		MauleDriver(at)nc.rr.com Guest
				 Posted: Sat Oct 03, 2009 8:14 am    Post subject: Door-I'm the guy - how about those seals? |
				Dave, I'm getting ready to re-search the list for seal information so I
 can finish off my doors.  I know you've mentioned your preference for
 foam seals over the Van's bulb type.  I know others have used other bulb
 type seals.
 What do you think the trade-offs are for the foam seal?  Does it work
 well relative to rain?
 What exactly did you use?
 Bill "trying to figure out what to do next and hoping it doesn't involve
 sanding fiberglass" Watson
 Dave Saylor wrote:
  	  | Quote: | 	 		   John,
  Thanks so much for your account of the episode.  I was starting to get
  a little bored with my routine:  I push on the back of each door just
  before take-off.  Now I know I'll stick with that checklist item for good.
  What type of door seal do you have?  I wrote a few days ago that I
  think the Van's bulb seal does a disservice to being able to
  effectively close the door.  I have foam seals that IMO work much better.
  Another point is that if the pins are installed per the plans, the
  bevels get installed with the long edge outboard.  Presumably, that
  ensures more engagement with the fuselage uprights since the long edge
  of the pin is outboard, contacting metal.  But that arrangement also
  helps the pins miss the hole unless the door is pulled all the way in
  during latching.  When I re-rigged my doors I turned the bevel around
  to face "angled edge out", so that the pins would be more likely to
  engage.  The bevel then helps pull the door in, even if the door isn't
  quite closed. Since I also installed metal guide blocks at the same
  time, I was sure I was getting a good, solid, metal-on-metal pin
  engagement.
  You did a great job Flying The Plane.  Even the other -10 that had the
  tail strike seemed to land well enough.  We should take away from this
  that a lost door clearly doesn't have to result in an accident if we
  remember to fly the plane.
  ******Shameless plug warning******
  Insurance pays (AirCrafters) well for door repairs, too, in case you
  don't want to do it yourself--I never do MY own surgery
  Best Regards,
  Dave Saylor
  AirCrafters LLC
		kearney
				 Posted: Sat Oct 03, 2009 9:24 am    Post subject: Door-I'm the guy - how about those seals? |
 Many builders have used the McMaster Carr edge grip seals (see
 http://www.mcmaster.com/#1120a732/=3wg8ba (type 3 seals). I bought lots so I
 could use some as "sacrificial seals" while I was doing the initial fit of
 my doors. That way I could ensure that the doors didn't become more
 difficult to close after the seals were installed. Apparently the door
 geometry can change after seals are installed so it is best to fit the doors
 with them. Whatever seals you plan on using, I recommend that be on the
 doors when fitting.
 Using the above seals will require f/g work - Oh Joy!
 Cheers
 Les
 #409643 - Living in f/g hell
		jchang10
				 Posted: Sat Oct 03, 2009 10:11 am    Post subject: Door-I'm the guy - how about those seals? |
				Les, what has your experience been so far with the edge seals? I guess I
 should order some of it to test myself. It seems like I can forsee a few
 fitting issues.
 The edge of my fiberglass door frames seem to vary from 1/8" up to 1/4".
 The lower parts of the door frame are thinner and the upper parts, esp.
 around the top forward corner and top aft corners have thicker edges.
 Did you have any edge fitting issues?
 Which Type 3 seals did you use again? Edge A B and C dimensions?
 Thanks!
 Jae
 40533
 Les Kearney wrote:
  doors when fitting.
  Cheers
  Les
  _________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
		kearney
				 Posted: Sat Oct 03, 2009 11:10 am    Post subject: Door-I'm the guy - how about those seals? |
				Jae
 I used part # 1120A313 - (3/16 grip with a 3/8" bulb).
 I used a Dremel with a small drum sander to even up the flanges for the
 seals. Some places the f/g was hugely thick and others almost perfect.
 I found that it was difficult to get an even line where I had to notch into
 the flange due to thickness. After I had fitted the seals, I covered the
 seal flange with packing tape, put in place and filled any gaps with
 superfill. The result was a clean edge where the notch meets the edge of the
 seal.
 I hope that is clear, if not I will see if I took any pix.
 Although fitting the doors with the seals in place was a lot of work but the
 end result is that I have a consistent seal around the doors. Now the doors
 open and close without a lot of effort. I can't image doing this, then
 fitting seals, and then adjusting again due to the seal changing the
 geometry.
 Here is the single most important think I did to get the doors to close
 easily. I found that the pressure of the seals on the bottom of the door
 made closing hard. There is little leverage at the bottom of the door to
 compress the seals. To fix, I pushed the bottom of the f/g door frame in
 board about 1/8". This reduces the amount of compression on the door seal at
 the bottom of the door made closing much, much easier.
 I didn't final drill the door opening holes (#19 & #12) until after I
 finished fitting the doors. This made adjusting the position of the door
 frame very simple. (It easier to fill & move small #30 hole than #19 & # 12
 holes).
 In a couple of places I moved the door flange by building up the back side
 and then removing material from the face.
 None of this was hard, it was just time consuming. And I just love f/g dust.
 Cheers
 Les
 #40643 - living in f/g hell
		msausen
  Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
				 Posted: Sat Oct 03, 2009 12:41 pm    Post subject: Door-I'm the guy - how about those seals? |
				I'll second pretty much everything that Les said as I'm sure would Deems, Rick, etc.  It's not a trivial task to switch to the edge seals but, IMHO, the end result is much better than the factory setup.  I spent probably an additional 20 hours getting the edge sanded down and built back up in the right spots to get a good fit and I still have some of the extra pressure to overcome as Les describes on the bottom of the door.  Without the seals my doors drop into place and lock with no effort.  With the seals on, well, I need to work on that.     Once I get my doors back from Abby I'll probably look closer at that again and try and reduce some of the pressure.
   One other thing I did was to slice the little barb off from the inside of the seal.  This greatly improved the fit on the door frame.  For anyone that thinks venturing from the plans method is straight forward, think again.  When it's all said and done I probably have at least 130 hours into my doors from beginning to end.  These types of mods probably contributed about 40 hours to it.
 Michael
		rene(at)felker.com Guest
				 Posted: Sat Oct 03, 2009 3:20 pm    Post subject: Door-I'm the guy - how about those seals? |
				Here is what I used.....I think they work great....I am not that picky
 thou...
 http://www.rvtraining.com/html/atp/rv10_door_seals.html
 Rene'
 801-721-6080
		jchang10
				 Posted: Sun Oct 04, 2009 9:32 am    Post subject: Door-I'm the guy - how about those seals? |
				Thanks Les for that description.
 I suspected there would be more work involved than just cutting and
 slipping on the seal, but there is definitely more work than even I had
 hoped. It's not entirely surprising, though, just from looking at my own
 door frame and realizing just how little uniformity there is.
 Jae
		kearney
				 Posted: Sun Oct 04, 2009 9:57 am    Post subject: Door-I'm the guy - how about those seals? |
				Jae
 It is a bit of work. For me, what was time consuming was figuring out what
 to do, doing it and then realizing I had to correct something as my
 assumptions were wrong. I can't believe doing as per plans would be any
 easier.
 Moving the door frame inboard was a key factor in making the doors easy to
 close. Using white grease on the door mechanism also removed a great deal of
 closing resistance when operating the mechanism.
 Cheers
 Les
				 Posted: Sun Oct 04, 2009 12:54 pm    Post subject: Door-I'm the guy - how about those seals? |
				Bill,
  	  | Quote: | 	 		   What do you think the trade-offs are for the foam seal?  Does it work well relative to rain?
 I can't recall leaving the plane out in heavy rain for very long, but we've flown through some pretty heavy downpours and done lots of washings.  I can't remember seeing any water inside...that feels like I'm overstating, but I certainly don't have any leaks worth trying to fix.
 The downside to the foam seals is that they look a little tacky, especially on the bottom edge where I built them out using a couple layers.  I think Les may have built out his fuselage edges to come closer to the door, which would improve that area by a ton.
 I was looking at the way the doors close yesterday.  I could post a video if someone wants it.  The doors just come right down to within about an inch of closing, and it just takes a very slight effort to pull in and latch.  It's all because of the seal, which since it takes a set, doesn't interfere with the door closing.  It's just not part of the equation.
 I have the McMaster P/N at work, along with some pictures.  I'll send those out on Monday.
 Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA 95076
 831-722-9141 Shop
  831-750-0284 Cell
