mau11(at)free.fr Guest
Posted: Sat Sep 19, 2009 11:20 pm Post subject: Dynon remote compas and brake caliper |
Hi all,
1 I install the Dynon D10A and remote compas.
Where is the best position of the remote compas?
2 Does anyone know a brake caliper (cleveland or other) more
efficient than Europa caliper.
Thank you
Michel AUVRAY
mau11(at)free.fr
Ivor Phillips
Posted: Sun Sep 20, 2009 1:30 am Post subject: Dynon remote compas and brake caliper |
Hi Michel
I put mine in the bottom fuselage in front of the fuel tank, Buts its pretty busy there with wiring and pipe work, so have been unable to get it within 15 degrees of compass heading, This winter I will be moving it to the headlining space between the doors, My compass is in a pod there and works well so hopefully the Dynon will be more accurate,
regards
Ivor
---- Michel AUVRAY <mau11(at)free.fr> wrote:
Quote: |
Hi all,
Thank you
Michel AUVRAY
mau11(at)free.fr
DuaneFamly(at)aol.com Guest
Posted: Sun Sep 20, 2009 11:25 am Post subject: Dynon remote compas and brake caliper |
Good Afternoon Michel,
As I am going with the conventional gear I can't advise on another brake caliper because you may have bolt pattern and size limitations to consider. I have my battery on top of the passenger footwell and so the little platform that I did during the build in the normal location behind the rear bulkhead was available for me to mount the remote compass. While I am not flying yet, I have had my panel running and it seems to match the compass above my windshield. It seems to be out of the way of most of my electrical runs. But this is just a suggestion.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300A
Sensenich R64Z N
Ground Adjustable Prop
avgashead(at)btinternet.c Guest
I'm running the D180 and installed the compass between the two rudder cable
pulleys. I've not flown yet but the calibration with the ground compass went
fine and it lines up with the analogue compass. Be careful with the O.A.T.
probe if you're running one as it must be wired through the remote compass.
Richard Scanlan
#103 ready to fly
ploucandco
Posted: Sun Sep 20, 2009 12:50 pm Post subject: Re: Dynon remote compas and brake caliper |
Hi Michel,
I have the Dynon remote compas under the pilot seat.
Works well.
Have fun.
Jacques
willie.harrison(at)tinyon Guest
Posted: Sun Sep 20, 2009 1:37 pm Post subject: Dynon remote compas and brake caliper |
Put mine in the space overhead, just in front of the rear door hinges.
Calibrated up very nicely with a landing compass etc. Symmetry between
the hinges seems to cancel out any error from the steel hinges/screws.
Good calibration is really worth it IMHO for the prime reason of
getting an accurate real time wind vector from the Dynon (who really
flies by heading these days when you have the option of controlling
track against desired course?)
My headset causes a 1 degree error if I sway my head over to the right
(either that or its the fillings in my teeth...)
It was fairly simple to jig the mounting brackets to align with
'straight and level' reference lines. It required a slight 'power
bulge' in the ceiling trim to align the remote compass with the
horizontal in the pitch axis.
I'm a fan of the Dynon kit. Has anyone got a view on the new product
they introduced at oshkosh giving synthetic vision etc etc?
Willie
G-BZNY
On 20 Sep 2009, at 08:16, Michel AUVRAY wrote:
Quote: |
Hi all,
Thank you
--------(*)-------- Michel AUVRAY
mau11(at)free.fr
