ncol(at)xtra.co.nz Guest
Posted: Tue Sep 29, 2009 9:41 am Post subject: Door bulge |
Here is an air to air pic + enlargement.
Speed was only about 110 knts max as the photo ship was a C182.
On the ground the door is perfectly flush all around, with no visible
bulge at the leading edge, nor at the bottom.
In flight I have not noticed it moving out, but we have a thick lining
material there. But the bulge is definitely visible in these pics. Our
pins go right into the frame as per Vans instructions, but it serves
as a reminder to ensure that the front pins have plenty of engagement.
We also have the Vans door warning system and that hasn't illumintated
in flight.
Nor is there any feeling of a draught at all, so the seals obviously
do their job well.
Neil
29.72 KB |
7368 Time(s) |
28.75 KB |
7368 Time(s) |
bkbrown(at)minetfiber.com Guest
Posted: Tue Sep 29, 2009 2:46 pm Post subject: Door bulge |
Makes one wonder if a spring loaded latch pin engaging through the sill
vertically at the center of the door would help. Visualize a door latch,
that is flat on one side (to facilitate latching) and rounded on the other.
It would make getting out of the plane a "two-latch" affair, but may prevent
the in-air mating of a door to the horizontal stab...
Kellym
Posted: Tue Sep 29, 2009 3:59 pm Post subject: Door bulge |
One RV-10 at OSH had just what you suggest. Owner had door come open and
off before rotation, and was able to abort, and door did not hit
anything to damage airframe. He was not about to have a second event, so
put latch with clevis pins vertically through bottom of each door. I
don't think I got a picture, but if I look, I can get the tail number.
KCHD |
toaster73(at)embarqmail.c Guest
Posted: Tue Sep 29, 2009 7:11 pm Post subject: Door bulge |
Here it is.
Chris
123.85 KB |
7330 Time(s) |
AirMike
Posted: Wed Sep 30, 2009 2:25 am Post subject: Door bulge = RV10 archilles heel |
N220RV - the factory Continental equipped RV10 has a nice latch system. I do not know when it was installed but it is a spring loaded mid door latch
630.26 KB |
7312 Time(s) |
_________________ See you OSH '18
Q/B - sold. |
velo
Posted: Wed Sep 30, 2009 6:33 am Post subject: Re: Door bulge |
Is this Van's answer to their door design? I think they should make this modification available to all builders as a standard build item. Has anyone talked with Van's about this mod?
Rick
kearney
Posted: Wed Sep 30, 2009 8:09 am Post subject: Door bulge |
Hi
Does anyone have a pix of the N220RV mid door latch? I'd like to see how
Van's handled this issue.
Cheers
Les
