Brake line exit holes
Phil.Perry(at)netapp.com
PostPosted: Sat Sep 19, 2009 7:41 am    Post subject: Brake line exit holes Reply with quote
I think I really screwed up this morning.
28-5 Step 4
"Enlarge the two pre-punched brake line pilot holes to 5/8 diameter"
These are the holes where the brake lines exit the bottom skin at each landing gear mount.
I drilled the hole in the skins out to 5/8" just as the plans indicated. While I was there (keep in mind this is a QB), I decided to install the brake line hardware too as described on 36-2. The AN fitting doesn’t fit through the corresponding hole on the landing gear mount.
After looking at the directions, it says (a second time) to enlarge the hole to 5/8”. I can only assume they’re talking about the corresponding hole in the landing gear, to make room for the AN fitting.
So now I have a 5/8” hole in the bottom skin and in the landing gear mount.
This is the point where shock set in. I’ll bet I wasn’t supposed to drill the landing gear mount to 5/8” and I’ll bet the fitting is supposed to mount to the landing gear – and pass through the skin untouched.
Now I have a really nice hole that my AN fitting will push right through. Not to mention a weak point near a very critical structural component that gets abused (the landing gear).
I think I just bought myself a lot of work, a new right main gear mount, and a lot of stress.
Someone tell me I didn’t….
Phil
Lenny Iszak
PostPosted: Sat Sep 19, 2009 8:19 am    Post subject: Re: Brake line exit holes Reply with quote
Phil,
Took a (crappy) picture of my brake line exit. The fitting mounts to the landing gear bracket and just goes through the skin.
Hopefully someone has a good idea for a fix. It ain't fun to take the landing gear bracket out.
Lenny
 Filesize:  68.8 KB
 Viewed:  6424 Time(s)
AirMike
PostPosted: Sat Sep 19, 2009 9:39 am    Post subject: Brake line exit holes - collapsed gear - and silver linings Reply with quote
Since none of us have a perfect plane, I would not get too concerned. If it were me, I would take a thick aluminum plate - put the proper sized hole in the plate for the AN fitting - then epoxy the plate in place.
At this point in the build - this kind of error will drive you crazy - a year from now it will be long forgotten.
Also look at the silver lining to this screw up - you will be much more motivated to make nice soft landings after you are flying.......
See you OSH '18
Q/B - sold.
kearney
PostPosted: Sat Sep 19, 2009 10:49 am    Post subject: Brake line exit holes Reply with quote
Hi
If you have enlarged a hole in the gear mount, you can avoid having to get a new one by getting a welding shop to fill in the hole. You can then redrill to the correct size.
Cheers
Les
#40643 –living in f/g hell
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: September-19-09 9:27 AM
Subject: Brake line exit holes
28-5 Step 4
Phil
[b]http://www.matronics.com/Navigator?RV10-List[b]
PostPosted: Sat Sep 19, 2009 11:18 am    Post subject: Brake line exit holes Reply with quote
Sorry about going dark for a few hours. I realize a few of you replied.
The internet connection went down as soon as I sent the first message and it still hasn't returned.
But my blackberry is working at least. Once the connection comes back, I'll sort through the replies.
Phil
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Sent: Sat Sep 19 08:13:10 2009
28-5 Step 4
Phil
Phil White
PostPosted: Sun Sep 20, 2009 1:19 pm    Post subject: Re: Brake line exit holes Reply with quote
Phil: We Phil's can hang together, as we make the same mistakes. Look at the photo attached, which shows how I put a small piece of .035 or .041 with the correct smaller hole in it, on top of the gear leg flange, put the fitting thru, and 'twas fixed. the slightly oversize hole in that flange won't cause a problem.
Can't recall whether there is a washer on the underside or not, but the fitting is solidly attached to the plane now.
Phil White
#40220
 Filesize:  236.17 KB
 Viewed:  6381 Time(s)
PostPosted: Mon Sep 21, 2009 6:47 am    Post subject: Brake line exit holes Reply with quote
I don't have my documentation with me this morning and I can't seem to
find Section 4 on Tim's site.
Does anyone know if the main gear mounts are 4130? I think I've found
an aircraft welder who can patch the hole for me, but I'd like to be
certain of the material first.
Phil
PostPosted: Mon Sep 21, 2009 9:11 am    Post subject: Brake line exit holes Reply with quote
Got the answer for those who are wondering. (Or for those who might
search the archives later.)
1) Yes, it is 4130.
2) Unfortunately the mount has been heat treated. So touching the thing
with a welder is not a good idea for fear of weakening the structure.
3) Van's doesn't believe there is a structural issue with the hole, but
they're running it by engineering to check.
4) The proposed solution from Van's is to insert a bushing into the hole
and then a large flat washer on top to hold it into position.
Once we reach a resolution, I'll send the fix for the archives.
Phil
