		Ken
				 Posted: Thu Oct 01, 2009 3:53 pm    Post subject: Washer usage |
				What are the rules regarding usage of flat washers on the AN bolts?  I assume you must have one under the nut so you don't scuff the metal it is tightening against (when you tighten it)?  How about the other end, is it necessary or even required by FARs?
 How about on the rudder pedal where you have a bolt going through a clevis that attaches the cable?  Is a washer under the castle nut enough or do you need one under the head as well?
 Thanks in advance.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Thruster87
				 Posted: Thu Oct 01, 2009 9:15 pm    Post subject: Re: Washer usage |
				 	  | Ken wrote: | 	 		  What are the rules regarding usage of flat washers on the AN bolts?  I assume you must have one under the nut so you don't scuff the metal it is tightening against (when you tighten it)?  How about the other end, is it necessary or even required by FARs?
 Thanks in advance. | 	  Washers are there to spread/transfer the loads  and secondary for scuff marks.You can use just one under the nut  or max two under nut one under head.Usually with clevis pins you only use one for the split pin end as the head is already against solid metal.  Hope that helps Cheers
		bryanmmartin
				 Posted: Thu Oct 01, 2009 9:57 pm    Post subject: Washer usage |
				See AC 43.13-1B, paragraph 7-37. The maximum combined height of
 washers that should be used is 1/8". Since standard AN washers are
 1/16" thick, that usually means no more than two washers can be used.
 1/32" washers are also available. You should have one washer under the
 nut, you don't usually need one under the bolt head. An additional
 washer can be used, if necessary, to keep the nut from bottoming out
 on the shank of the bolt. The additional washer can be placed on
 either end of the bolt. If more than two washers are needed to keep
 the nut from bottoming out, you should use the next shorter bolt.  AN
 bolts are available in multiples of 1/8".
 On the cable attachment to the rudder pedals, the nut will not be
 tightened. The nut will be left loose enough to allow the parts to
 move freely, which is why a castle nut and cotter pin is required
 here. You will probably need a washer under the nut to keep the
 threads from bearing on the moving parts. You may not need a washer
 under the bolt head. Only the unthreaded shank of thethe bolt should
 bear on the moving parts of the cable connection.
 On Oct 1, 2009, at 7:53 PM, Ken wrote:
  Thanks in advance.
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
  _________________ --
Bryan Martin
do not archive. |
		klaus(at)utdallas.edu Guest
				 Posted: Fri Oct 02, 2009 5:43 am    Post subject: Washer usage |
				Hi Ken,
 The general rule is that a washer must be used on both sides. The reason
 is not just to prevent the head or nut from damaging the surface
 during the tightening, but also to prevent dangerous corrosion.
 The cadmium plating of the washers is
 attacked by any corrosion first and thus prevents corrosion at the head
 or nut, where corrosion would be dangerous.
 Happy flying,
 Klaus
		z601a(at)anemicaardvark.c Guest
				 Posted: Fri Oct 02, 2009 6:15 am    Post subject: Washer usage |
				On Friday 02 October 2009 08:37, Klaus Truemper wrote:
  Hi Ken,
  Happy flying,
  Klaus
 A delimma I've found is that Zenith doesn't always supply, or call out, bolts
 that allow the use of two washers. I've also found that some of their photos
 and drawings do not show the use of washers.
 I think this is a mistake, and that Klaus is correct: it is very desirable
 that there be a washer under both the head of the bolt, and under the nut.
 Another rule of thumb I see ignored in the parts supplied, the drawings, and
 the photos is the number of threads showing beyond the end of the nut. I
 think I recall AC 43-13 requiring a minimum of one thread showing, and a
 maximum of three. Of course, additional washers, up to a maximum of three, or
 a maximum 1/8", may be added to achieve this.
 I again emphasize that AC43-13 does not apply to experiemental aircraft, but
 that's a good guideline. You sure don't want installed bolts that don't have
 less than a thread showing beyond the nut.
                 Do not archive.
                 Jim B Belcher
     BS, MS Physics, Math, Computer Science
                   A&P/IA
      Retired aerospace technical manager
      Mathematics and alcohol do not mix.
          Do not drink and derive.
		carlossa52(at)gmail.com Guest
				 Posted: Fri Oct 02, 2009 8:23 pm    Post subject: Washer usage |
				There is a good summarized Standard document in the ZAC web site.
 I don't know if it is still pointed to by any ZAC web page. If it is, I could not find it. But I do have the direct link to the document:
  http://www.zenithair.com/pdf-doc/zenair construction standards draft 1-07.pdf
  It does not replace AC43-13, but it is a pretty useful summary.
  I believe it is also provided in the CDs that ship with the kit.
 Carlos
 2009/10/1 Ken <hror1(at)pld.com (hror1(at)pld.com)>
 [quote] --> Zenith-List message posted by: "Ken" <hror1(at)pld.com (hror1(at)pld.com)>
  Thanks in advance.
