Flap positioning system
Kelly McMullen
PostPosted: Fri Sep 25, 2009 10:40 am    Post subject: Flap positioning system Reply with quote
For those who have the flap pre-select system: I am at stage to decide whether I want this system or not. My question is whether it can be adjusted to select reflex, trail, 1/2 and full flaps? Or can you only get 10, 20, 30 degrees?
Kelly
40866
QB arriving
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
bcondrey
PostPosted: Fri Sep 25, 2009 10:42 am    Post subject: Flap positioning system Reply with quote
That is exactly what you get – reflex, 0, ˝ and full.
Bob
N442PM
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Friday, September 25, 2009 1:39 PM
Subject: Flap positioning system
Kelly
40866
QB arriving
ricksked(at)embarqmail.co
PostPosted: Fri Sep 25, 2009 11:04 am    Post subject: Flap positioning system Reply with quote
If I did it again I think I would rather have more control over exactly how much down flap I could use past zero. At times full is too much and 1/2 is not enough but I'm just being picky I suppose. I do like the zero setting for take off vs. the reflex or -3 degree setting. I've found the difference being at zero the aircraft just flies off without much back pressure at all with an overall increase in climb performance. In the reflex position you need a bit more pressure to rotate and take off.....that extra one inch of pull is wearing me out! The system works great though.
Rick Sked
N246RS
Flying naked
Painting the pants and fairings
Tim Olson
PostPosted: Fri Sep 25, 2009 11:05 am    Post subject: Flap positioning system Reply with quote
I see no reason for any more than these 4 settings,
but by cutting a couple more notches you could
add a couple more steps if you really felt it necessary.
The way it flies though, I see no need for any more
than what it has now. I think, but have not
measured, that it's reflex, 0, 15, 25
Bob
N442PM
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly McMullen
*Sent:* Friday, September 25, 2009 1:39 PM
*To:* rv10-list(at)matronics.com
*Subject:* Flap positioning system
Kelly
40866
QB arriving
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
jcumins(at)jcis.net
PostPosted: Fri Sep 25, 2009 11:20 am    Post subject: Flap positioning system Reply with quote
Rick
Sounds like you need to life weights then hehehe, worn our all of us still pounding rivits are worn out, LOL
I will look you up next time I am in LAS
Fly safe
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked
Sent: Friday, September 25, 2009 12:02 PM
Subject: Re: Flap positioning system
Rick Sked
N246RS
Flying naked
Kelly McMullen
PostPosted: Fri Sep 25, 2009 11:39 am    Post subject: Flap positioning system Reply with quote
Thanks everyone...exactly what I needed to know.
On Fri, Sep 25, 2009 at 3:02 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Bob
N442PM
Kelly McMullen
KCHD
rene(at)felker.com
PostPosted: Fri Sep 25, 2009 11:51 am    Post subject: Flap positioning system Reply with quote
Ok for the people that don’t have the FPS or have not used it yet.  One point of order.  You can put your flaps at any setting from -3 degrees to full (?25 degrees).  All you have to do is go down to the preset (anyone), then hit the up switch until it is at the desired setting.
Now, after 100 hours I have not needed to do that because my empty weight CG is further aft than the Vans aircraft.  But when I was doing my transition training, I was taught to put the flaps down, then bring them up just a little, or else you run out of elevator trim for landing…
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Sent: Friday, September 25, 2009 1:02 PM
Rick Sked
N246RS
Flying naked
Tim Olson
PostPosted: Fri Sep 25, 2009 12:11 pm    Post subject: Flap positioning system Reply with quote
Yes, you can stop the flaps anywhere mid travel by centering
the switch. Just yesterday I used it to give more partial
flaps so I could take photos of the wife in the cherokee.
you'd be amazed at how hard it is to fly side-by-side
with a plane that doesn't WANT to stay that slow. Yes,
the RV-10 flies nicely at slow speeds, but it cools better
at higher speeds, so to try to maintain 90kts
for 30 minutes, you have to pull out some tricks. Partial
flaps when needed aren't tough, even with a 4 stop positioner.
Tim Olson - RV-10 N104CD
Rene Felker wrote:
[quote] Ok for the people that don’t have the FPS or have not used it yet. One
Rene' Felker
RV-10 N423CF Flying
801-721-6080
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rick Sked
*Sent:* Friday, September 25, 2009 1:02 PM
*Subject:* Re: Flap positioning system
great though.
Rick Sked
N246RS
Flying naked
bcondrey
PostPosted: Fri Sep 25, 2009 12:41 pm    Post subject: Flap positioning system Reply with quote
During transition training Alex D. demonstrated that it actually takes about 200-300 feet more roll on takeoff if in reflex instead of 0.
Bob
Sent: Friday, September 25, 2009 2:02 PM
Rick Sked
N246RS
Flying naked
indigoonlatigo(at)MSN.COM
PostPosted: Fri Sep 25, 2009 7:13 pm    Post subject: Flap positioning system Reply with quote
If you take off with the flaps in reflex and you have a problem that makes you need to go slow as in engine failure C you will tip stall your wing instead of allowing the inner portion of the wing to stall first. This would not be a good thing.  At least with sailplane design and other aircraft C tip stalling the wing is a bad thing.
JOhn G
Date: Fri C 25 Sep 2009 13:41:25 -0700
Subject: RE: Flap positioning system
.ExternalClass .ecxshape {;} .ExternalClass .ecxSHAPE {;} .ExternalClass p.ecxMsoNormal C .ExternalClass li.ecxMsoNormal C .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link C .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.ecxMsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.ecxEmailStyle19 {font-family:Arial;color:navy;} .ExternalClass span.ecxEmailStyle20 {font-family:Arial;color:navy;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.ecxSection1 {page:Section1;}
Bob
Sent: Friday C September 25 C 2009 2:02 PM
Rick Sked
N246RS
Flying naked
AirMike
PostPosted: Sat Sep 26, 2009 7:16 am    Post subject: Flap pre-positioning system Reply with quote
I like it. I flew in another RV10 that does not have it. It is not really a big deal to just set the flaps manually. Still, I like the simplicity of the system. It is easy to install - uncomplicated to operate and relatively foolproof. I also installed a little Ray Allen sensor (the 1.2" model) that shows the flaps position on my AFS3500 EFIS. My only note is that the change on the indicated position on the EFIS from reflex to 0 degrees is too small to show an indication on the EFIS.
See you OSH '18
Q/B - sold.
