Ray Allen trim indicator failures
kdbelue(at)charter.net
PostPosted: Mon Oct 05, 2009 4:54 am    Post subject: Ray Allen trim indicator failures Reply with quote
I'm using the Ray Allen LED trim indicators but they quit working
after a few hours of flying. I could get them to work temporarily by
thumping them, but now they rarely work. Have others had this problem
and did you ever get them to work reliably?
Kevin Belue
RV10 flying
RV6A flying
Tim Olson
PostPosted: Mon Oct 05, 2009 5:20 am    Post subject: Ray Allen trim indicator failures Reply with quote
Yeah, internally I've found solder joints broken and such. You should
take a peek inside once. In the end, I had one that I just couldn't
fix and they sent me a replacement.
Tim Olson - RV-10 N104CD
Kevin Belue wrote:
I'm using the Ray Allen LED trim indicators but they quit working after
a few hours of flying. I could get them to work temporarily by thumping
them, but now they rarely work. Have others had this problem and did you
Kevin Belue
RV10 flying
RV6A flying
recapen(at)earthlink.net
PostPosted: Mon Oct 05, 2009 5:24 am    Post subject: Ray Allen trim indicator failures Reply with quote
I have three in my panel and have replaced them all at least once as individual LED's have failed.
I have one that is doing the same thing that you've mentioned and when I give it a good flick-thump it comes back.
Maybe another bad batch of something.
Ralph
RV6A N822AR (at) N06 38.4hrs - sooooo close
PostPosted: Mon Oct 05, 2009 6:49 am    Post subject: Ray Allen trim indicator failures Reply with quote
My annual inspection is due next month so I'm waiting until then and
I'll take it apart. I thought there might be bad solder joints - you'd
think they would correct that QC issue by now....
Thanks for the info!
Kevin
> by thumping them, but now they rarely work. Have others had this
> problem and did you ever get them to work reliably?
> Kevin Belue
> RV10 flying
> RV6A flying
Phil.Perry(at)netapp.com
PostPosted: Mon Oct 05, 2009 8:07 am    Post subject: Ray Allen trim indicator failures Reply with quote
Thanks for the tip.. Before installing mine, I'm going to open them up
and take a peek inside.
Phil
