Coil removal
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
dsavarese0812(at)bellsout
PostPosted: Mon Sep 28, 2009 3:38 am    Post subject: Coil removal Reply with quote
I think this is what you are looking for Henry. Let me know if I can be of further help.
Dennis
A. Dennis Savarese
334-285-2141
334-546-8182 (cell)
Skype: yakworld1
www.yak-52.com
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Magneto_coil_removal_description.doc
 Filename:  Magneto_coil_removal_description.doc
 Filesize:  243 KB
 Downloaded:  837 Time(s)
Dennis
A. Dennis Savarese
334-285-2141
334-546-8182 (cell)
Skype: yakworld1
www.yak-52.com
 Filesize:  243 KB
 Downloaded:  877 Time(s)
HBaker
PostPosted: Fri Jan 01, 2010 6:28 pm    Post subject: Re: Coil removal Reply with quote
Thanks Dennis,
I asked the wrong question. I need to know exactly where the p-leads from my ignition switch connects to the mags. Can't see anything obvious. Also need to know where the p-lead ground (shield) connects.
I have M9-F mags.
And 1 more question ... can you describe where the + 12 volts and ground connects to the shower of sparks (booster coil). I see a stud with 2 nuts on it with the letter "N" stamped next to it and this unit has a adjustment screw on top.
Thanks for your reply.
Henry
Currently building a Murphy Moose - any help would be appreciated.
PostPosted: Fri Jan 01, 2010 6:51 pm    Post subject: Coil removal Reply with quote
Henry,
The P leads connect/screw into the back end of the mag at the bottom. You should be able to see the threaded fitting. The back end of the mag is directly opposite the end where the plug wires exit the front of the mag.
Connection of the shield is to the insulated washer inside the knurled nut as explained in my previous email.
If you are using a Russian or Chinese "shower of sparks" (starting coil), they are 24 volt units, not 12 volt units and the + and ground wires are connected to two terminals under the cover. I don't have a drawing of it available or I'd send it to you.
Dennis
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
