russkinne(at)mac.com Guest
Posted: Tue Sep 22, 2009 9:41 am Post subject: gyros |
BTW, gyrocopters do NOT "fall like a rock" without power. They
autorotate down to a smooth landing.
Ken Brock used to cut power, prop stopped, at about 500' & autorotate
down to a smooth, very soft landing. Nothing bent, he waved & walked
away from it. Repeatedly! -- part of his airshow routine. (In a
Bensen gyrocopter)
Helicopters can of course autorotate to a fairly soft landing if
they have enough altitude to get everything done in time.
"Fall like a rock"? I don't think so.
Russ K
On Sep 22, 2009, at 12:39 PM, JetPilot wrote:
In almost all airplanes, stopping the prop completely reduces drag
and increases glide. A windmilling prop is much worse than a
stopped one if you are trying to glide. As John H says, a
helicopter would fall out of the air if this were not true. A
gyrocopter just has a big windmilling prop on the top of it, no
power to it at all, and if it were to ever stop in the air the
gyrocopter would fall like a rock.
JetPilot
Posted: Tue Sep 22, 2009 10:21 am Post subject: Re: gyros |
Kolb MK-III Xtra, 912-S
rlaird
Posted: Tue Sep 22, 2009 10:24 am Post subject: gyros |
Correct, Russ! EVERY landing I do in my gyro is softer than a kittens
paw, and EVERY one is done with the engine at idle. I've done them
from as high as 1500 feet AGL (no reason it couldn't be higher), and
as low as 30 feet... chop the power, lean into it slowly, maintaining
best-glide speed, then flare. Couldn't be simpler. My roll-out is
usually between 10 and 20 feet.
But, to be fair, I think he was speaking theoretically. Yes, if my
rotor was suddenly frozen by a futuristic stasis ray gun, the gyro
would drop like a rock. But, that would be like saying, if a fixed
wing aircraft has its wing suddenly vaporized, it would fall like a
rock. Yep. The wing, to rotor, are providing the lift for the
craft... without that lift, they are both toast.
-- Robert (flying a Gyrobee as well as a Kolb)
On Tue, Sep 22, 2009 at 12:36 PM, russ kinne <russkinne(at)mac.com> wrote:
BTW, gyrocopters do NOT "fall like a rock" without power. They autorotate
Ken Brock used to cut power, prop stopped, at about 500' & autorotate down
to a smooth, very soft landing. Nothing bent, he waved & walked away from
it. Repeatedly! -- part of his airshow routine. (In a Bensen gyrocopter)
Helicopters can of course autorotate to a fairly soft landing if they have
Russ K
> In almost all airplanes, stopping the prop completely reduces drag and
> increases glide. A windmilling prop is much worse than a stopped one if
> you are trying to glide. As John H says, a helicopter would fall out of
> the air if this were not true. A gyrocopter just has a big windmilling prop
> on the top of it, no power to it at all, and if it were to ever stop in the
> air the gyrocopter would fall like a rock.
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Tue Sep 22, 2009 12:58 pm Post subject: gyros |
Mike
I apologise for not understanding your post correctly; but I'm hardly
'vindictive' or 'desperate', I don't need 'revenge' and I hope I'm
not 'pathetic'
Please accept my sincere apology.
Russ K
On Sep 22, 2009, at 2:21 PM, JetPilot wrote:
Russ,
In your jubilation and glee when you thought you had found that I
made a mistake, you were in such a hurry to start a new thread and
point out that I had made an a mistake that you failed to read what
I posted and understand it. I said if the BIG windmilling prop on
TOP of the gyrocopter ever stopped - Meaning the ROTOR, the
gyrocopter would fall like a rock, which is very true.
You sure are desperate to find something wrong with something I
have posted, it took you only a couple minutes for you to start a
new thread on where you thought I made a mistake. Funny, with
all the incorrect and bad information posted on this forum, you
have only started a new thread on the subject when you thought I
said something wrong... Get over your vindictiveness and need to
get revenge , its pathetic.
Mike
http://forums.matronics.com/viewtopic.php?p 64350#264350
Posted: Tue Sep 22, 2009 2:44 pm Post subject: gyros |
| Quote: | autorotate down to a smooth landing.
| Quote: | they have enough altitude to get everything done in time.
Russ K
Russ K/Gang:
Gyros are right behind rocks when they lose power. They are in contant
autorotation when flying, with or without a source of thrust.
Helicopters feel like they are falling out of the sky in autorotation,
especially a 180 degree autorotation. Even normal approaches to land a
steep compared to fixed wing aircraft. Guess that is one reason I have
always been comfortable flying Kolbs.
Helicopters used to have a dead man's curve, when I was flying them many
years ago, published in the operational manual. This was the
airspeed/altitude that an autorotation would probably not be sucessful.
Rock House, Oregon
_________________ John Hauck
Titus, Alabama |
Posted: Tue Sep 22, 2009 2:56 pm Post subject: gyros |
| Quote: | paw, and EVERY one is done with the engine at idle. I've done them
| Quote: | -- Robert (flying a Gyrobee as well as a Kolb)
Robert L/Gang:
Of course your landing is always done with forward airspeed when the engine
is at idle. If not, it loses rotor rpm quickly.
Also, the gyro is never out of autorotation from take off to landing, with
out without power.
Helicopters do quite well in autorotation, especially with forward airspeed.
They'll also autorotate sideways and aft, but will probably be hard on the
skids that way.
Hovering autorotations are a piece of cake in Army helicopters in ground
effect, but sucessful higher hovering autorotations depend on load and main
rotor enertia.
Rock House, Oregon
DO NOT ARCHIVE
Titus, Alabama |
JetPilot
Posted: Fri Sep 25, 2009 6:17 pm Post subject: Re: gyros |
[quote="russkinne(at)mac.com"]Mike
not 'pathetic'
Russ K
Russ,
I misjudged your intentions, and I owe you the apology. I have removed my previous post to you from the forum. Given what has gone on here on the list recently, I was to quick to jump in with a harsh reply. Thanks for the nice response.
Mike
Kolb MK-III Xtra, 912-S |
grantr
Posted: Mon Sep 28, 2009 9:42 am Post subject: Re: gyros |
| Quote: | Of course your landing is always done with forward airspeed when the engine
John,
A gyro does not lose rotor rpm at zero airspeed. The rotor self regulates its rpm unlike a helicopter.
We need forward speed to add energy to the rotor to arrest the sink rate. Similar to a fixed wing you can land right above stall speed but you don't have energy to flair and arrest the sink rate.
A vertical landing is possible in a gyro but the sink rate is too high for a good landing.
Posted: Mon Sep 28, 2009 11:16 am Post subject: gyros |
When I got my checkride in a Hughes 269 my examiner announced
inflight that I had passed and asked for the stick back.
He brought it to a hover at about 2000' feet and switched off the
key. He lowered the collective and we went straight down in a vertical
descent, level with the horizon. All you could hear was the whirl of
the blades. At maybe 50' from the ground he went forward cyclic
to get some excess rotor rpm and touched it down at a gentle walk.
Les Hembel of SC Helicopters. I'm thankful to have flown with a legend.
Even the Ft Rucker ex flight instructors on the faculty looked up to
this guy even though he was only about 5' tall.
-good thing the country boy mechs he had set the stops right. They
were good too. They could put together a frame up
machine from only a dataplate and it would run much smoother than a
factory new ship.
BB
On 28, Sep 2009, at 1:42 PM, grantr wrote:
<grant_richardson25(at)yahoo.com>
> the engine
John,
A gyro does not loose rotor rpm at zero airspeed. The rotor self
http://forums.matronics.com/viewtopic.php?p 65348#265348
Posted: Tue Sep 29, 2009 4:08 am Post subject: gyros |
key. >>
Hi Robert,
having been interested in gyrocoptors ever since Bensen when gyros became
`approved` over here I booked a ride.
The instructor took us off pretty sharply and threw it around a bit and then
brought it to a hover at about 1000 ft. I watched the ASI as the speed
decayed and then we began to fly backwards. Its a funny feeling to a
`normal` pilot to watch the ground retreating in front of you. He then said
"I expect you are wondering what would happen if the engine stopped now`
and switched off. Except that it got quiet it was a non event. He put the
nose down and we descended fairly rapidly but not excessively so, flared and
landed right on the numbers. Very nice.
We then took off and he flew a chicane at about 5 feet all the way along a
series of traffic cones. Super.
The approval was withdrawn after a series of accidents shortly afterwards so
I never pursued that particular branch of flying. New models are now back
on the `approved `list so there are quite a few about but not for me.
Cheer
Pat
rlaird
Posted: Tue Sep 29, 2009 4:47 am Post subject: gyros |
On Tue, Sep 29, 2009 at 7:08 AM, pj.ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
The approval was withdrawn after a series of accidents shortly afterwards so I never pursued that particular branch of flying. New models are now back on the `approved `list so there are quite a few about but not for me.
The gyro community collectively had an epiphany in the not too distant past, whereas they realized that by making gyro's truly center-line-thrust, and by installing a horizontal stabilizer, the safety improvement was radical and game-changing. (Not 100% of the gyro enthusiasts agree with these two changes, but the aerodynamics are irrefutable.) The other change has been the improving training environment. Combined, these changes convinced me it was time to complement my fixed-wing flying, and I'm enjoying every moment. The thing I love best is my flight stability even in thermally, gusty, rough air -- very common in Texas. In my Kolb, I have to fight the plane, thrashing the stick around, dancing with my feet, to keep wings, well, almost level -- not much fun -- whereas in the gyro, in the same conditions, I notice the air is a bit more blustery, and when a gust hits the side of my empennage I might get a bit of yaw, but I can still fly hands and feet off! That is a huge difference in comfort and the feeling of stability.... much more enjoyable. And the turns are wicked!
-- Robert
Robert Laird
Houston, TX area
Posted: Wed Sep 30, 2009 8:54 am Post subject: gyros |
more enjoyable. And the turns are wicked!>>
Hi Robert,
The improved `gust resistance` is due to the high wing loading I assume. Re turns. The instructor I flew with when he finished his slalom of the traffic cones said `Lets go across the field and attack that hangar. We got clearance and dashed across the field, over the main runway, at about 20 ft. and to my amazement there was a Heinkel 111 parked in the lee of the hangar. Where it came from or if it was real or a mock up I never found out but we bored into the attack by flying down the opposite side of the hangar, banking steeply, round the side wall and popped out behind the hangar with metaphoric guns blazing. Great fun..
Nearly made me forget the picture of a pilot flying a demonstration of a Benson. I don`t think he had ever flown a gyro before but he was the only guy they could get. He looked scared to death before he even got into the thing. He got it into the air and did the most tentative circuit I have ever seen. Obviously the blades had not been balanced and the stick was shaking in the pilots hand, backward s a forwards every time the blades went round. He put the plane down and staggered away without a backward glance and could not be persuaded to fly again. Never seen a guy so scared.
Cheers
Pat
rickofudall
Posted: Wed Sep 30, 2009 9:19 am Post subject: gyros |
Interesting. Not about the gyro, but the He 111. I was up at Arlington (AWO) a few years back, and looked across from the ultralight field to see an He 111 sitting on the ramp in front of the airport office so I went over to see. The fellow who had flown it in told me the story. It was Franco's personal airplane given him by Hitler after the Spanish Civil War. It and all their Merlin powered Me 109's (they had been reengined in the 50's and 60's when the supply of DB engines was exhausted) had been bought up by the makers of the film, "The Battle of Britain" and the He (also Merlin powered) had been surplused out after the filming was done. He wouldn't tell me who owned the aircraft and he wouldn't give me a ride even when I offered to buy the gas. Oh well.....
Rick Girard
On Wed, Sep 30, 2009 at 11:53 AM, pj.ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote] That is a huge difference in comfort and the feeling of stability.... much
Hi Robert,
Cheers
Pat
Posted: Wed Sep 30, 2009 10:19 am Post subject: gyros |
bought up by the
makers of the film, "The Battle of Britain" >>
Hi Richard,
sad to think that film could not be made now. The planes do not exist and the CG stuff just doesn`t cut it. See the last version of Tora! Tora! Rubbish compared to the original even if they did use T6`s for Zero`s.
Peter Jackson has a number of old planes stuck away in a hangar down in NZ and there are runours that he would like to do a war epic....vereee interesstting.
Cheers
Pat
aoldman(at)xtra.co.nz Guest
Posted: Thu Oct 01, 2009 12:37 am Post subject: gyros |
He's { Peter Jackson} is working on a dam busters movie. He has a collection of WW1 planes in Blenheim.The AirPort his aircraft fly from is called Omaka . They are flown at wings over Wanaka every other Easter and at the Marlborough air show every other Easter.
You can see some of the collection at Omaka Aviation Heritage centre.{ You can google that}
You will see more of this subject at "thevintageaviator.co.nz"
To keep this Kolb related ,My Kolb shares hanger space with my replica Sopwith camal.
Downunder
MK111c
Posted: Thu Oct 01, 2009 11:25 am Post subject: gyros |
He's { Peter Jackson} is working on a dam busters movie. >>
Thats great news. I understood something was brewing. What is Jackson going to do about Guy Gibsons dog? You probably can`t call a dog `Nigger` these days. Historical accuracy or will the pc fraternity win out yet again.
Difficult film to make .The original with Richard Todd was a classic and in spite of the poor `effects`(the best at the time) it is one of the best war films (along with Ice Cold in Alex) produced. Those of my age have a great feeling for that film and would hate to have it `messed about`
In NZ for a month in Feb. next year but planning to stay in the Bay of Islands so little chance of getting to South Island.
Cheers
Pat
beauford
Posted: Thu Oct 01, 2009 1:40 pm Post subject: gyros |
Rick:
That particular He-111, actually a Spanish-built CASA 2111, was destroyed in a crash in Wyoming about 5 or 6 years ago. It lost an engine and went in into a built-up area, killing all aboard. A friend of mine knew the pilot, who was a pilot for one of the major airlines. Airplane belonged to the CAF.
On a Kolb note... looks like the goo which used to be the Manatee airstrip is beginning to dry out a bit. Management had closed the eastern half of it because of the mud and water. Summer weather pattern here appears to be breaking and the fall pattern ought to dry it up pretty quickly... may be able to actually get in there and commit some aviation with the Kleenex Kolb this coming week.
fingers crossed beauford
FF-076
