rvg8tor
Posted: Tue Sep 22, 2009 6:40 pm Post subject: What size wire? |
Bare with me I am learning! My system will follow Z12, but it does not list a AWG for the connection form the battery relay to the main bus and from the main bus to the E-buss. Some of the drawings show a 6 AWG from the battery relay to the main bus, but the wire diagram from Van's calls out a 8 AWG. So this got me to thinking how do I determine the size wire that will go here. I understand wires sizing to individual components but how does one figure a wire feeding a bus? Do I take the numbers from my load analysis (only continuous loads) and use that to size the wire? Does the same theory apply for the wire connecting the main bus to the E-bus through the diode?
Lastly due to panel space my main buss is going to be in two rows, how do I make the interconnection between the two, bolt a strip of bus bar material between the buss that holds the CBs. should I connect the two rows of breakers at both ends giving a redundant path to the second row. To be clear my main bus is 2 rows of breakers and the E-bus is one row, for 3 rows total. Thanks for the help.
_________________ Mike "Nemo" Elliott
RV-8A QB (Engine)
www.mykitlog.com/rvg8tor |
Posted: Wed Sep 23, 2009 11:48 am Post subject: What size wire? |
At 09:41 PM 9/22/2009, you wrote:
buss and from the main bus to the E-buss. Some of the drawings show
As a general rule, fat wires that do not carry starter
currents are picked to carry alternator currents. Many
builders using 4AWG fat wires for battery installations
near the engine simply use 4AWG for the altenrator b-lead
and main bus too. But if your alternator is 60A or smaller,
6AWG is fine for these two slots.
Size the main-bus/e-bus jumper according to e-bus loads.
Same philosophy for the e-bus alternate feed path from
the battery bus.
| Quote: | Lastly due to panel space my main buss is going to be in two rows,
buss bar material between the buss that holds the CBs. should I
path to the second row. To be clear my main buss is 2 rows of
breakers and the E-buss is one row, for 3 rows total. Thanks for the help.
Here's how Beech does it . . .
http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_2.jpg
http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_1.jpg
http://aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_0.jpg
( -Thomas Paine 1776- )
