		Scotsman
  Joined: 27 Aug 2007 Posts: 89 Location: Johannesburg, South Africa
		pavel569
				 Posted: Wed Jun 24, 2009 5:03 am    Post subject: Re: Fuselage Side Skins (Front) |
				James,
 if your side skin is aligned with the fuse floor aft of the gear channel and you have the gear channel level and firewall at the required angle (77deg) you should end up perfectly aligned. It's important to hold the gear channel down with some weight to keep it level.
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive" |
		psm(at)att.net Guest
				 Posted: Wed Jun 24, 2009 5:03 am    Post subject: Fuselage Side Skins (Front) |
				Hi James,
 I think I had a similar problem (if I really understood your
 issue).  The position of the gear channel and cabin floor has a
 couple of degrees of freedom.  I needed to be very careful that all
 the pieces were firmly held at the correct angles to get it all to
 fit together.  I think my parts - particularly the side skin - had
 fewer holes pre-drilled than yours, so I may have had a slightly
 different set of issues to handle.
 This is the kind of question that the tech support folks at Zenith
 are really good at handling.  I suggest you give them a call before
 doing anything permanent.  I realize this might take some tricky
 scheduling because of the different time zones, but I think it would
 be worth your while.
 Good luck,
 Paul
 XL grounded.
 At 05:44 AM 6/24/2009, you wrote:
 <james.roberts(at)computershare.co.za>
 Afternoon all, frustration and probable stupidity has driven me to
 posting this question on the list.   [Embarassed]
 I am at the point where I am trial fitting the front side skins of
 the fuselage to the ac.  I have followed the steps in the builders
 photo guide but have hit the following problem.  I can't see where I
 have gone wrong so I am hoping that someone on the list can enlighten me.
 When trial fitting the front side skins of the fuselage I have
 pressed the rear of the skin against the rear spar attach plate and
 things look good at that end in terms of the height of the skin
 versus the upper longeron and the lower longeron (plus also alignment).
 As I look along the floor of the cockpit from the attach plate to
 the gear channel all is perfectly aligned.  The problem is between
 the main spar and the gear channel that the alignment of the
 predrilled holes on the bottom of the side skin drops below the
 height of the cockpit floor.  This obviously isn't meant to happen.
 The instructions state to raise the firewall 42 mm (if I remember
 correctly) off the beams and what appears to be causing this is that
 the reinforcing "longerons" under the cockpit floor appear to be
 raising the floor above its intended level.  If I try raising the
 upper longeron to compensate then I no longer have a level upper
 longeron (ie. just creating another problem).
 Has anyone experienced this or alternatively can visualise how I may
 have cocked this up?  Any help would be appreciated as this is quite
 frustrating and holding up the build.
 Cheers
 James
 Cell   +27 83 675 0815
		Scotsman
				 Posted: Wed Jun 24, 2009 5:27 am    Post subject: Re: Fuselage Side Skins (Front) |
				Thanks for the responses so far.
 Pavel - I have a good sized collection of weights on top of the gear channel as otherwise it was inclined to bow upwards slightly.  I made the firewall jig in accordance with the specs so the firewall should be at the required 77 degrees.
 Paul - How did you solve the problem with yours?  Going from aft towards the firewall the predrilled holes at the foot of the side skin essentially stop at the main spar (there are other holes after that but they are significantly higher on the skins for some of the L angles that get attached later).  The overlap of the bottom of the side skin forward of the firewall gets trimmed later...on the aft side of the firewall it should be flush and not overhang by 0.5 cm.
 Any other ideas before I zip an email to Zenith....ideally I would like to fix the problem tonight.
 Cheers
 James
  _________________ Cell   +27 83 675 0815 |
				 Posted: Wed Jun 24, 2009 5:51 am    Post subject: Fuselage Side Skins (Front) |
				Hi James,
 I wish I could remember all the details of that
 problem.  Unfortunately it was a couple of years ago when I faced
 it.  The sad news is that the notion of 90% complete and 90% to go is
 reality.  The difference is the time it takes to complete the
 airframe kit and actually finish the whole airplane that includes a
 lot of stuff not included in the kit like engine, instruments,
 upholstery, paint, etc.
 As I recall, I didn't wind up with any side skin overhang on the
 firewall.  Also, I remember needing to cut a rather deep notch in the
 side skin around the wing rear channel connection to get the proper
 overhang between the side skin and the rear side skin.  In my case,
 the trimming was done on the rear end of the front side skin rather
 than around the firewall end.
 On second thought, I think the side skin hangs quite a way over the
 firewall to allow for attachment of the engine cowl.  Maybe I am just
 remembering this all wrong.  My plane and drawing set are at the
 hangar, and I am at home.
 I also had difficulties that generated a long conversation with one
 of the Zenith guys over the overall mating of the front to rear
 fuselage and the resulting "Fit",  I wound up with one less rivet in
 the side "Splice" of the top longeron than the drawings show (7 sets
 of rivets instead of  .  I also had to extend the baggage floor
 perhaps one cm.
 The only suggestion I can offer is to double check the angle of the
 gear channel to both the front floor and the rear section of the fuselage.
 Good luck,
 Paul
 XL grounded
 At 06:27 AM 6/24/2009, you wrote:
 Cheers
 James
		Davcoberly(at)wmconnect.c Guest
				 Posted: Wed Jun 24, 2009 10:10 am    Post subject: Fuselage Side Skins (Front) |
				There was a lot of the pre-punched holes on the sides skins that I fought with trying to get everything to line up with.  After talking to Zenith I just drilled new holes between and above those that you are talking about nobody will ever notice they will be under the wings anyway. David Coberly  [quote][b]
		chuck960
				 Posted: Wed Jun 24, 2009 6:04 pm    Post subject: Re: Fuselage Side Skins (Front) |
				James,
 I'm at the same place you are with my 650.
 The side skin forward of the spar hangs down past the floor. I'm hoping that there is still clearance for the pre drilled holes.
 Aft of the spar the skin lines up fine along the bottom.
 I had to play with the upper longerons a bit and make sure you have the width between the longerons correct. The seat back top piece should be in place as well as the instrument panel. Also I had to add 5 mm to the 19 mm shim that sits under the Rear Skin forward corner and then re-level everything.  It took two days of screwing around to tweak this setup. And I had to add weight to the gear channel.
 Chuck
		w8n2bup
  Joined: 09 Apr 2008 Posts: 20 Location: Kansas City Area
				 Posted: Wed Jun 24, 2009 6:36 pm    Post subject: Re: Fuselage Side Skins (Front) |
				James,
 I had exactly this same problem about two months ago with my pre-drilled holes too low on the bottom, among other minor pre-cut and drilled areas on the side skin.  Roger at Zenith said he had heard of similar problems and they sent me, free of charge, two new side skins without any pre-drilled holes, only the air intake cutout.  This meant I had to lay out all my own hole patterns and cutouts for the wing spar but was certainly worth it because everything now fits perfectly. If you have any further questions, please feel free to call me at 913-856-4900 after 6PM or 913-915-1989 during the day.
 John
		aussiech650
  Joined: 04 Oct 2009 Posts: 25 Location: Sydney, Australia
				 Posted: Sun Oct 04, 2009 7:16 am    Post subject: Re: Fuselage Side Skins (Front) |
				Hi, I have just reached this stage on my CH650 fuselage and my front side skins dont appear to be correct either. Have the factory made a change to these skins to rectify this issue?
