the canopy from
detaching as designed.
slider; can be opened in flight, however.......
The airloads on both designs make it nearly impossible to get either
canopy open more than a few inches in flight. The tip up can be pushed
up with difficulty maybe 6-12", the slider can be pushed back less than
12". In either case a pilot would find it practically impossible to exit
the aircraft. If a builder was serious about aerobatics quick-release
pins might be incorporated into the slider installation. Some have done
this with the RV-8.
As far as I know, there are *no* documented cases of someone bailing out
of a side-by-side RV with either canopy. Matter of fact, there are no
documented cases of anyone even attempting to jettison the tip up canopy.
A parachute in a RV-6/6A might make you feel safer until you actually
needed to use it.
Sam Buchanan
Posted: Mon Aug 31, 2009 12:56 pm Post subject: Loop problem |
| Quote: | Very unlikely you would ever be able to get out of the RV-6A........
Sam Buchanan
I have often thought this about my RV6. Opening the canopy in normal
flight beyond about 2 inches is next to impossible. I mentioned this to a
retired USAF F-4 Driver and his response was "It depends upon how motivated
you are!"
But the caution about having plenty of altitude is good. It will give you
more time to try and regain control even if you don't think you can bail
out. The IAC requires parachutes in competiton, so I use one regardless of
what I think its usefullness might be. And who knows, if I loose control in
an inverted flat spin and can't regain control, maybe I will be able to open
the canopy.
Bob
RV6 "Wicked Witch of the West"
bmeyette
Posted: Mon Aug 31, 2009 4:17 pm Post subject: Loop problem |
For that reason and because my tipup quick release bar was in the way of my
avionics, I used AN bolts instead of the sliding pins to hold my canopy
hinges.
Brian
_________________ Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm |
Charles Heathco
Posted: Tue Sep 01, 2009 3:43 am Post subject: Loop problem |
Yes Sam I agree, Parachute would note be of any use. When I first got my 6a
I forgot to t latch the canopy a few times and had to pull full flaps and
slw to near stall to be able to move the canopy enuf to latch. I had always
thought that it could not be opened if ypou had to try to et out in flight.
camdaddy
Posted: Sat Sep 19, 2009 4:41 am Post subject: Re: Loop problem |
Hey, Charlie. I wonder how your loops have been progressing?
When I got my first acro training in an Extra 300L, the military instructors drilled into me to get a feel in my butt for 3 and 4 Gs. In a couple days I knew what they meant and could sense when I was loading the plane to those levels.
In my RV that feeling was a little different and I had to re-learn what 3Gs and 4Gs felt like. Now, that along with a sense for the elapsed time I'm taking to get to the top lets me know how the loop will look.
I also placed a piece of pinstripe tape on the inside of my canopy at eye level on my left to act as my horizon marker. It's not as good as a wingtip sighting device, but it's a good low-tech solution that's better than nothing. Once I lose sight of the horizon up front, I turn my head left to watch my wing. The tape will tell me when I'm nearing the top and it's time to look "up" and unload the plane.
One other thing I did that helped me... I did a bunch of Split- Ss. I would slow the plane to just above stall speed, roll it over, and pull a Split-S. This gave me a good feel for how my loops would finish.
-Cam
Charles Heathco
Posted: Sat Sep 19, 2009 5:47 pm Post subject: Loop problem |
Thanks for the pointers Cam. It has been raining here most every day past 2
wks, havent been up. Im suprised to hear that the plane will roll going that
slow, would seem like could easily slip into a spin. Charlie
camdaddy
Posted: Sat Sep 19, 2009 6:47 pm Post subject: Re: Loop problem |
It will roll over just fine. It's slow... kinda wallows over, but not bad. Don't let it get too slow and it CAN'T spin b/c for a spin to happen it needs yaw to couple with the stall. Keep the bubble centered and the plane unloaded (stick-wise, I mean, not cargo-wise)... you'll be fine.
In fact, I have to really work to get my -4 to spin. It will do it, but I have to hold pro-spin inputs for awhile. Once it spins and I am done, I give the PARE recovery inputs and it pops right out without hesitation. Even with a back seat passenger. The side-by-side RVs I've flown seem to want to spin easier than the -4s I've flown. But I wouldn't be concerned about them being "stubborn" in the spin.
But do only what you're comfortable with and listen to that all-important "little voice". ...and keep me posted.
Charles Heathco
Posted: Sat Sep 19, 2009 7:48 pm Post subject: Loop problem |
Ok, I am itchi8ng to get up, maybe a window some time tomorrow
dale1rv6(at)comcast.net Guest
Posted: Sun Sep 20, 2009 2:12 am Post subject: Loop problem |
I would suggest at least a starting altitude of 4,000 AGL for your
introductory split S. 5,000 ft would be even safer.
Dale
RV6a 1230 hrs GRT S200 0-360 Hartzell
jvanlaak(at)aol.com Guest
Posted: Sun Sep 20, 2009 4:53 am Post subject: Loop problem |
Two suggestions:
First, you may find that making a level, coordinated roll just above stall is actually quite difficult. Instead, consider starting at a more "normal" speed like 80 and lifting the nose 20 degrees before rolling you end up with the same condition - inverted at about 60 - with more control authority and less adverse yaw. The nose wants to fall quickly at low speeds even when "unloaded" especially as you go through knife edge. Raising the nose give you the room for that to occur before seeing the horizon inverted to confirm you in fact got through 180 degrees of roll. Otherwise you could find the windshield full of ground and no idea how far you rolled and what direction is the shortest one to right side up.
Second, pay attention to CG. One of the most common mistakes in aviation is to neglect the effect of cg on stalling and spinning characteristics. When you read somebody telling how hard a Cessna 172 is to stall you see that they only attempt the maneuver with the back seat empty (I think by POH restriction). But if they happened to inadvertently stall with the seats and baggage area full they would find an entirely different result. In the case of RVs, the empty CGs vary wildly depending on engine and especially prop (a CSP versus wood prop is huge) and of course the tandems can change greatly with who is sitting where.
Explore spinning and other new maneuvers with a forward CG and lots of altitude.
Jim
